‘21 CM Limited Led headlights flutter
Discussion in '2.5 Gen Tundras (2014-2021)' started by ScenicRoute, Oct 12, 2022.
  1. Oct 12, 2022 at 5:45 AM
    ScenicRoute
    ScenicRoute [OP] New Member
    2021 Tundra CM Nightshade
    Eibach stage 2, SmartCap, Ride Rite, Bora spacers, 35” rugged ridge tires.
    Have a 2021 cm limited nightshade with the oem led headlights. Have noticed that the headlights bounce or flutter…not in intensity but the housings…when on uneven or rough roads. Search yielded zero results with anyone else complaining of this issue. It’s both lights and they do seem noticeably loose when you fondle them!
  2. Oct 12, 2022 at 6:17 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Take to dealer and have them tighten the mounts and adjust them to spec. It’s a 21. Yours is the first I’ve heard of on here.
  3. Oct 12, 2022 at 9:36 AM
    Chris001
    Chris001 New Member
    Ontario, Canada
    2018 Tundra Double Cab SR5
    LED interior, tint, auto lock tailgate, Rhino Liner, Blacked out emblems
    Are you sure it's not the fog lights? Posts all over about them bouncing.
    EDDO likes this.
  4. Oct 12, 2022 at 10:28 AM
    ScenicRoute
    Definitely the headlights.
  5. Oct 12, 2022 at 2:02 PM
    corisu
    corisu New Member
    2021 Crewmax TRD Off Road
    I have the same problem on my 21. I checked the housing and everything is tight, appears to be something internal bouncing around.
