Bully Dog GT mpg's
Discussion in 'Performance and Tuning' started by Brad90, Jan 17, 2019.
  1. Jan 17, 2019 at 10:53 PM
    Brad90
    Brad90 [OP] New Member
    Brad
    2013 Tundra Crewmax Rock Warrior
    aFe Power Magnum Force Stage 2 SI PRO-DRY S intake, aFe Mach Force XP exhaust, 3 inch leveling kit, DVB front bumper, tri-fold tonneau cover.
    I've been running the BD for almost a week now. It has noticeably more power on premium tune. I was more interested in gaining gas mileage, but it doesn't seem to help at all. For the first couple days I went from just over 16 mpg (without the BD) to 13.4 (with the BD). As of today, it has increased to 15.5 mpg. I'm at a half tank left of 93 octane so when I fill up next with 87, I will try to performance tune then the tow tune to see what gets the best mpg's. Anyone else have any input on using the BD?
  2. Jan 18, 2019 at 8:15 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    Ive never tested for mpg. Just power!!
    But I have a lot of customers telling me that they’re seeing better mpg.
    I’d say give it a tank or two before switching tunes.
  3. Jan 18, 2019 at 8:22 AM
    15whtrd
    15whtrd Mr. Blonde
    I suggest adjusting the throttle sensitivity as that may contribute to some of the mpg loss. Not because of the tune but more because of your foot LOL
    nlaroy likes this.
  4. Jan 18, 2019 at 8:50 AM
    Brad90
    Brad
    I've been very easy on the throttle. I like how the transmission doesn't seem like it's searching for gears now. Stock it was like the torque converter wouldn't stay locked in.
  5. Jan 18, 2019 at 8:52 AM
    dirtydeeds
    Keith
    USA
    Oh ya. Good point!!
    Stock throttle or trail throttle will certainly net the best mpg
    15whtrd likes this.
  6. Jan 18, 2019 at 9:05 AM
    Brad90
    Brad
    I'll eventually change my tunes after I try my 3 I have downloaded. I'm still impressed with it though.
  7. Aug 10, 2019 at 12:28 PM
    Russ389
    Russ389 New Member
    First of all I wouldn’t waste my money on 93 octane unless you have increased compression in that motor by some modification If anything running 93 as a post to 87 probably hurt your gas mileage because 93 is too cold in the stock motor to burn completely octane measurement is just a resistance from detonation it doesn’t have any more power
  8. Aug 10, 2019 at 12:37 PM
    15whtrd
    15whtrd Mr. Blonde
    Unless you are using the 93 octane tune in the bully dog. It’s required if you’re running that tune.
    AZTundra likes this.
  9. Aug 10, 2019 at 2:26 PM
    Tundra_power
    Tundra_power New Member
    That is correct the performance tune requires 93 octane to be safe. I did try running 87 in performance tune and there was pinging so for me i reccommend for a daily driver regular tune with 87 octane. Is the trail throttle sensitivity above stock or below as for performance goes.
    15whtrd[QUOTED] likes this.
  10. Aug 10, 2019 at 3:08 PM
    15whtrd
    15whtrd Mr. Blonde
    I haven’t used the trail tune yet, I have adjusted the sensitivity back to stock for the throttle. If I need it to feel peppy, I just hit tow haul. That way if I’m off road, the stock throttle response is less touchy and acceleration over bumps is less jerky.
