'06 Tundra Double Cab 4wd Limited doors- how can I auto lock on drive off?
Discussion in '1st Gen Tundras (2000-2006)' started by Cemoto, Nov 12, 2017.
  1. Nov 12, 2017 at 3:18 PM
    Cemoto
    Cemoto [OP] New Member
    Al
    I've done as much research as I can but have found nothing that works for my truck. It does have an aftermarket remote start installed but I don't think that would have anything to do with my issue.
    I have an '06 Tundra Double Cab 4wd Limited and would like to have the doors auto lock when put into drive or when the vehicle starts rolling like my Camry's do.
    Would you happen to know of a way to do this?
    I've tried the put it in N and hold the door lock button and have done the five on/off sequence as well without results.
    Thank you.
  2. Nov 12, 2017 at 4:33 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    I wonder if it's something Tech Stream could change.
  3. Nov 12, 2017 at 5:11 PM
    Cemoto
    Al
    Ok - what is tech stream?. Thank you.
  4. Nov 12, 2017 at 6:09 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Proprietary Toyota software that runs on a computer that connects to your truck via it's OBDII port to access the vehicles various ECUs to change settings and to read stored trouble codes. Some folks have personal copies. I'm not sure if it works with 06 and earlier vehicles. My oldest is an 07. Someone else will have to chime in to answer that.
  5. May 31, 2018 at 10:59 AM
    T23
    T23 New Member
    I have a 2005 SR5 with the OEM alarm. Asking the same question. What is the "neutral hold the door lock" sequence? Be great to correct this as I like having the doors lock. Thanks!
