2002 3.4 runner engine into a 2002 Tundra
Discussion in '1st Gen Builds (2000-2006)' started by BDScott, Aug 23, 2022.
  1. Aug 23, 2022 at 5:18 AM
    BDScott
    BDScott [OP] New Member
    2002 tundra 3.4l 4x4
    Hello,
    I have a 2002 Tundra 3.4l 4x4 with a bad engine, I found a great running 3.4L engine from a 2002 4runner. Will this motor from the 4 runner have any issues in the tundra? Any things that make them different that I may need to know before doing the swap?
    Thanks for any help!
  2. Aug 23, 2022 at 6:30 AM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
  3. Aug 23, 2022 at 1:48 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Just keep the harness and sensors from the tundra and toss them in the 4runner engine. They’re the same. Only potential difference is the 4runner might not have the oil cooler on the block, but it can be swapped over
  4. Jan 13, 2023 at 5:40 PM
    NorthOf40
    NorthOf40 New Member
    If you search Toyota's parts website for the "partial engine assembly" you can get a part number for the engine in your truck. You can then click on "what this fits" to see what else it was used in.
    For my 2000, the engine part number is: 19000-62320
    and it was used in:
    Toyota 4Runner 2WD Base
    2001, 2002
    Toyota 4Runner 3.4L A/T Base
    2000
    Toyota 4Runner 4WD LIMITED
    2001, 2002
    Toyota 4Runner 4WD SR-5
    2001, 2002
    Toyota Tacoma 3.4L A/T 2WD Double Cab PreRunner
    2001, 2002, 2003, 2004
    Toyota Tacoma 3.4L A/T 2WD EXTRA CAB DLX
    2000
    Toyota Tacoma 3.4L A/T 2WD Xtracab PreRunner
    Toyota Tacoma 3.4L A/T 4WD Double Cab DLX
    Toyota Tacoma 3.4L A/T 4WD EXTRA CAB DLX
    2000
    Toyota Tacoma 3.4L A/T 4WD Xtracab
    Toyota Tundra 3.4L A/T 2WD Access Cab Limited
    2001, 2002
    Toyota Tundra 3.4L A/T 2WD Regular Cab SR-5
    2001, 2002
    Toyota Tundra 3.4L A/T 4WD Access Cab SR-5
    Toyota Tundra 3.4L A/T Access Cab Limited
    2000
    Toyota Tundra 3.4L A/T Access Cab SR-5
    2000
    Toyota Tundra 3.4L A/T Regular Cab SR-5
    2000
    Toyota Tundra 3.4L M/T 2WD Access Cab SR-5
    Toyota Tundra 3.4L M/T 2WD Regular Cab DLX
    Toyota Tundra 3.4L M/T 2WD Regular Cab SR-5
    2001, 2002
    Toyota Tundra 3.4L M/T 4WD Access Cab SR-5
    Toyota Tundra 3.4L M/T Access Cab SR-5
    2000
    Toyota Tundra 3.4L M/T Regular Cab DLX
    2000
    Toyota Tundra 3.4L M/T Regular Cab SR-5
    2000
    If your heads are okay, you might only need the short block which was used in even more vehicles:
    2001, 2002
    Toyota 4Runner 2WD LIMITED
    2001, 2002
    Toyota 4Runner 2WD SR-5
    2001, 2002
    2000
    Toyota 4Runner 3.4L A/T LIMITED
    1999, 2000
    Toyota 4Runner 3.4L A/T SR-5
    1999, 2000
    Toyota 4Runner 3.4L M/T Base
    2000
    Toyota 4Runner 3.4L M/T SR-5
    1999, 2000
    2001, 2002
    2001, 2002
    1999, 2000
    1999, 2000
    Toyota Tacoma 3.4L A/T 4WD EXTRA CAB SR-5
    1999, 2000
    Toyota Tacoma 3.4L M/T 2WD EXTRA CAB DLX
    1999, 2000
    Toyota Tacoma 3.4L M/T 2WD Xtracab S-Runner
    Toyota Tacoma 3.4L M/T 2WD Xtracab Sport S-Runner
    2002, 2003
    Toyota Tacoma 3.4L M/T 4WD EXTRA CAB DLX
    1999, 2000
    Toyota Tacoma 3.4L M/T 4WD EXTRA CAB SR-5
    1999, 2000
    Toyota Tacoma 3.4L M/T 4WD Xtracab
    2001, 2002
    Toyota Tundra 3.4L A/T 2WD Access Cab SR-5
    Toyota Tundra 3.4L A/T 2WD Regular Cab DLX
    2001, 2002
    2000
    2000
    Toyota Tundra 3.4L A/T Regular Cab DLX
    2000
    2000
    2001, 2002
    2000
    2000
    2000
    It is possible a 3.4 from a T100 would fit too, but there was something that changed between the 90s and 2000s and you'd probably want to check each part number one by one (block, piston, rods, crankshaft, etc) to see what it is.
