2001 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by 01yota, Aug 27, 2020.
  1. Aug 27, 2020 at 6:36 PM
    01yota
    01yota [OP] New Member
    Tyler
    2001 tundra sr5
    I have a 01 tundra SR5 v8 4wd. I recently cleaned my air filter and shortly after I noticed my engine making a loud intake/air noise. Sounds like a leaf blower full throttle in my engine bay when I accelerate, I have never heard it do this before. Any ideas what this could be. Any suggestions would be helpful
  2. Aug 27, 2020 at 6:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Is the filter properly clamped in? That’s 90% of the time the issue
  3. Aug 27, 2020 at 6:51 PM
    01yota
    Tyler
    2001 tundra sr5
    It’s probably clamped in yes. I also sprayed off MAF and cleaned throttle body but that was a while ago. It didn’t start doing this until after I cleaned my air filter
  4. Aug 27, 2020 at 6:54 PM
    empty_lord
    05 rollover special
    Take some photos around the air box if you can. Possible you knocked a hose off or something
  5. Aug 27, 2020 at 6:55 PM
    01yota
    Tyler
    2001 tundra sr5
    Ok I’ll post in just a few minutes stay with me
  6. Aug 27, 2020 at 7:08 PM
    01yota
    Tyler
    2001 tundra sr5
  7. Aug 27, 2020 at 7:09 PM
    01yota
    Tyler
    2001 tundra sr5
  8. Aug 27, 2020 at 7:10 PM
    01yota
    Tyler
    2001 tundra sr5
  9. Aug 27, 2020 at 7:10 PM
    01yota
    Tyler
    2001 tundra sr5
  10. Aug 27, 2020 at 7:35 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Was the filter still wet from the cleaning??
  11. Aug 27, 2020 at 7:52 PM
    01yota
    Tyler
    2001 tundra sr5
    Possibly
  12. Aug 27, 2020 at 7:58 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Is it equipped with a k&n? If so, maybe it was so dirty before cleaning it that it muffled the intake noise, and now that it’s clean you can hear it.
    Darkness and revtune like this.
  13. Aug 27, 2020 at 10:14 PM
    empty_lord
    05 rollover special
    well i cant see anything wrong here honestly. video might help... slim chance your fan clutch is stuck on now and your hearing the fan roaring to life? but that usually sounds like a 18 wheeler driving by on a hot day
    N84434 likes this.
  14. Aug 28, 2020 at 8:57 AM
    01yota
    Tyler
    2001 tundra sr5
    Could the MAF sensor be a reason? I cleaned it off as well as the throttle body. There is no way it’s the fan because this doesn’t sound normal I’ve never heard anything like this come from my truck
  15. Aug 28, 2020 at 9:01 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    No, you've got an air leak someplace in the intake system. Air is rushing in under acceleration and causing the noise.
    What about the connection between the Throttle Body and the intake hose?
  16. Aug 28, 2020 at 9:03 AM
    01yota
    Tyler
    2001 tundra sr5
    I tightened all the hose clamps down. Air box is clamped all the way down. I’m just not sure I’m worried but I know it’s nothing serious
  17. Aug 28, 2020 at 10:01 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    How about get an oem style paper filter off Amazon for $10-$15 dollars at most. Just to see if it is the filter. I don’t care for the oiled K&N filters anyhow.
  18. Aug 28, 2020 at 12:02 PM
    01yota
    Tyler
    2001 tundra sr5
    If my fan clutch is stuck “on” what should I do. I’m pretty sure this is the issue. Do I need a new one?
  19. Aug 28, 2020 at 1:15 PM
    empty_lord
    05 rollover special
    Yea new one is the typical fix. Technically they can be rebuilt. But no one does that these days
  20. Aug 28, 2020 at 2:05 PM
    StuntDouble
    StuntDouble Just here for the beer
    Missouri
    2001 Tundra
    You can try spraying brake cleaner around the area you were working on and if there is a leak present it will get sucked in and cause the engine to sputter slightly.
  21. Aug 28, 2020 at 4:18 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    How did you verify this? If the fan clutch has gone Tango Uniform, when you grab the fan to spin it, it should spin fairly freely. If it feels tight, or you can't move it at all, the clutch is shot.
    They're not horrible to change, but it is easier with the radiator out of the way. The clutch is sold separate from the fan, So you'll have to swap the fan over to the new clutch. Pretty sure it's all 10mm bolts you'll be dealing with.
