20” OEM wheels, Michelin tires (Austin tx)
Discussion in 'Marketplace - Wheels & Tires' started by teedubbya, Oct 9, 2018.
  1. Oct 9, 2018 at 5:55 PM
    teedubbya
    teedubbya [OP] I like fat booty
    Austin TX
    SOLD SOLD SOLD
    ff of 2013 lone star edition. The wheels show their age but are structurally sound.
    The tires are Michelin defender ltx m/s with tons of life left. 275/55/20. These just came off the truck and have not been sitting. No sensors.
  2. Oct 9, 2018 at 6:24 PM
    Pudge
    Pudge Sap Wizard
    CT
    2015 Blue Ribbon Platinum
    TRD PRO grille, OCD consol organizers, DIY wireless phone charger, 33" Michelin Defender LTX MS, Bak revolver X2 tonneau, weathertech liners, 20% tints. DIY pop n lock, 2018 LED headlights, morimoto fogs, TRD shift knob
    Those are really good tires for anyone looking for a set of winter or long distance trip tires. Great deal!
  3. Oct 9, 2018 at 6:39 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Our of curiosity, what are the blemishes on the tires?
  4. Oct 9, 2018 at 7:07 PM
    teedubbya
    Austin TX
    Stuff like this. Just aging of chrome. May be able to polish them with decent results. Some curb rash as well.
  5. Oct 9, 2018 at 8:27 PM
    Pudge
    Pudge Sap Wizard
    CT
    Tires alone are worth it, even if half worn they'll go another 30k. Would be nice for someone running MT or AT if they are taking a long highway drive or need winter tire. As for the wheels maybe a good polish would do it, paint or powder coat is fairly cheap. GLWS
  6. Oct 19, 2018 at 5:55 PM
    teedubbya
    Austin TX
    Dropping these down to 350. Need them out of the garage.
  7. Oct 22, 2018 at 3:46 PM
    teedubbya
    Austin TX
    Down the $300. Need the garage space
  8. Oct 22, 2018 at 5:09 PM
    Semperfella73
    Semperfella73 New Member
    I want them for $300 right? I am in Ohio working. Have to check shipping costs
  9. Oct 22, 2018 at 5:11 PM
    teedubbya
    Austin TX
    Shipping would be well over $200. And a lot of hassle. Sorry.
  10. Oct 22, 2018 at 5:26 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    corsa, coilovers, methods, toyos
    teedubbya
    Nice shark btw I have the black 2018 RGS, glws
  11. Oct 22, 2018 at 5:55 PM
    Semperfella73
    Ok thanks for the reply
  12. Oct 23, 2018 at 8:57 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Actually it is the clear coat on the wheels breaking down. The exact same wheels on my 2013 did/are doing the same thing and most of the other Texas Edition Tundras with that wheel package, local to me, are exhibiting the same issue. You can scrape off the failed clear coat with your finger nails or a plastic/nylon panel remover in the really bad places. Simple solution is to remove the remaining clear coat and polish the now bare aluminum (Mothers or similar polishing ball/wheel/pad) and putting some kind of protectorate on them as needed to keep the corrosion away. These are 20" "diamond cut" so you'll still get a bit of refracted light and it won't look too much like chrome.
    Good price for them so someone needs to snap them up!
    B
  13. Mar 14, 2019 at 8:25 AM
    LiftMeUp
    LiftMeUp New Member
    I have same wheels as well and same problem. Craziest thing, can scrap off easily with fingernail but can't seem to get off any other way. Glad I came across your post. Have you had any luck and if so, what products, ways? Thanks!!
  14. Mar 14, 2019 at 10:20 AM
    bvia
    bvia New Member
    None
    I machined a .5 derlin block into a scraper with a 45 degree angle, rounded the edges and just went to town one weekend. The derlin is hard enough to scrape the cc off, but softer than the aluminum. See if your SO has a hard plastic pan scraper and commandeer it for the cause!
    I'd bet that Easy-off (the stinky version) would work also as would acetone, but try it one a small spot first!
    B
    aRabidLunatic likes this.
  15. Mar 15, 2019 at 6:51 AM
    LiftMeUp
    LiftMeUp New Member
    Didn't think of that. Will have to give them a try! Thanks.
