1794 engine / computer adjustments
Discussion in '2.5 Gen Tundras (2014-2021)' started by cnoswadj, Nov 10, 2018.
  1. Nov 10, 2018 at 10:03 AM
    cnoswadj
    cnoswadj [OP] New Member
    Chuck
    2018 Tundra 1794
    Toyota cat-back dual exhaust, TRD cold intake and anti-sway bars
    I have a new 2018 1794 edition Tundra that I had the dealer modify by adding a cat-back dual exhaust, a TRD cold air intake system and anti-sway bars. My seems to run and handle better so I am happy with the mods, but gas mileage has suffer somewhat. Is there anything I can do to improve my mpg?
  2. Nov 10, 2018 at 10:51 AM
    15whtrd
    15whtrd Mr. Blonde
    None of that should’ve affected your gas mileage. I think you just need to keep your foot out of it lol. Maybe the truck just needs to learn it has a little more flow in the intake. Did you try resetting the ECM? Disconnect the battery for about three minutes. Did you try resetting the ECM? Disconnect the battery for a few minutes. I like to hit the brake or the horn a few times to make sure all the power is drained from the system.
    Inquiringone likes this.
  3. Nov 10, 2018 at 10:58 AM
    cnoswadj
    Chuck
    2018 Tundra 1794
    Good tip, should have thought of that. I’ll give it a try.
    BTW, the new sound and handling probably has created a heavier right foot... ;)
    Inquiringone, Black Wolf and 15whtrd like this.
  4. Nov 10, 2018 at 11:08 AM
    15whtrd
    15whtrd Mr. Blonde
    Haha no doubt!
  5. Nov 10, 2018 at 8:28 PM
    JTX Tundra
    JTX Tundra New Member
    I average 12 to 15 mpg per tank. If I make an effort I can get over 18 mpg. The best way to improve gas mileage is to change your driving style. Light on the throttle, minimize use of brakes, keep it under 65, and stay out of the left lane. But that's no fun.
    ColoradoTJ and TundraLuv like this.
  6. Nov 11, 2018 at 4:38 AM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    You loss low end and back pressure with the exhaust. Surely you felt that. I had Trd duals for 4 years in my 14. Didnt think anything of it. Until I drove a stock 2018. It was significant. My 18 CM at 70 to Houdton and back was just at 18.7 average. I'll take it.
    14burrito likes this.
  7. Nov 11, 2018 at 4:50 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I'm looking to get a rear sway bar and the TRD exhaust installed this coming spring, and this is exactly what I'm expecting to happen to me.
  8. Nov 11, 2018 at 6:09 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    The TRD intake is supposed to work with the ECU the way it is. At least that’s what the product description says.
  9. Nov 11, 2018 at 6:21 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Fix the nut between the seat and steering wheel
    Navi, landphil and TRD-tv like this.
  10. Nov 11, 2018 at 7:38 AM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    Hahahaha ull have to use that
  11. Nov 11, 2018 at 7:45 AM
    Stig
    Stig New Member
    Another gas mileage thread...
  12. Nov 12, 2018 at 6:22 PM
    cnoswadj
    Chuck
    2018 Tundra 1794
    ...thx for the help...I think I’ve had enough.
    15whtrd, Inquiringone and TRD-tv like this.
  13. Nov 12, 2018 at 6:27 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    This.
    And the intake didnt Help either. Most "performance" intakes are tuned for HP gains: they use a larger diameter tube = tuned more for high end power.
    netranger6[QUOTED] likes this.
