1997 T100 Brake Booster??
Discussion in 'Other Toyota Vehicles' started by se3388, Aug 3, 2018.
  1. Aug 3, 2018 at 8:04 PM
    se3388
    se3388 [OP] New Member
    1997 Toyota T100 SR5 Ext. Cab 4x4, 2014 Tacoma Dbl Cab Short Bed 4x4 TRD Sport
    I think my brake booster is going out on my T100. It doesn't do it all the time but I can be sitting at a red light with my foot on the brake pedal and the pedal seems like it looses pressure (resistance) and goes down closer to the floor, when it does this sometimes it will roll slightly. There are no leaks on any of the wheel cylinders or any signs of leaks on or around the brake booster, the reservoir is full also. What say you guys?
    Steve..........
  2. Aug 3, 2018 at 8:13 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    When was the last time you bleeded your brake lines? Air in the lines can cause that.
  3. Aug 3, 2018 at 8:33 PM
    se3388
    Never bled the brakes, might have to check that out. Wouldn't that do it most of the time? This only happens about one out of four times I'm stopped.
    Steve...........
