2001 Tundra V6 Automatic. 4x4 on. Floor
Discussion in '1st Gen Tundras (2000-2006)' started by Mhagha, Oct 5, 2022.
  1. Oct 5, 2022 at 6:39 AM
    Mhagha
    Mhagha [OP] New Member
    Hello everyone,
    I have a 2001 Toyota Tundra. Automatic It’s a V6 Access Cab.
    The 4x4 shifter is on the floor.
    (Pic attached)
    I cannot shift it out of position. Some have you said you just have to pull with force…. This thing isn’t budging!
    Any help would be great.
    2006 Tundra AC likes this.
  2. Oct 5, 2022 at 7:21 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    Unfortunately I don't think I can help you but I did not know they built them with the 4WD shifter on the floor. I've always seen it on the dash next to the clock.
  3. Oct 5, 2022 at 8:46 AM
    shifty` Is the Gila Copter a love machine?
    I think it's maybe only a V6 option, I haven't seen the V8 with floor shift.
    Tundra2 likes this.
  4. Oct 5, 2022 at 9:32 AM
    blenton
    blenton New Member
    Drive in reverse in a straight line for 10 feet, then park it on level ground and put the transmission in neutral. Put your foot out the door and rock the vehicle a bit and try changing the 4wd selector. Usually the drivetrain is a little bound up making it difficult to move the selector. It’s much easier to do with the vehicle in neutral.
    richsadams and des2mtn like this.
  5. Oct 5, 2022 at 1:55 PM
    Mhagha
    Thanks,
    Thats probably the only thing I haven't tried.....to drive backwards 10 ft
    Tundra2 likes this.
  6. Oct 5, 2022 at 2:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I have no advice other than what's already been said about being in neutral.
    The Field Service Manual is in my signature if you need technical diagrams or anything of that sort.
    richsadams likes this.
  7. Oct 5, 2022 at 2:39 PM
    blenton
    blenton New Member
    If that still doesn’t work, put a floor jack under the rear end and lift it just off the ground. Start it up, put ur foot on the brake, and shift to R, then D, then R, then N. Try moving the selector. Don’t forget to drop the jack back down and remove it.
    If its still jammed, the linkage could likely be the culprit. Inspect from u see watch the truck.
  8. Oct 5, 2022 at 3:31 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    After trying to remove an entire engine/transmission/x-fer case in a junkyard unsuccessfully...
    Which was the same engine/trans/x-fer combo as yours...
    There really isn't a whole lot that I can see going wrong with that in my minds eye, but I have very little experience with a floor shifter 4WD.
  9. Oct 6, 2022 at 3:09 AM
    Mhagha
    Yes I will try. ThAnk you everyone
  10. Oct 6, 2022 at 7:16 AM
    Mhagha
    Update
    So I did drive backwards a bit. Then in Neutral, I was able to move 4x4 one spot down and the 4x4 light did come on..
    Now, I am beyond confused. If you look at the picture attached. It looks like the truck is in 4L as per shifter. And its resting spot is all the way up forward.
    Shifter won’t move from that point. So if you look at shifter in pic. It looks like I moved it from 4L to Neutral…..
  11. Oct 6, 2022 at 7:34 AM
    I know with my truck, I can't shift into 4L *unless* the main shifter is in Neutral. This is by design and is discussed in the manual.
    Stupid question, but have you RTFM to see how Toyota wants you to use the 4WD shifter? It would make sense you had to be in Neutral to do anything with it.
  12. Oct 6, 2022 at 11:24 AM
    Mhagha
    I have the manual. And all info for from 2005. It was bought certified. I also contacted dealer and I would have to leave it for them to even look at it. And there will be a charge.
  13. Oct 6, 2022 at 11:26 AM
    Mhagha
    And in case anyone wants to see the window sticker. This is it
  14. Oct 6, 2022 at 11:26 AM
    Mhagha
    Window sticker
  15. Oct 6, 2022 at 12:24 PM
    snoope likes this.
  16. Oct 6, 2022 at 1:05 PM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    You shifted from H2 to H4. Move it right and up to get to neutral. Shift the trans to neutral then you can shift the xfer case to L4.
    snoope likes this.
  17. Oct 6, 2022 at 2:13 PM
    Mhagha
    Update.
    After this morning when Blenton stated to drive in reverse about 10 ft. My 4x4. Ended up going from H2 to H4, but nothing further from that point. I Drove to work and back. I Just parked and tried the same thing and this F*****g shifter is…..working!!!
    Leaving my truck in Neutral. I was able to shift from H2 -H4- N- L4. So thanks man.
    Thank you to all you guys for taking your time to help everyone on here!!!!
    Shifty as usual. Thanks for the links and all the help.
    I have a big koolaid smile now
    dbittle, bmf4069, digitalferg and 3 others like this.
  18. Oct 6, 2022 at 3:03 PM
    Consider fluid change now, make sure you put the right stuff in it. Chances are, what's in the diffs is gnarly after years of non-use.
    Tundra2, snoope and Mhagha[OP] like this.
  19. Oct 7, 2022 at 11:10 AM
    Boone01Tundra
    Boone01Tundra New Member
    Benjamin
    Boone, NC
    2001 AC Tundra V8. OEM 2 tone. Leather 48k miles
    Man, I would prefer to have an actual 4x4 shifter like that. I hate "magic push button" 4x4.
    Bprose, bmf4069 and Tundra2 like this.
  20. Oct 8, 2022 at 8:32 AM
    bmf4069
    TX
    02 AC sr5 4wd v8
    Agreed. I think there was someone on here that put one in theirs along with a manual.
    Tundra2 likes this.
