2000 toyota tundra squeaking noise front suspension
Discussion in 'Suspension' started by carrillo4115, May 8, 2017.
  1. May 8, 2017 at 11:09 AM
    carrillo4115
    carrillo4115 [OP] New Member
    2000 toyota tundra sr5
    none
    hey everyone name is Alejandro Carrillo I'm new on the forum I know very little on tundra 1st gen I actually have a problem with my front suspension making some squeaking noise sounds like it come from the front it only squeaks when I go over some bumps I wanna put a leveling kit on but I wanna get this problem solved first can anyone help me determine on what it can be?
  2. May 8, 2017 at 11:14 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    How do your sway bar bushings look?
    Shoot me a message anytime if you have any questions!
    -David
    NewImprovedRon likes this.
  3. May 8, 2017 at 11:18 AM
    carrillo4115
    none
    they look good actually
  4. May 8, 2017 at 11:27 AM
    Mike Tread lightly.
    south carolina
    Just because they look good means jack. The interior of them could be shot. Reason for the noise is out of grease on bolts or on the bushing surface.
  5. May 8, 2017 at 1:31 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    upper and lower control arms bushings could be shot too along with the coil spring mounting pads. These all use carbon rubber and dry out over time.
    and welcome :)
  6. May 8, 2017 at 1:58 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  7. May 10, 2017 at 11:41 AM
    kelly32327
    kelly32327 New Member
    chris
    wakulla springs fl
    2001 tundra trd
    wheeles & tires
    more than likely lowers did the same thing with mine
