1.9" or 2.5" on Bilstein 6112?
Discussion in 'Suspension' started by upchurch_k, Aug 12, 2019.
  1. Aug 12, 2019 at 8:36 AM
    upchurch_k
    upchurch_k [OP] New Member
    So I'm getting a set of 6112/5160's and I'm really struggling to figure out what height I should set them at. My plan is to put a BOSS 4X4 shackle in the back to retain some rake for hauling purposes. I want to run 275/65/R20's, and I really don't want to have to replace UCA's or anything like that. Any input would be welcomed!
  2. Aug 12, 2019 at 8:43 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Stock wheels? 1.9
    Wider wheels 2.5 imo
    Luckydog likes this.
  3. Aug 12, 2019 at 8:46 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    I would go with a add-a-leaf instead of shackles for hauling. It will actually help with hauling and help with bed bounce.
  4. Aug 12, 2019 at 8:47 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    275/65/20 fits stock.
  5. Aug 12, 2019 at 8:47 AM
    upchurch_k
    Sorry, forgot to mention that I'm sticking with the stock wheels just need new all terrains. @canadianguy do you have a recommendation on an AAL?
  6. Aug 12, 2019 at 8:48 AM
    upchurch_k
    @Scuba you're saying 275/65r20 fits stock with no lift/level?
  7. Aug 12, 2019 at 8:50 AM
    canadianguy
    Kevin
    I did the toytec add a leaf. Rides way better in the back.
  8. Aug 12, 2019 at 8:54 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Correct.
    Stock wheels nothing is needed.
    AM wheels I had to remove mud flaps.
    My truck came with 275/65’s. I only recently put Eibach leveling shocks on the front set at “2” average lift.”
  9. Aug 12, 2019 at 9:09 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
  10. Aug 12, 2019 at 9:22 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
  11. Aug 12, 2019 at 11:39 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I am happy with 1.9. I sacrificed height for ride comfort.
  12. Aug 12, 2019 at 12:25 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    BBF059C9-0A18-4D17-B276-4C2CAD87AA88.jpg 8772BBA3-5514-41D8-B22C-45FD73A393A5.jpg 25D04C73-FA61-4443-9247-0CBC70CFF131.jpg Personally, I like being high lol! I set my 6112’s at top setting 2.5” and did 1/2” shims. Out back I’m running the 5100’s since I’m on road more and didn’t want to spend more. Also went with +3 Coachbuilder shackles and it leveled really nice. Front looks a touch high but it’s pretty dang close. Topped it off with some Michelin LTX ms 2. 275/65/20. I got real close to 3.25 inches of lift up front and almost 2” out back. Since I went top setting I decided to get some JBA upper control arms, but was told it wasn’t absolutely necessary. Love the way it rides! Not rough at all for being on top setting. The only thing I suggest is getting some front bumper spacers from Coachbuilder pushes the front bumper out 1” to help clear large tires, also had to trim the skid plate BBF059C9-0A18-4D17-B276-4C2CAD87AA88.jpg8772BBA3-5514-41D8-B22C-45FD73A393A5.jpg
