GP Audio Battery Terminals
Discussion in 'General Tundra Discussion' started by kurtwp, Jan 27, 2018.
  1. Jan 27, 2018 at 4:03 PM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    Curious to know if the GP battery terminals will fit a 2016 stock tundra battery. I noticed on my battery that I have two raised rectangles that are about 2 5/8 inches in from the edge of the long side of the battery. I wonder if the GP terminals will rest completely on the battery or will they need to be turned out?
    I looked at GP's website to check dimension but could not find any. Does anyone know the dimension of the product?
    http://gpcaraudio.com/gp-audio-sae-style-6-spot-machined-battery-terminals/
    Kurt
  2. Feb 1, 2018 at 4:17 PM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    RitcheyRch, MT Madman and BlueBottle like this.
  3. Jan 16, 2019 at 10:45 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Looking to buy this for my soon to come Northstar battery. Any other posts to consider besides this?
    I’m also concerned about the conductivity of aluminum vs copper
  4. Jan 16, 2019 at 10:46 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  5. Jan 16, 2019 at 10:48 AM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    BlueBottle[QUOTED] likes this.
  6. Jan 16, 2019 at 11:50 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    No, I never pursued getting them or the other terminals.
    Kurt
    BlueBottle likes this.
  7. Jan 16, 2019 at 1:45 PM
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    Yes-the GP terminals do fit. I had them on my 18 until I swapped out batteries for AGM.
  8. Jan 29, 2019 at 10:49 AM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
  9. Jan 29, 2019 at 12:03 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    I have the gp terminals on my tundra what about two years now. No problems.. I'm using a lead acid battery.
  10. Feb 5, 2019 at 10:13 AM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    :worthless:
    Any concerns with large exposed positive and negative terminals and is there any signs of corrosion on the aluminum?
  11. Nov 30, 2021 at 8:51 PM
    dittothat
    dittothat New Member
    SD
    2016 MGM Platinum
    Bumping this thread up. Tried to install my GP terminals today but the hole in the main positive lead was too small for the bolts on the GP terminal. The negative lead was fine. Was a little weary about thinning out the positive ring as not sure it would handle the current etc etc. Anyone else have to deal with this. I have a ‘16. SDHQs looks nice because they offer different size mounting bolts to fit different sized rings
  12. Dec 31, 2021 at 11:26 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have the GP terminals and the A battery lists are too skinny. If you read the fine print on the terminals it says you might have to use those caps on the the terminal to fill the space. I tried it and it doesn’t work very well. The caps were too thick and basically sheared off. Currently in the market for some new ones.
    NewImprovedRon likes this.
  13. Dec 31, 2021 at 11:28 PM
    Tundyfundy
    Bay Area, CA
  14. Jan 8, 2022 at 9:07 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I’ve got the same battery. I have the GP terminal with the set screw, works great, it’s on there very tight.
  15. Jan 10, 2022 at 1:06 AM
    Tundyfundy
    Bay Area, CA
    Me too, I wonder if they would give a discounted upgrade. Obviously its an issue, I already wrecked mine by putting a new bolt into the clamp and tightening it to deform the terminal to hold tight to the terminal. Gonna be a bear to get those things off now.
  16. Jan 11, 2022 at 1:29 AM
    Tundyfundy
    Bay Area, CA
    for 50 bucks might not be worth the hassle. I'm just going to order the new ones I think or look for another type. Probably do it next time I need a battery. I have about 2 years on this AGM.
  17. Jan 13, 2022 at 1:47 AM
    Tundyfundy
    Bay Area, CA
    Smart choice. So frustrating. Keep us posted when/if they respond.
  18. Apr 2, 2022 at 5:21 PM
    Nickatnight
    Nickatnight New Member
    98445
    2021 1794 Tundra
    Rhino running boards, Amber running lights, Underhood automatic LED Lighting, OEM Fender Flares, Tech12 Volt New Killer Audio System with factory Head Unit.
    Hi, has anybody else have a problem with the battery positive terminal wire being too short to change out to a higher performance terminal? I have a 2021 Crew and I canʻt pull enough slack to change the positive terminal out. Thanks
    Toyotoholic and dittothat like this.
  19. Apr 2, 2022 at 5:26 PM
    dittothat
    SD
    2016 MGM Platinum
    I have the same issue on my 2016. Not enough slack for either the GP’s or SDHQ terminals. Currently have both sitting on a shelf in the garage. Still debating if I want to sell them or hold on and eventually do a big 3 upgrade.
    Toyotoholic likes this.
  20. Apr 3, 2022 at 8:35 AM
    Nickatnight
    98445
    2021 1794 Tundra
    So are some wiring harnesses shorter than others, doesnʻt make sense that a 2016 and a 2021 have the same issue.
  21. Apr 3, 2022 at 9:42 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I did this to my GP audio terminals 3 years ago...
    No problem with the factory wire lengths, and I just drilled a second hole in the ground terminal so it looks and fits better, and has never worked it's way loose.
    dittothat likes this.
