1794 driver seat heater question
Discussion in '2.5 Gen Tundras (2014-2021)' started by sadbttru, Nov 11, 2025.
  1. Nov 11, 2025 at 3:36 AM
    sadbttru
    sadbttru [OP] New Member
    2020 tundra 1794 edition
    None yet but help!
    Hi! I have searched a bit for this but I’m looking for 1794 trim guidance. My seat heater stopped working and I was looking for a video or something to get an idea of how complicated this is. The passenger side still works. The light fir driver side still works.
    Thank you!!
  2. Nov 11, 2025 at 7:16 AM
    explorerst4x4
    explorerst4x4 ᔭxᔭʇsɹǝɹoldxǝ
    Marc
    Cincinnati
    2017 Tundra DC SR5 MGM "Donkey"
  3. Nov 16, 2025 at 1:46 PM
    sadbttru
    None yet but help!
    Thanks!
    I read through most of that. I talked to one mechanic, not a dealer, and they were saying some of the tundras you have to cut the stitching to get the heater out. Just wondering if that’s the case for the 1794. Seems strange it quit as it’s a 2020. But I did have it on constantly. My back needs it!
  4. Nov 16, 2025 at 2:19 PM
    1lowlife
    1lowlife Toxic prick and pavement princess
    DADA
    THE GREAT STATE OF TEXAS
    On my 3rd Tundra 2005 DC 2014 DC 2026 CM Limited
    Is it the seat bottom and back that don't work?
    They seem to be different parts, but they look wired in series.
    2014-2021 Toyota Tundra 2014-2021 Toyota Tundra - Seat Back Heater 87530-0C041 | Sparks Parts
    2014-2021 Toyota Tundra 2014-2021 Toyota Tundra - Seat Cushion Heater 87510-0C071 | Sparks Parts
    I would bet there is a break in the heating element.
    Even more so since you used it a lot.
    Removing the cover might be more difficult if you have ventilation, I'm not sure.
    But the cover itself should be removable.
    I installed aftermarket seat heaters in my SR5 and it wasn't that hard.
    Release the elastic straps on the bottom, and there should be zippers on the sides.
    You will need hog ring pliers and extra hog rings to get it off and back on.
    Something like this.
    WORKPRO Bent Hog Ring Pliers with 500 Pcs 3/4" Hog Rings, Galvanized Steel Hog Rings Perfect for Furniture Upholstery, Auto Upholstery, Plastic Meat & Sausage Casings - Amazon.com
    https://youtu.be/cwmjuVwXYvU?si=0analAFFWTQfWqdw
    Both sides are on the same circuit, so there aren't separate fuses.
    You might want to try testing the Z1 connector under the seat with the ign on and make sure it's getting power under the seat.
    It will be pin 1 the lime green wire.
    It should be hot with just the IGN on,
    upload_2025-11-16_16-10-54.pngupload_2025-11-16_16-1-21.pngupload_2025-11-16_16-1-37.pngupload_2025-11-16_16-12-25.png
    Good luck..
