2000 Tundra Front Strut Recommendations
Discussion in 'Suspension' started by omega1349, Feb 22, 2023.
  1. Feb 22, 2023 at 5:01 AM
    omega1349
    omega1349 [OP] New Member
    Omar
    2000 Tundra SR5 Access Cab 4.7L
    Body restoration/Painting
    Greetings,
    I recently replaced the rear shocks on my 2000 Tundra with Bilstein 4600's. Now I'm looking at replacing the front struts. The truck is 2WD. I'd like to go with a quick strut for ease of installation.
    I've come across Duralast, TQR, Monroe, FCS....
    What would you all recommend?
    Thanks in advance for your input.
  2. Dec 11, 2023 at 11:55 AM
    cody c
    cody c New Member
    cody
    blue 2006 tundra double cab 4x4
    retractable fog lights, dry box mounted winch
    What shock did you end up running and how do you like it's performance?
  3. Dec 11, 2023 at 12:17 PM
    I would not, could not recommend any of the quick strut options. The spring and shock that come together are both usually sub-par offerings. Best bet would be the 4600 with a factory spring. But budgets are real and I understand the need to save a few bucks. This is one of those things you save a little and end up regretting it everytime you drive your truck.
