01 tundra with 06 sequoia motor and transmission and transfer case
Discussion in '1st Gen Tundras (2000-2006)' started by Dallas127, Jun 12, 2022.
  1. Jun 12, 2022 at 5:22 PM
    Dallas127
    Dallas127 [OP] New Member
    Dallas
    01 tundra with 06 sequoia motor trans tranfar and both axles ON 35'S WITH 3" LIFT
    01 tundra with 06 sequoia motor trans tranfar Case and both axles ON 35'S WITH 3" LIFT
    I was hoping mine would be a direct swap ( 2006 sequoia to 01 tundra swap EVERYTHING)but trans is different the motor will plug right in but the transmission and transfer case is different! help I can't figure it out!!! SO MANY WIRES!!!!! I have everything from 06 sequoia in there just have trouble with the wiring!
  2. Jun 12, 2022 at 5:39 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I believe only 00-04 are the same with 05-06 being much different with the VVTI engine and 5 speed over the original 4 speed transmission.
    5N0W808 likes this.
  3. Jun 12, 2022 at 5:40 PM
    Your 1st mistake was probably putting the '06 with VVTi 2UZ engine into your '01 non-VVTi 2UZ truck ('01 is V8, right?). I'm fairly certain the '05+ Seq/Tun all had VVTi drivetrains.
    The general rule of thumb is, if you're moving to a new drivetrain and engine type, you always use the donor vehicle's engine harness and ECU so you don't get stuck in the screwed position you're in now, digging through schematics and re-pinning stuff, and ultimately chasing gremlins galore, which you will be doing most likely.
    5N0W808 likes this.
  4. Jun 12, 2022 at 5:48 PM
    Dallas127
    Dallas
    the motor plugged right in I have everything out of the sequoia but the wiring harness got cut where it comes in on passager side I have the dash, Colom,gauges,computer>I have everything!!!
    shifty` likes this.
  5. Jun 12, 2022 at 5:48 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I think those sequoia were Awd as well
  6. Jun 12, 2022 at 5:55 PM
    Dallas127
    Dallas
    no not all wheel drive!
    FrenchToasty likes this.
  7. Jun 12, 2022 at 5:57 PM
    Dallas127
    Dallas
    i have the axles in it done that before trans went out! so it's has disk brakes all the way around it
    5N0W808 likes this.
  8. Jun 13, 2022 at 4:42 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Disk brake conversion... nice! :thumbsup: Got any pics of the axle installed?
    Sorry, I got no info on the wiring except that it's going to be some work since the engine, transmission, and transfer case are not plug-n-play compatible with your truck.
  9. Jun 13, 2022 at 9:20 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    to make the 5 speed work you'd need to get creative with a 4runner 4.7 non vvti ECU. the 5 speed will not work with an 01 ecm. and you cant run an 01 engine on an 05-06 ecm
