06 double cab 4.7 control arm issues
Discussion in '1st Gen Tundras (2000-2006)' started by Gibson24, Feb 8, 2018.
  1. Feb 8, 2018 at 12:13 PM
    Gibson24
    Gibson24 [OP] New Member
    06 double cab 4.7 tundra
    3200$to front end
    I just put 3200.00 into wheels tires upper and lower ballpoints 285 70r 17 tires. My control arm trashed my upper joint and is getting into springs when I hit holes. Please help
  2. Feb 11, 2018 at 3:31 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    sounds like you need an upper control arm.....I replaced my left side, got it from Rock Auto.
    Black Wolf likes this.
  3. Feb 13, 2018 at 6:09 AM
    Gibson24
    3200$to front end
    I just bought lower control arms and the guy said uppers were good. I have a front 2 inch leveling kit on it. The new upper ball joint is shot already and I was told I gotta do something to my truck to run these tires Dang 3000 in the front you'd think it's all good. Thanks
  4. Feb 13, 2018 at 8:05 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    So when you do a lift kit on these, do you need to have a longer control arm? Could the lift kit be putting stress on it? Or did you get a bargain price ball joint? I have done that in the past, and now I'd rather spend the money on quality ball joints now, it's not worth it going cheap on these. The Mevotech did not last very, now using all Beck/Arnley ball joints. Toyota might be better, but more costly.......but will try those next if these don't last.
  5. Feb 22, 2018 at 12:12 PM
    Gibson24
    3200$to front end
    Thanks
  6. Feb 22, 2018 at 4:40 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I bit the bullet and bought adjustable upper arms since my alignment wasn't great after new 5100's and OME springs. Sucks to spend another $400 but it's better than buying a new set of tires. There's quite a bit more clearance with the SPC arms and they came complete with new upper ball joints, only took an hour or so to install.
    Brt, Gibson24[OP] and Black Wolf like this.
  7. Feb 22, 2018 at 4:56 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Welcome!! Let’s see your truck!
  8. Feb 25, 2018 at 5:40 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Ok, so they make adjustable control arms for these.......probably because of the lift kits. Geometry is important. Extra money, but Sounds like you solved the issue.
  9. Mar 10, 2018 at 12:01 AM
    Gibson24
    3200$to front end
    Thanks two both....for the one about 5100's...I got hydroshock 5700. So how much did the arms cost? I'd do it because I've got almost 4500 in the front end with new 17inch by 10 dick cepec and but k2s and it should drive like a caddy but it's destroying ballpoints.
  10. Mar 10, 2018 at 12:02 AM
    Gibson24
    3200$to front end
    Just curious ...do you know if a turbo charger or a chip is available for this truck?
  11. Mar 10, 2018 at 3:52 AM
    Festerw
    Festerw New Member
    04 Tundra DC
  12. Mar 17, 2018 at 10:47 AM
    banta4x4
    banta4x4 New Member
    Josh
    2006 Tundra Double Cab TRD 4x4
    285/70R17 BFG All Terrain KO2 17 x 8.5 Stealth Custom Series Stealth 6 Bilstein 5100/5150 F/R
    I am having the same issue where the upper ball joint hits the springs.
    However, the angle of the ball joint bolt/ spindle is thrown off so I am having trouble replacing the stock UCA with camburg uniballs.
  13. Apr 18, 2018 at 6:50 AM
    Gibson24
    3200$to front end
  14. Apr 18, 2018 at 6:51 AM
    Gibson24
    3200$to front end
    These look like they don't fit. How does the ball joint hook up going down instead of up.
  15. Apr 18, 2018 at 8:08 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    There is a bushing that gets pressed into the knuckle then the ball joint is tapered and bolted through.
  16. Apr 18, 2018 at 8:14 AM
    Gibson24
    3200$to front end
    Ok.....so I just ordered them. Everything I need comes with the new control arms then. I think I saw the spacer in the pic that gets pressed right!
  17. Apr 18, 2018 at 8:19 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yup. It's not a hard install. Biggest problem I had was getting the right adapters to get the old ball joints out. That and I'm an idiot and tried press the bushing in the wrong direction at first :frusty:
  18. Apr 18, 2018 at 10:13 AM
    Gibson24
    3200$to front end
    So I have to take out the new ball joints in the new control arms and turn them the other way
  19. Apr 18, 2018 at 11:48 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Nope you remove the old control arm and ball joint. The new arms come with a new ball joint, insert, c-clip, and washers. The only part you'll reuse is the control arm bolt and nut.
  20. May 9, 2018 at 11:59 AM
    Gibson24
    3200$to front end
    I just had these put on and there is a manufacturer defect with them that will not allow you to align the vehicle properly
  21. May 9, 2018 at 3:11 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'm intrigued, what was the defect?
  22. May 10, 2018 at 12:05 AM
    Gibson24
    3200$to front end
    The company told the mechanic putting them In that there is still movement in the control arm that alters the alignment somewhat. I'll find out tomorrow
  23. May 10, 2018 at 12:08 AM
    Gibson24
    3200$to front end
    The company actually admitted that they was a design flaw
  24. May 10, 2018 at 8:22 AM
    Casper421
    In the woods
    06 DC
    What brand UCA?
  25. May 17, 2018 at 12:09 AM
    Gibson24
    3200$to front end
    They are spc by MTR motorsports from a site from a guy messenging in above messages. Maybe I need UCA instead. There is plenty of room for the tire but these aftermarket arms isn't designed this way and no factory.
  26. May 17, 2018 at 4:54 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Do you have some pictures of what you're dealing with?
    The SPC UCA's are still basically the same design for the newer trucks so if there's a known defect I would expect to hear a lot of complaints.
  27. May 17, 2018 at 8:25 AM
    Brt
    Brt New Member
    Brett
    Oregon
    2005 Tundra SR5 TRD 4x4 Silver Double Cab
    A few dents ;) This will hopefully populate soon.
    Hi Gibson! What setup are you running in the front by chance? We'd love to see it :)
  28. May 17, 2018 at 8:47 AM
    Brt
    Brt New Member
    Brett
    Oregon
    Maybe I missed it, but what arms would those happen to be? How are they performing?
  29. May 17, 2018 at 8:54 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I have the SPC arms also, been on for 6 months with no issues.
  30. May 17, 2018 at 9:14 AM
    Brt
    Brt New Member
    Brett
    Oregon
    I may look into those. Thank you!
