2001 Tundra TRD trailer light harness failed
Discussion in 'Towing & Hauling' started by tomundra, Mar 18, 2020.
  1. Mar 18, 2020 at 4:16 PM
    tomundra
    tomundra [OP] New Member
    Thomas
    Watkinsville, GA
    2001 Tundra TRD
    None
    My 2001 Tundra TRD has dropped power at the back end of the factory trailer wiring harness. It has a Reese 85247 Towpower converter which I have removed from the harness to check power at the plug, nada. Fuses are good up front, seems like the harness is in good shape, what I can see off it. Anyone else have this problem and/or fixes?
  2. Mar 18, 2020 at 4:36 PM
    koditten
    Kirk
    Midland of the Mitten
    Dollars to doughnuts, that converter box has failed. It's pretty common.
    Buckaroo and Ruggybuggy like this.
  3. Mar 23, 2024 at 4:56 PM
    JMcMusicman
    JMcMusicman New Member
    Did you ever find a solution here? Having the same issue with my 01... Tried replacing the after market converter box but still no joy...?
