2.5" Lift Tire Size???
Discussion in 'Wheels & Tires' started by Brady494, Sep 7, 2016.
  1. Sep 7, 2016 at 12:50 PM
    Brady494
    Brady494 [OP] New Member
    I have a ready lift 2.5" front kit. Can I fit 305/65/18 with out cutting the body mount?? What offset do i need?? What tire do you think will be best! I love the look of the tire sticking out from the body to where you need flares but i just don't know what size to get!
  2. Sep 7, 2016 at 12:59 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    18 offset should do it but you may still need to do a little trimming just because of the width.
    I'd be prepared for paint dings and scratches if you want them to stick out that far.
  3. Sep 7, 2016 at 1:12 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Welcome to the forum
  4. Sep 7, 2016 at 1:40 PM
    purpdust
    purpdust New Member
    2015 Tundra CM Platinum
    OME 2.5" Suspension ARB Front Bumper w/ Warn Winch ARB Air Lock Diff Rear
    I have 295/65R18 Duratracs on mine, it has @2.5inch lift, only seen slight rubbing on front inside mud flaps.
    At the time I got them I was told if I went bigger, cutting or a higher lift would have been required.
  5. Sep 7, 2016 at 1:43 PM
    Brady494
    So do i want a number higher or lower then 18 if i am having trouble finding rims i like with an 18 offset
  6. Sep 7, 2016 at 1:46 PM
    Brady494
    That is great information to know!!
  7. Sep 7, 2016 at 1:48 PM
    purpdust
    purpdust New Member
    Mine are -12 offset
  8. Sep 7, 2016 at 1:49 PM
    Brady494
    What kind of rims do you have on yours?
  9. Sep 7, 2016 at 2:00 PM
    purpdust
    purpdust New Member
    Fuel Revolver
  10. Sep 7, 2016 at 2:01 PM
    purpdust
    purpdust New Member
    The one added bonus is I bought a 5th wheel and tire for a spare and it fits in the Spare Tire Holder. Although it is a tight fit :)
  11. Sep 7, 2016 at 2:06 PM
    TheBeast The Beach
    check method wheels. i was running 305/60/18 with +18 offset and just leveling kit.
    Now I run 33"s and it's still ok
  12. Sep 7, 2016 at 2:09 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Black rhino has some nice selections also
  13. Sep 7, 2016 at 2:21 PM
    chphilo
    chphilo Tundra addict
    Western PA
    OP, are you interested in pocket style fender flares or OEM type (smooth type without rivets)?
  14. Sep 8, 2016 at 7:17 AM
    Brady494
    I really like the bolted look!
  15. Sep 8, 2016 at 7:17 PM
    chphilo
    Western PA
    If you want pocket style fender flares, 18 mm offset is a good compromise so you won't have to cut your truck and still look good.
