2002 Tundra Body Mount Kit
Discussion in '1st Gen Tundras (2000-2006)' started by JimmyDog, Jul 25, 2023.
  1. Jul 25, 2023 at 2:12 PM
    JimmyDog
    JimmyDog [OP] New Member
    I have a 2002 Toyota Tundra. I need to find a kit to replace all the cab body mounts. The bushings are worn out. It’s an SR5, has the V-8. Where can I get this kit? I’ve seen a few posts about the body mounts here but nothing conclusive. Also, is this something I can replace myself. Thank you,
    JimmyDog
  2. Jul 25, 2023 at 2:25 PM
    shifty` Waving My Dick In The Wind
  3. Jul 27, 2023 at 11:06 AM
    JimmyDog
    There are three mounts on each side for the cab mounts. I’m able to order the complete body mounts, including all hardware and bushings from Toyota. However, the rear bushings are on back order. I’ll order those, too, except I have to wait on the back order.
  4. Jul 27, 2023 at 11:11 AM
    Did you check that thread? It redirects over to this thread, right at the start. You may find alternate part numbers, part numbers from other Toyota trucks that'll work in that thread. Give it a shot. I don't want to read it myself, but going from memory I know there was a lot of helpful info in it for parts and process.
  5. Jul 27, 2023 at 11:21 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I ended up using these on a 2005 double cab. I did not use the front two and they don't fit a double cab because the diamond shaped plates are too small so I made my own. I would think they will work fine for an access or reg cab. If you have a mount that is out, it's easy to compare. or you can measure from below the truck the outer bolt spacing. If not, Amazon takes them back pretty easy.
    https://www.amazon.com/gp/product/B00G1X9ZBK?ie=UTF8
    Jack McCarthy and shifty` like this.
  6. Jul 27, 2023 at 11:40 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Did you talk to the parts department directly? The different numbers you see may actually be the same part. They were for my truck. However, I did choose the energy suspension route.
  7. Jul 27, 2023 at 1:36 PM
    alb1k
    Left Coast
    It's good
    On a side note, the middle and the rear are the same, except the rear has more rubber and therefore more strength. If I were to do it again with OEM, I would get the rears for both rear and middle. Fronts are completely smaller and different
    Jack McCarthy likes this.
  8. Jul 29, 2023 at 9:57 PM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Are you saying if you did it over again that you would go with OEM?
    How do you like the energy poly stuff so far? Any ill side effects? Thanks
  9. Jul 30, 2023 at 5:56 AM
    Jack McCarthy
    Bill
    North of Boston
    I don’t have an issue with the energy suspension parts. YMMV
