2001 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by 01yota, Aug 30, 2020.
  1. Aug 30, 2020 at 8:31 PM
    01yota
    01yota [OP] New Member
    Tyler
    2001 tundra sr5
    I put an exhaust on about a month ago. I’m getting noticeably worse gas mileage, I can smell gas when I start it up like it’s letting out gas that’s unused. I have 3 exhaust leaks that I plan on welding tomorrow. I don’t know why I’m getting the gas smell. Is it the computers not adjusting to the new system. Is it the leaks? Any help is greatly appreciated
  2. Aug 30, 2020 at 9:17 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Is your check engine light on??
  3. Aug 31, 2020 at 4:38 AM
    Professional Hand Model
    Hand Protectors
    Might have bumped a hose loose up near the Gas Canister during the install. Mine fell off over time about 8 years ago just from driving. I could smell it. Popped the hood and jiggled some connections to investigate and it was a tired hose tip that slipped off.
    Cut the small tired end piece off and reconnected for the win and still holding.
    Side Note: I’m seeing quite a few recently installed ‘New Exhaust Systems’ having problems around here. Was yours professionally installed?
  4. Aug 31, 2020 at 6:08 AM
    01yota
    Tyler
    2001 tundra sr5
    No i installed it
  5. Aug 31, 2020 at 8:34 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    O2 sensors?
  6. Sep 5, 2020 at 4:36 PM
    01yota
    Tyler
    2001 tundra sr5
    I have a code for a bag 02 sensor
  7. Sep 6, 2020 at 1:30 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Sounds like a clue, but :notsure:
    Tundra2 likes this.
  8. Sep 6, 2020 at 5:46 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That will definitely mess with the way the truck runs. Bad O2 sensors will make the truck run rich, thinking it's still not up to operating temperature. That may be the fuel smell you are experiencing
    Stuck in the '00s likes this.
  9. Sep 7, 2020 at 5:46 AM
    Hand Protectors
    O2 possibly damaged during swap over. Maybe not plugged in properly. Etc.
