Tundra 2007+ Coachbuilder Driveline spacers
Discussion in 'Ekstrom Design' started by Coachbuilder1, Jul 3, 2015.
  1. Jul 3, 2015 at 11:56 AM
    Coachbuilder1
    Coachbuilder1 [OP] Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    If you've lifted your Tundra Waaaay up and feel a vibration in the rear driveline chances are your driveline is not fully splined. 4wd applications 5" or more in the rear and 2wd applications 3" or more in the rear can definitely benefit. Normally guys running the Bulletproof lift using 9"/10"/11" rear leafs and are 4wd will need a .750" or 1" spacer.
    2wd trucks don't have the slip yoke design the 4wd models do and are much more tempermental when it comes to rear lift. The 2wd trucks pull on the carrier bearing and will actually slide the font portion of the driveline out of the tail shaft.
    6061 Billet Black Anodized finish (hardware included)
    https://www.shopcoachbuilder.com/pr...e-spacer-10-5-rear-axle-actual-thickness-1-25
    fb2c2fd4-c810-4097-a3b1-da3cd4b5941d_zps_3defe372b0ccfea3300895d7a16349986aaa2749.jpg
    1f98450e-c778-4aed-966e-ba62c52808c8_zps_fa81ed904fef1b871c66bd94cbe3f50b46d85e31.jpg
    Please feel free to Call, Email or PM for pricing.
    Ekstrom Design llc.
    801-635-4872
    ekstrom_design@yahoo.com
    Prostar 190 and GNTundra like this.
  2. Aug 23, 2016 at 2:20 AM
    kiteguam
    kiteguam New Member
    Isaiah
    Hi, I realize this post is old but I recently lifted a 2015 2wd with a 7" BDS kit, whats the size of your spacer?
  3. Aug 23, 2016 at 4:53 AM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    You've got to call or text David at 801 635-4872. He'll never even see your post.
    Coachbuilder1[OP] likes this.
  4. Aug 23, 2016 at 1:16 PM
    Coachbuilder1
    Salt Lake City UT
    This application usually uses a 1.25" driveline spacer. every truck sits just a touch different but would recommend pulling a measurement from the tall shaft out to the edge of the cup (dust shield) on the front portion of the driveline. We build them in .750" and 1.25"
  5. Sep 25, 2017 at 10:17 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Is this needed on a 3-3.5” lift?
  6. Sep 25, 2017 at 10:38 AM
    Coachbuilder1
    Salt Lake City UT
    Usually not, with a 3"-3.5" lift up front we normally only raise the rear 1.75" and will not need a driveline spacer. If you need help with lift options please let me know.
    David 801-635-4872
  7. Jun 12, 2018 at 8:49 PM
    cyllo
    cyllo New Member
    2008 tundra
    2wd poser with 6 inch rough country lift
    O.K. I have the spacer...… I'll install tomorrow. Hopefully this resolves the driveshaft being pulled backwards and into the carrier bearing frame under hard braking.
  8. Jun 13, 2018 at 11:02 AM
    Coachbuilder1
    Salt Lake City UT
    Which one did you go with?
  9. Jun 13, 2018 at 2:07 PM
    cyllo
    cyllo New Member
    2008 tundra
    Yours.... this is mike in tampa. You shipped out Saturday
    It’s in...... took a whopping 10-15 minutes.
    No more pulling the front driveshaft into the carrier bearing under hard braking. I didn’t realize that was what it was at first. I figured it was bad timing after installing the lift because it sounds just like pad to rotor...... so I have new brakes in the rear because of it.
  10. Jun 13, 2018 at 2:12 PM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
  11. Jun 13, 2018 at 2:38 PM
    Coachbuilder1
    Salt Lake City UT
    Awesome! I didn't realize it was you :) Fixed the driveline, carrier bearing, vibration and scored some new back brakes. Nice job! Thanks for posting.
  12. Jun 14, 2018 at 6:18 AM
    jbrownie99
    jbrownie99 New Member
    Jose
    So I just read this thread too and I’m pretty sure I’ll need this also! I’m at 7/8” out Please advice! If so send me another invoice and I’ll get it ordered, It’s Jose Rivera from Florida thanks again David
  13. Jun 14, 2018 at 8:17 AM
    Coachbuilder1
    Salt Lake City UT
    Thanks for the follow up Jose, I would def recommend correcting this while you're under there. As the suspension cycles up and down the driveline will pull in and out of the tail shaft not only minimizing the amount of spline its using but will also end up wearing the tail shaft seal out.
    Invoice sent and will ship your spacer with your shackles. thank you!
  14. Jun 14, 2018 at 8:22 AM
    jbrownie99
    Jose
    Thanks again brother!!!! Coming through as usual!! Sorry I bug you so much!!!!
  15. Jun 14, 2019 at 5:43 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    So to revive an old threat, but this is the closest I can find to my issue.
    While I am ordering the driveshaft spacer and waiting for it to come in, can I drive the truck gently?
