2001 Rear End Swap
Discussion in '1st Gen Tundras (2000-2006)' started by Deverett5, May 12, 2020.
  1. May 12, 2020 at 10:50 AM
    Deverett5
    Deverett5 [OP] New Member
    Dakota
    Hey everyone im new to this page and looking for some help. I have a 2001 Tundra SR5 Access Cab V8 4X4. I pretty sure I have 3.91 gears in the rear. Would I be able to run any other type of gears without damaging the truck? Also what year could I go up to and swap the whole axle assembly? Was under the impression I could go all the way up to 06.
  2. May 12, 2020 at 11:04 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    A few on here have swapped in gears. Just gotta match the front and rear. You can go up to an 06 for a swap.
    What are you wanting gears and/or a new axle for?
    BestGen likes this.
  3. May 12, 2020 at 11:33 AM
    Deverett5
    Dakota
    I had my rear go out of my truck last week. was wondering if any other gears besides 3.91 would damage my transfer case. I just called a a shop and he said that i could only go up to and 04 axle assembly. Apparently an 05 and 06 axle assembly wont bolt up in my 01? according to him
  4. May 12, 2020 at 11:46 AM
    BestGen
    BestGen Free Kyle!
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    The only way it's going to damage the t/c is if you don't match your front and rear gear ratios. If you have 3.91s then you absolutely must keep 3.91s in the rear axle. Mismatched gearing will definitely destroy your transfer case.
  5. May 12, 2020 at 4:54 PM
    bmf4069
    TX
    02 AC sr5 4wd v8
    Afaik all axles are the same.
  6. May 12, 2020 at 5:08 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    You can use any first gen tundra axle housing, however, there are 3 different style companion flanges on the 3rd members. 00-04 uses a 60x60 flange and the 05-06 uses a 66x66 flange. Don’t quote me on this, but I believe there is also an oddball flange they used on sequoias and some tundras where the studs are pressed into the flange and the nuts go on from the front side. Also, you must use 3.91 unless you’re gonna change front and back gears.
  7. May 12, 2020 at 5:19 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Change them all to 4.56 and you'll be happier
    :devil:
  8. May 12, 2020 at 6:04 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Something I almost forgot, some of the older tundras didn’t come with abs. Just something to consider if you’re searching for the whole assembly.
  9. May 13, 2020 at 3:44 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Also, be advised Double Cab axles are a different width than Standard Cab/Access Cab.
  10. May 13, 2020 at 8:52 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Thanks for bringing this up. Curious, how much wider are the crew cab axles?
  11. May 13, 2020 at 8:56 AM
    tvpierce
    Maine
    Paging @Mytechguyri
    I know he ended up with the wrong one for his truck. He might have the details.
  12. May 13, 2020 at 5:04 PM
    Deverett5
    Dakota
    Thank you everyone for your input. Still on the search for a rear. So for what I gathered and interpreted form everything, I need to match my t/c and get 3.91 gears if that what was in my truck which Im pretty sure it was and only a 00-04 rear will will bolt up correctly? I have ABS so I also have to get a rear with that as well? I think I got it haha thank you all again for the information this is a very helpful page to be a part of.
  13. May 14, 2020 at 3:25 AM
    tvpierce
    Maine
    To be clear, you don't need to match the gearing in your transfer case, you need to match the gearing in your front differential. If your front and rear axles have different gear ratios, they'll be spinning at different speeds when in 4WD.
    And you cannot use an axle from a double cab.
  14. May 22, 2020 at 9:00 AM
    Deverett5
    Dakota
    I was able to track down a rear end close by but would a rear from a 2003 tundra with ABS be able go into a 2001 tundra that doesn't have ABS has the same gears and everything? I don't see why it wouldn't.
  15. Jun 9, 2020 at 1:11 PM
    SumDooD
    SumDooD New Member
    06 Tundra SR5
    Non....yet, that's why I'm here!
    Hi I'm new here as well and this thread is as close to my question as I can find. Not trying to hijack this one by any means, mods.ease feel free to move this if needed.
    I have a 2006 SR5 and want to swap my whole rear end for a TRD set up to get rid of the drums and have rear disks, can i just straight up swap in a used 06 TRD rear from my local pick and pull with no real issue?
  16. Jun 9, 2020 at 4:33 PM
    bmf4069
    TX
    02 AC sr5 4wd v8
    An 06 trd have drums too. Unless you're talking about a sequoia, which would involve a lot of fab work.
  17. Jun 9, 2020 at 9:23 PM
    Deverett5
    Dakota
    What are the other numbers that are stamped on the ring? Do they have a significant meaning when swapping them?
  18. Jun 9, 2020 at 9:40 PM
    bmf4069
    TX
    02 AC sr5 4wd v8
    Build date followed by ratio?
    YardBird likes this.
