  1. Oct 31, 2025 at 9:56 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    In town now, got a couple taps and 5mm bits, and new bolts m6 x 1.o x 25mm. Flanged same size, but 8mm (EDIT: 8mm hex heads). It'll do donkey, it'll do.
    Got a pilot hole all the way through so close to center I can't tell if it's off. Worse case it becomes a 1/4 × 20 :rofl:, and plan C will be a nut on the bottom :burp:
  2. Oct 31, 2025 at 9:57 AM
    Upshot Knothole
    Upshot Knothole This space for rent.
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
  3. Oct 31, 2025 at 9:58 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  4. Oct 31, 2025 at 9:58 AM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    A little trick I learned if you have the patience is to spray penetrant at the valve cover screws after a long drive. Mine come out easy peasy after spraying them 10 times while hot.
    A little late for that idea I suppose though.
    G_unit3000, shifty`, jstone88 and 3 others like this.
  5. Oct 31, 2025 at 10:02 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Right, I had another stubborn one I had to ease in and out 20-30 times, no problem. Then this one I was proceeding the same and I barely got going and SNAP. Someone had mangled it prior to me and it was on its last leg. Appears original seals. Plug tube seals Def never been touched, tangs are pristine.
  6. Oct 31, 2025 at 10:04 AM
    Jack McCarthy
    Bill
    North of Boston
    They probably twisted the bolt head enough to say “ that’s enough for me; I give up”.
    BroHon[QUOTED] likes this.
  7. Oct 31, 2025 at 10:09 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    It going to make me earn it. But we salty boys know this going in.
    So I'm torn between blue thread lock, or antisieze.... what say the collective hive?
  8. Oct 31, 2025 at 10:11 AM
    Dakillacore
    Dakillacore Quantum Entanglement
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Candy cane it with one swirl blue thread lock and the other swirl antisieze
  9. Oct 31, 2025 at 10:28 AM
    Upshot Knothole
    Thatchery
    PDX OR
    I'd do antiseize, you'll see the oil leaking out if it starts coming loose.
  10. Oct 31, 2025 at 11:25 AM
    bmf4069
    bmf4069 Scored 4 touchdowns vs Andrew Johnson High School
    Beau
    TX
    02 AC sr5 4wd v8
    @FirstGenVol look at this dude. He's trying to take our mangling jobs.
  11. Oct 31, 2025 at 12:40 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Amateur. I could have done way more damage.
  12. Oct 31, 2025 at 1:37 PM
    Jack McCarthy
    Bill
    North of Boston
    Don’t dismiss him just yet. The mangling is only beginning…
  13. Oct 31, 2025 at 1:45 PM
    Neo
    Neo New Member
    Alabama
    (See Signature for Trucks Info)
    I seem to be playing whack-a-mole with fluid leaks. Got the front oil seal replaced during the summer and now it appears the radiator has a minor leak in some part of the upper hose fitting. I wiped off the driver side of the fan shroud and all around the radiator cap then ran a few errands. There is a small puddle of coolant (yellow arrow) in the little trough just under where the upper radiator hose connects to the radiator.
    You can also see where it has dripped all they way down to the oil filter. It's not obvious to me if it's the hose or the radiator fitting itself. Thinking of replacing the hose for grins and hoping that fixes it. Any suggestions?
    G_unit3000 likes this.
  14. Oct 31, 2025 at 1:57 PM
    Dakillacore
    Georgia
    It looks like a pretty tight fit and it looks like it shouldn't leak. I'd check to see if the plastic housing was cracked where the hose clamps on to it, if you don't have a split in the hose.
    JakeJake, Neo[QUOTED] and shifty` like this.
  15. Oct 31, 2025 at 2:48 PM
    Sirfive
    Sirfive Socially feral
    SATX
    Roxanne
    Bassani cat-back
  16. Oct 31, 2025 at 3:57 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I act snapped one of those when torquing it down. I'll get it out eventually.
  17. Oct 31, 2025 at 4:04 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    needed the laughs, but
    Look at this Manicas :bananadance:
    The 3rd bit right before the correct sized one felt like it lined right up and popped some of the broken bolts threads out on the way through.
    Tap felt a bit like it was chasing instead of cutting. Nice and easy slow roll.... no problems :rolleyes:
    75% of this job is scrape clean scrub wash. I'm not polishing them either, they were just filthy on the outside.
    Ran the shopvac beside my razor everywhere except some of the bottom portion
    Happy with the cleanness I see. Remember, I was a short tripper when I was working, and I had seen some booger snot in the fill cap b4.
    Ribcage needs a break...
  18. Oct 31, 2025 at 4:10 PM
    Jack McCarthy
    Bill
    North of Boston
    The real testimony to the engine will be mine when I get the covers off. Over 20 years of 5 mile drives to/from working in some of the coldest and crappiest weather around with 5k synthetic oil changes.
    jstone88, oscardog86, bmf4069 and 3 others like this.
  19. Oct 31, 2025 at 4:39 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    That's pretty cool, right in your shop!
    I noticed the dude is givin Minnie Pearl some props with his tag hanging from his hat :rofl:
  20. Oct 31, 2025 at 4:39 PM
    shifty` Do some sister twisters 'til the cows come home
    Great job. Engine looks awesome inside!
    Yup. Look forward to checking mine too.
  21. Oct 31, 2025 at 4:51 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Iknowright, I was cringing when I pulled the first one.
    Same with my coolant passages too, super clean. I switched it back to pink/or red from the green when I did the new rad, not sure if that helped it?
    I ran seafoam in the crank case 1 time, but it had to have been clean before that.
    Makes me pretty confident she can make it beyond 300k. I have put just shy of 10k on it myself.
    Technically I think it has 300K on it due to it having 265s on it when I got it. +3.6% distance traveled
    bmf4069 and Jack McCarthy like this.
  22. Oct 31, 2025 at 5:01 PM
    455h0le_dachshund
    455h0le_dachshund NO MASTERS, NO CHAINS
    Coastal TX
    Penelope & Elvira
    SFA 1st, supercharged 5vz 3rd, or V8 4th gen T4R only.
  23. Oct 31, 2025 at 5:04 PM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    I wonder when they finally started making these? I emailed about this years ago. I wish I had known, because I've have replaced all mine along with the body lift. Oh well.
  24. Oct 31, 2025 at 5:08 PM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Sounds like my front suspension on both trucks. Though it's worse on the 06, and it was serviced/swapped most recently. I've just learned to accept they're both race trucks now.
  25. Oct 31, 2025 at 6:57 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    you forgot to install the kelfords.
  26. Oct 31, 2025 at 7:03 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    I mean I didn’t say the tundra was going anywhere lol I’ll never get back what I have in it
  27. Oct 31, 2025 at 7:04 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I looked through the armor thread but does anyone know of anyone or any companies who make bumpers like this?
    oscardog86 and G_unit3000 like this.
  28. Oct 31, 2025 at 7:06 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    Fishninja built one like that.
    shifty`, Jack McCarthy and KNABORES like this.
  29. Nov 1, 2025 at 5:11 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    3/4 or FULL? :rofl:
    I don't know much about cams, but adding duration to to our motors must be tricky while keeping the piston and valve from having a rendezvous :bananadead:
    Sirfive[QUOTED] likes this.
  30. Nov 1, 2025 at 8:21 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    @KNABORES @shifty` and any other master pluggers, when a tire is repaired it’s either a plug or a patch, correct? Or is there a hybrid plug/patch? My spare is leaking thru a plug so I was going to try and pull or push the plug out and replug. Is there anything special I need to do? A buddy recommend double plugs with glue
