Fuse question
Discussion in 'General Tundra Discussion' started by Benstoy, Jan 19, 2019.
  1. Jan 19, 2019 at 10:40 AM
    Benstoy
    Benstoy [OP] New Member
    2008 Tundra Crew Max 4x4
    3/1 ready lift, added step bars, blue tooth, back up camera, assault roll up tonneau cover...has spray in liner, fender flares, leather
    I'm running wiring for aftermarket heated seats. The fuse box has one 20amp fuse labeled seat heater and then theres a blank slot under it. Am I to assume that I can throw a 20amp fuse in that blank slot for the additional seat? 2 seats = 2 20amp fuses, not one, so I am assuming that both slots are intended for each seat.
    Thanks for the help.
  2. Jan 24, 2019 at 8:47 AM
    Tuham817
    Tuham817 New Member
    2014 SR5 Crewmax
    Bump for an answer. I'd like to know as well!
  3. Jan 25, 2019 at 8:53 AM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
