2001 Toyota Tundra SR5 Break help please
Discussion in 'General Tundra Discussion' started by johnnyshoney, Aug 7, 2021.
  1. Aug 7, 2021 at 2:57 PM
    johnnyshoney
    johnnyshoney [OP] New Member
    The breaks go down slowly but will pump up sometimes they go to the floor just idling but when you pump them they are good. They have been bled but just can't get the last little bit of air out. What could be causing this? Thanks
    YardBird likes this.
  2. Aug 7, 2021 at 5:56 PM
    If you are sitting at a light and holding your foot on the brake, it randomly goes to the floor? I'm wondering if the vacuum booster is starting to go out due to a vacuum leak.
  3. Aug 7, 2021 at 7:17 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Has anything been replaced recently? Sounds like air in the system. Some components are a bi*ch to bleed.
  4. Aug 7, 2021 at 7:27 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I had the same issue with a Brand X truck many years ago ~ the master cylinder was leaking internally.
    ATV25 likes this.
  5. Aug 7, 2021 at 7:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    either a master, or its not fully bled, has the rear portioning valve been bled? to properly bleed these trucks you need to pop the bleeder on the LSPV on the frame that the rod on the axle attaches to. then bleed the wheel cylinders
  6. Aug 8, 2021 at 12:27 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Make sure the rear brakes are adjusted before bleeding.
    Although it sounds like possible failing master cylinder or vacuum booster.
