02 tundra rear axle
Discussion in '1st Gen Tundras (2000-2006)' started by crownapper, Aug 27, 2022.
  1. Aug 27, 2022 at 2:31 PM
    crownapper
    crownapper [OP] New Member
    Brad
    2002 Tundra sr5
    I am new to the forum. I have a 2002 Tundra sr5 4.7. I am in need to replace the right rear axle. My tundra doesn’t have abs brakes. I am looking to buy a axle assembly with bearings ect already pressed. Every axle I have found is for abs brakes. Will an axle with the abs ring and collar fit the housing of non-abs brakes? Or if the collar and ring is removed would the axle fit correctly? Any information will be gladly appreciated as I need this repaired asap. Thanks.
  2. Aug 29, 2022 at 10:31 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    With the collar being behind the tone ring, I'm not sure it would work. The collar is what seals the axle tube.
    Take a look at the top of your axle housing. If it looks like this minus the hole on top I don't see why an abs axle wouldn't work.
    Jack McCarthy and shifty` like this.
  3. Jan 6, 2024 at 2:58 PM
    hawkshaw94
    hawkshaw94 New Member
    2002 tundra 4.7L
    I could use an abs rear end for 2002 8cyl
  4. Jan 6, 2024 at 5:29 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 44k mi
    Car parts dot com
  5. Jan 6, 2024 at 5:30 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Why are you replacing axle? Is it a bad bearing? If so just replace bearing and seal and also replace the vent nipple.
