2001 Tundra Cab swap 5vz to 2uz
Discussion in '1st Gen Tundras (2000-2006)' started by cob, Aug 15, 2020.
keep roll up windows or swap in the power
  1. roll up
    4 vote(s)
    22.2%
  2. power up
    14 vote(s)
    77.8%
  1. Aug 15, 2020 at 12:46 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    So hear is the story i bought a tundra (2001 sr5 v8 4x4 tundra access cab) about a year ago. The body is very rough but the frame had been replaced so i had no problems buying it. I always had plans to replace the box and do some body work in order to come out with a legit truck over time. But the more i had thought about it tho the more i realized that really i needed a full body swap. Id say that i put about 2500 or 3000 into fixing everything on the truck. I do know in a way it is alot to have in a beat up old truck but honestly i love it and its 100 percent mechanically. so about a month back i found a 2002 (base model v6 2wd) with a bad transmission but the body is 8/10. No rusty nonsence i was gonna have it be a project for the spring and i know i have made it hard on myself, as the cab isnt gonna be a direct swap but i paid 600 dollars. I have been asking questions and trying to prepare myself for this project cause i know i am in a bit over my head in a way. Hear is the crazy part a tree falls on my truck the other day not to happy about it but thats life right and i guess my project a gonna come a little sooner then expected.
    i guess i just need to start with a few questions and start to make a game plan:
    [2001 sr5 4x4 v8 access cab -- 2002 base model 4x2 v6 access cab (donor truck)]
    my main thing is wiring and hvac stuff is my best best to just strip both cabs and swap all of it or can i go about this in a different way or maybe i should call the scrap yard lol
    20200810_183403.jpg 20200725_104924.jpg 20200725_104914.jpg 20200725_104639.jpg 20190830_182929.jpg 20190829_190752.jpg
    Rex Kramer likes this.
  2. Aug 15, 2020 at 2:13 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Everything should fit in the doner Truck since they’re both AC bodies. I’m knee deep in rebuilding the frame on my AC Turd, but the body was actually very clean. Looks like you’re in the opposite position.
    If this were me, I’d Start dismantling the new cab and swap parts over as I remove them. Take your time, label EVERYTHING and take photos.
    And welcome to the club!
  3. Aug 15, 2020 at 6:50 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    can i leave the motor on the frame and just remove the cab or does the motor come out first
  4. Aug 15, 2020 at 6:51 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    and there is no special trick to the wiring like harnesses are the same in the cab or anything along them lines
  5. Aug 15, 2020 at 6:56 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    my plan was to strip the donor cab down and then install the parts from the orginal cab so i have a clean slate i figgure i can just remove the whole dash assembly and place it in the doner cab i think that is the big one but i am new to the tundra i dont really know the best ways to go about things
  6. Aug 15, 2020 at 6:56 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Leave the engine on the frame. Swap all the harnesses from the v8 truck to the V6 body.
    Darkness and N84434 like this.
  7. Aug 15, 2020 at 6:57 PM
    empty_lord
    05 rollover special
    The engine harness, engine bay harness, and interior harness (gauge cluster is also different because of the tach) it’s honestly a time consuming job, but not super hard.
  8. Aug 15, 2020 at 7:02 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    one thing i am thinking about is how to i go about my registration does the vin number go with the frame or the body i live in new york i think i might need a salvage inspection i dont have a branded title but i guess that would be the case where stuff like that is done
  9. Aug 15, 2020 at 7:03 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    i believe they both have tachs
  10. Aug 15, 2020 at 7:03 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    yeah the clusters look the same
  11. Aug 15, 2020 at 7:06 PM
    empty_lord
    05 rollover special
    The v6 cluster will not read the right rpm because the signals different.
    vin follows the body. So registering it as a V6 will be what happens. Actually may save you on insurance
    torino69 and Darkness like this.
  12. Aug 15, 2020 at 7:13 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    interior harness probly has more then one part right or is the wiring in the dashboard called something else i guess i am trying too get an idea of how the harnesses are layed out
  13. Aug 15, 2020 at 7:14 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    would swaping the dashboards as a unit be the method that id wanna take
  14. Aug 15, 2020 at 7:14 PM
    empty_lord
    05 rollover special
    It’s pretty much one harness in the dash. Then you have a floor harness. Engine bay harness has the exterior fuse box. Engine harness can stay on the frame. Frame rear harness stays on frame too
  15. Aug 15, 2020 at 7:15 PM
    empty_lord
    05 rollover special
    Not easy. Just pull the dash (not too hard) and the harness comes out realitivly easy. I’ve had my own dash out twice. You may need some new clips, but they can be had.
    N84434 likes this.
  16. Aug 16, 2020 at 7:17 AM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    would i be able to use the heater box and ac stuff from the v6 dash
  17. Aug 16, 2020 at 8:30 AM
    empty_lord
    05 rollover special
    That should be fine
  18. Oct 20, 2020 at 11:44 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    20201014_142731.jpg 20201014_152355.jpg 20201014_152410.jpg 20201015_004304.jpg 20201015_004306.jpg
    So i just started the tundra project a few days ago we cut up the roof and got it so we could drive the truck again. Then we removed the box and removed some parts like radiator and interior bits but i am just looking for a bit of direction on how i should go about removing the cab
  19. Oct 20, 2020 at 11:46 PM
    empty_lord
    05 rollover special
    engine harness stays on engine, unplug by the ecu behind the glove box and route out of way, remove brake lines from body to frame, unplug frame harness from under driver seat, and all the evap lines that connect to body stuff.. and you should be able to lift the body off (oh and the steering shaft) its really easy since youve got a lift to pull the body.
    Darkness likes this.
  20. Nov 3, 2020 at 6:45 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    made a bit of progress with the truck the actual process is simple. there are just a few extra things that empty didnt list like ebrake cables and transmission cooler lines........rust is terrible !!
    bmf4069, Darkness, speedtre and 4 others like this.
  21. Nov 3, 2020 at 7:24 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    few more pictures gonna pull the cab off the purple truck next
    shifty`, bmf4069, speedtre and 2 others like this.
  22. Nov 3, 2020 at 8:28 PM
    empty_lord
    05 rollover special
    Hmm, I did seem to space those out, but you figured it out! Good progress
  23. Nov 4, 2020 at 5:04 AM
    Professional Hand Model
    Hand Protectors
  24. Nov 4, 2020 at 9:43 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    did some reconsideration and we are going to strip this cab before we start removing the cab from the donor truck
  25. Nov 4, 2020 at 9:48 PM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    little progress removed brake lines and evap from the cab starting to remove the wiring harnesses i believe i need too just swap all the wiring harrnesses in the cab with the v8 stuff just trying to get a grasp of how it all goes together
    bmf4069 and Darkness like this.
  26. Nov 7, 2020 at 3:06 AM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    cut the old cab up to make it easier as we dont have alot of room pulled the donor truck in
  27. Nov 7, 2020 at 3:46 AM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    i think this has been alot easier then i thought it would be only about 15 hours to get too this point and we spend half of the time fighting rust i am gonna be getting plates next week and maybe we can be rolling in a week or two i am not stressing over every little thing as thats how projects take years just wanna get my truck back
    bmf4069 and empty_lord like this.
  28. Nov 7, 2020 at 3:49 AM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    i need too get a new setup for body mounts do u guys have any suggestions i didnt seem to find anything aftermarket but i was only looking on rock auto i was also wondering if any dealer techs knew about how much the brake lines go for that are used for a frame swap id dont wanna bend for hours idk if there are an abundace of parts from that stuff but i did see u could buy a frame for 2500 new so maybe them brake lines are under 100 lol
  29. Nov 7, 2020 at 3:57 AM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    i have access to alldata but i got a subciption for a few days to tis. as i have some cut wires and its just confusing the way alldata is setup for this thing. is there anyway i can just print whole sections as id rather not spend hours organizing pdfs
  30. Nov 9, 2020 at 8:25 AM
    cob
    cob [OP] New Member
    Bob
    few 1st gen tundras
    worked on the donor cab yesterday got it off and started to strip out the harrnesses i gotta clean up a few spots on the cab because of rust but for upstate new york i cant ask for much better
    MS22, shifty`, bmf4069 and 3 others like this.
