Humidity Inside Cab
Discussion in '2.5 Gen Tundras (2014-2021)' started by GbRunner10, Jan 18, 2019.
  1. Jan 18, 2019 at 7:36 AM
    GbRunner10
    GbRunner10 [OP] New Member
    Hey Guys!
    Since the cold winter temperatures have hit, I've been having issues where the inside of my windows are frosting up. I've checked my carpets and everything is dry. All my windows are closed so I don't think anything is coming in through them.
    I don't drive my truck very often, but when I do I always run the heater on high to hopefully remove some of that moisture in the cab... but it always comes back!
    Does anyone have experience with this issue? This is my first vehicle that this happens to.
    2018 Crewmax. NB, Canada
  2. Jan 18, 2019 at 7:40 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Could happen if you drag snow into your truck on your shoes and mats stay wet. Could be just that it's humid where you live?
    Nmanning556 and JoshuaA like this.
  3. Jan 18, 2019 at 7:41 AM
    jlind
    jlind New Member
    2016 Tundra Limited CM
    You should be running your heater with the defroster setting or running the air conditioner if you're trying to eliminate condensation or moisture. Warm air holds more moisture than cold air. Because of this, you want it to run through a condenser.
    Nmanning556, JoshuaA and 15whtrd like this.
  4. Jan 18, 2019 at 7:43 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Does it smell musty or sweet in the cab?
    Nmanning556 likes this.
  5. Jan 18, 2019 at 8:00 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Your AC is a big dehumidifier, use it.
    Trooper2 likes this.
  6. Jan 18, 2019 at 8:24 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Welcome :canada:
    New truck shouldn’t do that, make sure it’s not on the HVAC recirculate function. Is the air filter inside the glove box clogged with leaves? You check around the windshield, around the sunroof if you have one for leaks, UNDER the mats for moisture? After you check the filter, blast the cabin out with A/C while leaving a crack of window open. Close it up and if it happens again, take it in for a check under warranty. It shouldn’t be anything serious being 2018 but you never know.
  7. Jan 18, 2019 at 8:36 AM
    Nmanning556
    Nmanning556 New Member
    VA
    2015 Crewmax SR5 4x4
    Sunroof? Park under trees?
  8. Jan 18, 2019 at 8:51 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    A coworker of mine is having condensation issues on his 6-month-old 2018 as well. I'd definitely take it in and have them check for leaks. I thought I heard somewhere that the rails/tracks on the roof under the plastic sometimes aren't sealed properly, so you might want to check there.
  9. Jan 18, 2019 at 9:06 AM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    you need to remember that warm air holds a lot more moisture than cold so when you have the heat blasting you'll gain moisture from the snow melting and evaporating as well as when passengers exhale. now you park your truck and the air inside starts to cool loosing it ability to hold all that moisture that was introduced thus creating the frost. the quick and easy way to remove that moisture before you park the truck is to open all your windows as you're driving and let the warm moist air get replaced with cool dry air. I usually do this for about 30 seconds just before I pull in the driveway
    Rex Kramer likes this.
  10. Jan 18, 2019 at 9:24 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Shot in the dark:
    Before you shut off the truck for the day, press the recirculate button
  11. Jan 18, 2019 at 9:38 AM
    GbRunner10
    Thanks for all the responses! When I run the heat ill try it with the AC function and I'll also try the window trick before I park.
    I don't think the cabin filter would be full of junk as the truck only has 5000 ish miles where 1700 of those happened during the holidays. I'll still pull it once it warms up to see if its humid though.
    @BuckWallace If you hear anything from him let me know!
