1st gen belt/ tensioner squeaking
Discussion in '1st Gen Tundras (2000-2006)' started by taranovich92, Jan 31, 2023.
  1. Jan 31, 2023 at 6:48 PM
    taranovich92
    taranovich92 [OP] 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Nitto TerraGrappler G3 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate, 333 Fab steering rack clamp.
    I've had my 03 tundra for about 8 years and somewhere on the front of the motor something has always squeaked but it's gotten way worse by now. It only makes noise on rainy / snowy days when there's a lot of moisture. It will cold start and about 20 seconds later it will squeak like hell. It will squeak less the more you drive it. But on days where it's dry outside, it won't squeak haha. I've done the timing belt, water pump, and serpentine belt not terribly long ago and it's just made noise the entire time I've had the truck. My buddy has an 05 double cab that does the same exact thing but not quite as loud. Does anyone else have this issue with the first gen? What the hell is squeaking??
  2. Jan 31, 2023 at 8:16 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    taranovich92[OP] likes this.
  3. Feb 1, 2023 at 5:40 AM
