‘05 Tundra Crewcab Limited
Discussion in '1st Gen Tundras (2000-2006)' started by MrFeldman, Jul 14, 2022.
  1. Jul 14, 2022 at 8:30 AM
    MrFeldman
    MrFeldman [OP] New Member
    Mr
    ‘05 Tundra Limited Crew Cab
    Upgraded Stereo
    Hey folks, I’ve got a tire pressure warning light on , won’t turn off , all my tires are recently rotated & balanced at my local Les Schwab, and I’ve replaced the battery, still on for no apparent reason. Any advice?
  2. Jul 14, 2022 at 8:54 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    One or more of your Tire Pressure Monitor Sensors (TPMS) is probably bad. You can either replace one or all of them (don't forget the spare tire too), or do the TPS disable modification. I chose the latter due to the expense of the TPMS x 5 and installation costs.
  3. Jul 14, 2022 at 9:08 AM
    Is the light solid or flashing? Or flashing, then eventually solid? Solid with no flashing at any time means one sensor is reporting error/low pressure. Flashing means comminicating/communication error. Often times, a sensor battery is dead, sometimes it's a sensor failure.
    Have you used the reset button on the driver side lower dash to reset the TPMS? The Gen 1 came with an archaic system, you basically hold the button to tell it to remember the current values, then it checks for % of skew from those values, IIRC.
    The TPMS receiver is typically mounted to the ceiling, top center, just in front of the 3rd brake light. Not important for this, just sharing that extra bit.
  4. Jul 14, 2022 at 11:12 AM
    MrFeldman
    Mr
    Upgraded Stereo
    Yes, I have hit the reset button on the bottom of steering column, and when I installed new battery, everything reset, including (aftermarket stereo)stereo presets, time, and the tire pressure light flashes on ignition start, then stays on solid. I may just do the bypass.
  5. Jul 14, 2022 at 11:29 AM
    If it flashes repeatedly at IGN but eventually goes solid after, say, 20+ seconds, I've seen some take 2-3 minutes, then it's a sensor failing to communicate.
    Still, I'd try holding down the button for - I think 10 seconds? - just to see if it'll reset. After checking all 4 tires for pressure, of course.
    MrFeldman[QUOTED][OP] likes this.
  6. Jul 14, 2022 at 12:49 PM
    GXPaycheck
    GXPaycheck New Member
    Central NC
    Did you check the pressure on the spare? I've done that one.
  7. Jul 14, 2022 at 1:10 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The TPMS sensors have to be replaced, most likely. There is no way to just change the batteries in them, as they are sealed.
    shifty` likes this.
  8. Jul 14, 2022 at 2:05 PM
    MrFeldman
    Mr
    Upgraded Stereo
    seriously? Are you saying low pressure on my spare could cause that warning light? I’ll check it out.
  9. Jul 14, 2022 at 2:52 PM
    Teutonics
    2005 DC SR5 4WD
    Yep!
  10. Jul 14, 2022 at 3:47 PM
    MrFeldman
    Mr
    Upgraded Stereo
    Thanks for the tip!
  11. Jul 14, 2022 at 6:29 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Denso from RockAuto are the same as the factory ones, but less than 1/2 the price.
    I swapped all mine, but haven’t programmed them yet :frusty:
    MrFeldman[OP] and FrenchToasty like this.
  12. Jul 15, 2022 at 12:14 PM
    I really need to get off my ass and get an OBDII tool that will read codes, reset SRS, and allow programming of TPMS for our '20 highlander and my 1GT.
    Diablo169[QUOTED] likes this.
