  1. Jan 2, 2026 at 9:51 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Is that a C-130 reflecting in the hangar door glass?
    des2mtn likes this.
  2. Jan 2, 2026 at 10:14 AM
    des2mtn
    des2mtn Barf me out, gag me with a spoon!
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    shifty` and Casper421 like this.
  3. Jan 2, 2026 at 10:19 AM
    Casper421
    In the woods
    06 DC
    3 in the hanger along with a few S2’s
  4. Jan 2, 2026 at 1:40 PM
    shifty` Got patience on my neck like a cold, cold knife
    BroHon[QUOTED] likes this.
  5. Jan 2, 2026 at 1:44 PM
    bing5
    bing5 Fight the powah
    New Mexico
    2004 DC SR5 4WD V8
    Would someone mind double checking me on a part? I'm looking for the little plastic clips into which the plastic "push pins" on the door panel sides seat. Per epc-data, looks like 90467-09122, but that doesn't seem to jibe when trying to order it. Thanks
    p.s. Also need to replace vapor barrier if anyone has a genius idea. I'm probably overthinking it.
  6. Jan 2, 2026 at 3:01 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    What do we think of white tire paint for the letters in Mickey Thompson Baja ATs? I bought some not sure if I’ll use it but kind of want to add a little contrast between my wheels/tires
  7. Jan 2, 2026 at 3:02 PM
    I'm a white letter fan. I like the outlined white letters better than the solid, but the BFGs looked good in solid too. You'll have to do it, then post it up for opinions. I've thought about doing mine.
    KTM_AJ421[QUOTED] likes this.
  8. Jan 2, 2026 at 3:18 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I like the outline better too I’m just a bit wary of my drawing skills/steady hand it will look like I wrote it myself lol
    BroHon and KNABORES[QUOTED] like this.
  9. Jan 2, 2026 at 3:23 PM
    Same
  10. Jan 2, 2026 at 3:53 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Couple 3 drinks and the hand will steady right up :burp: :rofl:
    I am team white letters OUT. N/A on my new tires :(
  11. Jan 2, 2026 at 6:17 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You'll need a scan tool that can bleed the ABS pump and a master cylinder bleeder kit (LINK) . Bleeder kit is easy and cheap, if you don't already have the scanner that could be an expense.
    Maybe you could get away without the ABS bleed, I don't remember there being much air at all at the wheels, I just made sure to bleed the master really well before hooking up the lines.
    As I stated before, my car still does it every once in a while (every couple months maybe) but not as bad as before. It had done it off and on as long as I had owned the car but then got to doing it nearly every time I pressed the brakes.
    FirstGenVol[QUOTED] likes this.
  12. Jan 2, 2026 at 6:21 PM
    Don't think there's a scan tool that will do that for these trucks.
  13. Jan 2, 2026 at 6:22 PM
    NickB_01TRD
    Nick
    KY
    FirstGenVol and KNABORES[QUOTED] like this.
  14. Jan 2, 2026 at 6:27 PM
    NickB_01TRD[QUOTED] likes this.
  15. Jan 2, 2026 at 6:43 PM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    The one I recently bought has that feature and I can read the ABS controller. I don’t have ABS though.
    Edit: I might be wrong. It may just have an ABS reset and not a bleed feature.
  16. Jan 2, 2026 at 9:37 PM
    bing5
    New Mexico
    2004 DC SR5 4WD V8
    Would someone point me to an old thread on whether or not to drain and fill a 250k plus transmission that's never been serviced? Know it's been beat to death....
    Mine is at 275k and the CCN has me spooked....
  17. Jan 3, 2026 at 4:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I already have a bleeder kit from when I replaced the master cylinder on my truck. Thinking it should work for the RAV4 too. I'm hoping I can get away without having to mess with the ABS.
    When you bled your system, did you go around all 4 wheels or just the front? Typically when I've done work up front, it's been a waste of time and fluid to bleed the rear wheels. Air isn't traveling back there.
  18. Jan 3, 2026 at 6:21 AM
    Jack McCarthy
    Bill
    North of Boston
    Why not just drain 1/2 pint to send to Blackstone Labs for analysis? Usually it’s only an issue if you have a significant amount of clutch material suspended in the fluid preventing the inevitable slipping of the transmission.
  19. Jan 3, 2026 at 6:50 AM
    NickB_01TRD
    Nick
    KY
    I did all 4 with the ABS bleed. If I followed my scan tools instructions it wanted to bleed each wheel at least 4 times or more. I did each wheel a couple times but I really don't remember there being much air anywhere.
    I bench bled the master on the car, seems easier and the car can hold the master better than a vise. I watch a lot of videos of people working on old cars that have been sitting around and they usually emphasize varying the stroke length while bleeding the master, so I tried to do this the best I can (short and long pedal strokes). It's supposed to make sure you get all the air out of the front and rear ports of the master.
  20. Jan 3, 2026 at 8:15 AM
    No. It’s been beaten to death. Don’t even want to rehash that shit.
    tl;dr - If you’re not confident with a complete fluid flush, drain and fill is totally safe.
    455h0le_dachshund likes this.
  21. Jan 3, 2026 at 11:36 AM
    bmf4069
    bmf4069 Scored 4 touchdowns vs Andrew Johnson High School
    Beau
    TX
    02 AC sr5 4wd v8
    Attention rust belt homies:
  22. Jan 3, 2026 at 12:03 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Would it be stupid or brilliant to get the same color truck? Fawk...
  23. Jan 3, 2026 at 12:03 PM
    bing5
    New Mexico
    2004 DC SR5 4WD V8
    Fair enough
  24. Jan 3, 2026 at 12:11 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    My truck 288k when purchased/previous maintenance unknown (I think it was used for plowing snow actually)/2 drain and fills/10k miles/no problems.
    I did dump a whole bottle of Lucas in with the first (and maybe second) drain and fill.
  25. Jan 3, 2026 at 12:12 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Body parts interchange better...
  26. Jan 3, 2026 at 12:19 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Well there isn't a body panel on my current white barnacle that I would put on that truck.
    And that's about the only advantage to having the same color :rofl:
    Nice thing is NO clearcoat to peal on it.
    The dude "knows what he has" though :cool:
    EDIT: I do have the white SnugTop topper though:monocle:
  27. Jan 3, 2026 at 12:27 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Never say never... but I hear ya.
  28. Jan 3, 2026 at 1:03 PM
    bing5
    New Mexico
    2004 DC SR5 4WD V8
    Did you use third-party crush washers? $2 or more for a damn washer seems a little nuts.
  29. Jan 3, 2026 at 1:10 PM
    Jack McCarthy
    Bill
    North of Boston
    Brilliant. One will be a backup parts truck.
  30. Jan 3, 2026 at 1:25 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    fuck that washer bullshit, I just put it back on. :crapstorm:
    If she drips, I'll address it then. Hasn't happened yet.
