  1. Jan 6, 2026 at 3:38 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Don’t recommend trying these stupid paint pens they suck. Was trying to get more paint and it just exploded. I’m going to peel/clean it off tomorrow and wait for AT3’s with white letters.
    oscardog86 and BroHon[QUOTED] like this.
  2. Jan 6, 2026 at 3:49 PM
    Upshot Knothole
    Upshot Knothole This space for rent.
    In a van, down by the river. PNW
    2003 SR5 V8 AC TRD 4x4
    Gotta commit and make them white walls now.
  3. Jan 6, 2026 at 4:09 PM
    455h0le_dachshund
    455h0le_dachshund NO MASTERS, NO CHAINS
    Coastal TX
    Penelope & Elvira
    I don't really consider myself an overlander, but maybe somewhere between that and crawler. I do sleep in the truck bed.:D
  4. Jan 6, 2026 at 4:11 PM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    So which came first, Boondocking or Overlanding?
  5. Jan 6, 2026 at 4:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Or galavanting
  6. Jan 6, 2026 at 4:15 PM
    Casper421
    In the woods
    06 DC
    Your truck is telling you it doesn’t want white letters out…it’s a smart truck.
  7. Jan 6, 2026 at 4:18 PM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    You need to prep yourself to sawzall off those rear shocks. You’d be in the first gen hall of fame if you get that top shock mount in the rear to bust loose.
    It’s scary at first but once you get going it isn’t too bad. Just don’t cut into your frame or wiring.
    bmf4069 and Steve4X42002[QUOTED] like this.
  8. Jan 6, 2026 at 4:23 PM
    shifty` Got patience on my neck like a cold, cold knife
    Using your old springs? If your old shocks are OEM, you'll need to move the tophat and rubber isolator over with the springs.
  9. Jan 6, 2026 at 4:24 PM
    It may work? But the traditional "cat cleaners" you buy at the store are bullshit.
    TXTundraGuy23[QUOTED] likes this.
  10. Jan 6, 2026 at 4:28 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    2004 AC 2wd to 4wd conversion ABS delete
    EDIT: I just remembered that i did reinstall those cats, but i don’t remember if i kept them installed or used my other set. I completely forgot about the epic cloud of smoke that comprised of burning residual oil, boiling water steam, and a tantalizing smell of grape drink…i mean purple power. It took a while for those cats to dry out, so the steam cloud lasted for quite some time!
  11. Jan 6, 2026 at 4:32 PM
    Upshot Knothole
    I was prepared to cut mine off, but they came free with a ratcheting wrench. I still think it's best to plan to have to cut them off and be pleasantly surprised if you don't.
  12. Jan 6, 2026 at 4:32 PM
    whodatschrome
    We don’t salt our roads, so pretty much every west coast tundra would make it in the 1st gen hall of fame with having easy to loosen upper shock nuts.
    oscardog86, BroHon, bmf4069 and 3 others like this.
  13. Jan 6, 2026 at 4:50 PM
    Steve4X42002
    Steve4X42002 New Member
    Minnesota
    2002 Tundra Limited Access Cab 4x4 V8
    OEM shock and springs, is moving the tophat and isolator over an issue or should it be fine to reuse them?
  14. Jan 6, 2026 at 4:56 PM
    You can walk out to your truck right now and visually inspect your rubber isolator to make sure it's not cracking/warped/missing. It's this rubber bit, red arrow is pointing at its bottom edge, and the metal "tophat" is the little sliver that blue arrow points at:
  15. Jan 6, 2026 at 5:05 PM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    I would guess overlanding, like Willys Overland. But then again, V8 cars could've been hauling camper trailers before that maybe? :notsure:
    Or
  16. Jan 6, 2026 at 5:15 PM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    I'd say it's a toss up in TX.
    If you're not from the coast or NTX, they usually come out fine. My 06 rears had to be cut off. My 03 rears came right off, no problemo.
    FrenchToasty likes this.
  17. Jan 6, 2026 at 5:52 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
    That's a lot of trailer for that old 53 Chevy stovebolt 6 to be haulin. Keep in mind that was long before they started building modern lightweight trailers.
  18. Jan 6, 2026 at 5:57 PM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Reminds me of The Long Long Trailer with I Love Lucy.
    I had that one on tape back in the day.
    whodatschrome and G_unit3000 like this.
  19. Jan 6, 2026 at 6:15 PM
    Jack McCarthy
    Bill
    North of Boston
    Unless you clamp the shock shaft that’s never going to happen in the rust belt without maybe cutting a slit in the nut with a dremel to help loosen that rust bond. I lifted my bed 3” on each side by loosening the belt bolts before sawzalling the top nut off.
  20. Jan 6, 2026 at 8:03 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Yeah based on my lack of rust, I thought it’d be a cake walk. Boy was I wrong.
    oscardog86 likes this.
  21. Jan 7, 2026 at 4:05 AM
    bmf4069
    bmf4069 Scored 4 touchdowns vs Andrew Johnson High School
    Beau
    TX
    02 AC sr5 4wd v8
    Mine fell off with a stern look from @Sirfive.
  22. Jan 7, 2026 at 4:53 AM
    Sirfive
    Sirfive Socially feral
    SATX
    Roxanne
    Bassani cat-back
    So did mine.
    bmf4069 and 455h0le_dachshund like this.
  23. Jan 7, 2026 at 2:35 PM
    MI_Treetaco
    MI_Treetaco New Member
    06 Farm Truck
    JakeJake[QUOTED] likes this.
  24. Jan 7, 2026 at 2:38 PM
    AZBoatHauler
    So.Arizona
    Sequoia is throwing some codes - anyone familiar with P0037?
    Google is telling me bank 1 downstream O2 sensor... does that sound right?
  25. Jan 7, 2026 at 2:40 PM
    MI_Treetaco
    06 Farm Truck
    I was looking at the eastwood kit and it looks nice but it's outside my price range right now. I had probably 10k in logs on the back of my isuzu and blew a brake line pulling into the barn for the night. Ended up just grabbing a pre-flared line with fittings that was close enough to the right length and bending it up the next day.
    whodatschrome[QUOTED] likes this.
  26. Jan 7, 2026 at 2:42 PM
    MI_Treetaco
    06 Farm Truck
    Thank you, that's good info to save. Also, I have to put effort into figuring out multi quote.
  27. Jan 7, 2026 at 2:42 PM
    Id be more worried about the camshaft sensor codes. But heater circuit on the O2 sensor will only affect startup cold weather performance of the O2 sensors. The vehicle initially runs open loop, then within a couple minutes (the heater gets the O2 sensor up to temp for readings) it switches to the O2 sensor info. Bank 1 sensor 2 should be drivers side rear O2 sensor. I would replace that sensor with Denso plug and play. The cam position sensor a new code? Could be the wire harness that runs down the front of the motor got misrouted and is getting eaten by the belt, or a faulty sensor. Replace with OEM only here too.
  28. Jan 7, 2026 at 2:45 PM
    AZBoatHauler
    So.Arizona
    Im pretty sure the cam position code is from when the battery died - truck has been starting and running just fine and those codes aren't showing current or pending.
    KNABORES[QUOTED] likes this.
  29. Jan 7, 2026 at 2:59 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I know I made a bunch of tire/wheels posts but some acetone took off the tire paint I used. Then I saw I had an old can of maxima sc1 (moto guys will know). So I sprayed it on my wheels and tires and it came out really good.
  30. Jan 7, 2026 at 4:13 PM
    whodatschrome
    Fare enough. I bought the tool a few years ago in a black friday sale, so it costed a bit less back then. I also usually have vehicle projects on the back burner that require all new brake lines, so i made actual cents for me to buy it.
    MI_Treetaco[QUOTED] and BroHon like this.
