'18-'19 LED HL's amber or no amber? What are you doing?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXRailRoadBandit73, Mar 21, 2019.
  1. Mar 21, 2019 at 7:08 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    As you all have seen, I just put some '19 all black housing TRD PRO LED HL'S on from @Headlight Revolution with their harness as well, I have a SR5 model, So I followed the video instructions on how to tap into fuse box and wire up, so with their harness and having to de-pin the 2 wires in the turn signal harness (I have 3 wire turn signal harness, thier video shows 2 wire), so the LED strips are bright all the time with HL's on too, BUT I also have amber DRL's on too, I was told how to delete the running amber, but I kinda like the look of them on too, FOR THOSE WHO PUT THE NEW LIGHTS ON AND RUNNING iHacker harness , ARE YOUR LED STRIPS WITH OR WITH OUT AMBERS???
  2. Mar 21, 2019 at 8:44 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    I went with keeping the amber on. I like the look of it.
  3. Mar 22, 2019 at 5:35 AM
    tundraty
    tundraty New Member
    Fort Worth, TX
    2022 Celestial Silver SR5 CM 4x4 TSS Off-Road
    I'm torn on this one myself. I don't actually have the new headlights yet but hope to pick up a set in the next few months. Been trying to decide which setup I like better myself. Both look freaking awesome IMO.
  4. Mar 22, 2019 at 6:38 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I kept them for a different look.
    [​IMG][​IMG]
    panicman, Sumo, CPdaddy and 5 others like this.
  5. Mar 22, 2019 at 6:46 AM
    I'm liking them too, IDK yet
    West Texas Tundra likes this.
  6. Mar 22, 2019 at 11:48 AM
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    No amber for me.
  7. Mar 22, 2019 at 1:01 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Headlight conversion still in progress (for about three weeks now?)...turning into a BFD. First I was keeping the ambers, then I wasn't, now I think I will (nice look @JeremyGSU, stock amber bulbs?).
    Some members here worry about the signals being visible with HR bright DRLS @ARamirez73. I started to worry about the signals being bright enough even with the dimmed DRLs (To Be Determined)...LED signals? Or no LED signals? Too much heat in the housings with aftermarket LED signals??? Burn up these expensive Yota housings? But..the LEDs I'm looking at, there is a low level (half the chips) and a high level power (all the chips). High level for signal, low level for DRL?
    I am not taking a chance on these high-dollar housings getting fryed. Bought me a cheepazz little infrared thermometer (I tol' ya...a BFD...a major f'n project). I'm going to measure the temps of the LED signal bulbs in the housing and compare stock to aftermarket LED. Maybe I should take pics before and after, videos before and after, etc. etc. :pccoffee::crazy::annoyed::smash::cookiemonster:
    Conclusions:
    (1) If the replacement LED signals won't incinerate the housings on low level, I'll probably keep the amber DRL and use LED replacement bulbs for signals and DRL.
    (2) If the replacement LED signals threaten to incinerate the housings with extended "on" time (DRL), I'll do the amber delete and use the LEDs only for the short-term turn signals.
    (3) If the replacement LED bulbs threaten to incinerate the housings at ANY power level, I'll keep the amber DRL and use the stock 7444NA bulbs.
    Watt maker likes this.
  8. Mar 22, 2019 at 7:19 PM
    JeremyGSU
    Jeremy
    2016 Tundra
    Yes. I’m using the stock ‘16 turn signal bulbs.
    I think the guys that are complaining have the stock LED headlights from factory and it may use a different turn signal bulb than if you did the conversion and used your old orange day time running lights.
    I’ve looked at mine at night and didn’t notice any issues seeing them at all.
    JohnLakeman likes this.
  9. Mar 22, 2019 at 7:24 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    No amber for me. Be careful if your going to de pin I attempted to de pin and subsequently snapped the wire. So I taped both ends and it seems fine lol.
  10. Mar 22, 2019 at 7:36 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Hey @Watt maker you think my truck will go up in flames because of that?
  11. Mar 22, 2019 at 8:02 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Thank you sir!
  12. Mar 22, 2019 at 8:11 PM
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
    I haven’t done this but I like the look of the amber!
  13. Mar 22, 2019 at 8:22 PM
    I'm on the fence about it
  14. Mar 22, 2019 at 8:31 PM
    JohnLakeman
    I read a post where someone else (might have been you) used their old bulbs. Since the new bulbs are different, how does that work?...Do you use your original sockets, and they will fit the new 2018+ housings and iHacker's harness?
  15. Mar 24, 2019 at 6:39 AM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Amber delete. I think it looks cleaner. Have the lights all one color when you look at it head on. I kept the side parking light orange(GTR Led) so when you see it from the side it stands out a little more for safety.
  16. Mar 25, 2019 at 4:42 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    Yep. The sockets are still the same. Just plug and play.
    JohnLakeman[QUOTED] likes this.
  17. Mar 25, 2019 at 5:19 AM
    sundance
    sundance New Member
    I've done both and I think I like the amber include better.
    I have noticed several 2018 and 19s that don't have DRLs on at all?
    How does that work?
  18. Mar 25, 2019 at 5:32 AM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    The led strip around the headlight have to be turned on manually in my '18. You can also turn them off. I usually keep the surround on and turn everything else off.
    sundance[QUOTED] likes this.
  19. Mar 25, 2019 at 5:37 AM
    sundance
    sundance New Member
    I've thought about putting a switch inline to do the same. Trying to think of a reason to have them off.
    reelcracker[QUOTED] likes this.
  20. Mar 25, 2019 at 5:38 AM
    reelcracker
    Farva
    2018 off-road d/c
    6 in one 1/2 dozen in the other
  21. Jan 25, 2020 at 10:07 PM
    Hold Fast
    Hold Fast New Member
    I would like to keep the amber on but make my white DRL amber as well. Has anyone done this? I am even thinking amber film over just the LED DLR part. Any ideas? I like the amber DLR lights of my 2014 but now I have a 2019 and I would much rather have the amber. Thanks
    CanDras likes this.
  22. Mar 5, 2021 at 10:43 PM
    CanDras
    CanDras New Member
    Marc
    Canada
    2018 Plat. Supercharger, Fox 2.5 DSC, Total Chaos UCA, ADD Stealth Bumper, ARE topper, 35x12.5x20 Toyo MT, Fuel D671
    Any luck with this?
  23. Mar 6, 2021 at 4:13 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2021 Super White TRD Pro
    In progress…
    LED bulbs produce about 20% as much heat as an equivalent halogen bulb. They should be cooler than the stock bulbs. If not then something’s wrong.
  24. Mar 6, 2021 at 4:35 AM
    JohnLakeman
    My fears in that post were based on some false info in Amazon reviews. I did the testing for myself, and confirmed the temps were slightly cooler, but not 80% cooler. I think the temp results were posted here somewhere.
    That post is nearly two years old...I'm smarter now. At least about LEDs, I'm smarter. :D
  25. Mar 6, 2021 at 4:49 AM
    tttrdpro
    SWGA
    In progress…
    Good deal. I wasn’t trying to be a smart ass (this time). A lot of people think LED’s get hotter than halogen/incandescent bulbs, but it just ain’t so.
