CLOSED: Deaver Leaf Springs & ADS Rear Shocks Group Buy
Discussion in 'Deals & Group Buys' started by UTTundra, Feb 21, 2018.
  1. May 23, 2018 at 1:56 PM
    #181
    UTTundra
    UTTundra [OP] New Member
    Lou
    Utah
    How much thread do you have showing? What is the lb rating of your springs? Did they settle some after you drove?
    I only have 2.5's with 650 lb springs, but when I first got them they gave me about 2" on driver and 3" on passenger. The installer didn't know they were preset to give me a certain height, so they messed with them. I was able to adjust the driver's side on the truck to get within 1/4" of the passenger.
    TheBeast likes this.
  2. May 23, 2018 at 2:05 PM
    #182
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Holy crap.
    CVs have got to hate you right now. I feel bad at 3".
  3. May 23, 2018 at 4:11 PM
    #183
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    650 lb springs. Zero threads on the passenger side and maybe 3/8 on the driver side.
    I haven’t driven it yet nor have I had the alignment done. It is been sitting on jackstands because the wheels are at powder coat. I suspect that it will settle tiny bit and maybe more after the aligned.
    UTTundra[QUOTED][OP] likes this.
  4. May 23, 2018 at 4:17 PM
    #184
    14burrito
    2014 SR5 CM 4x4 5.7
    IIRC min lift from the 3.0s was like 2.76" so being at 4....damn
  5. May 23, 2018 at 4:40 PM
    #185
    UTTundra
    Lou
    Utah
    Any time I mess with my suspension, or even jack the front end up, it always sits really high. It usually settles down quite a bit with just a quick drive.
  6. May 23, 2018 at 6:11 PM
    #186
    JohnH
    JohnH From PA
    Pennsylvania
    I wanted 2-3 inches...
  7. May 23, 2018 at 6:11 PM
    #187
    JohnH
    JohnH From PA
    Pennsylvania
    I will hope for that. Thanks for the hope.
  8. Jan 17, 2019 at 5:20 PM
    #188
    SmokeyTT
    SmokeyTT Smokey The Tundra
    Oahu
    2018 SR5 Off-Road 4x4 Crewmax
    How many inches of lift do you get in the rear when pairing MCM or TC 3/4" shackles and Deaver K37/U748? 2018 Tundra Crewmax
  9. Jan 17, 2019 at 6:01 PM
    #189
    JohnH
    JohnH From PA
    Pennsylvania
    MCM shackles with U748 gave me 1 1/2”.
    SmokeyTT[QUOTED] likes this.
  10. Jan 17, 2019 at 8:43 PM
    #190
    TheBeast
    TheBeast The Beach
    I got a bit over 1" with K37s and MCM shackles.
    SmokeyTT likes this.
  11. Jan 17, 2019 at 9:06 PM
    #191
    SmokeyTT
    Oahu
    You’d say 1.5”?
  12. Jan 18, 2019 at 11:26 AM
    #192
    TheBeast
    TheBeast The Beach
    more like 1.25" ish..but then again it might be the way I measured too.
  13. Jan 22, 2019 at 3:04 PM
    #193
    SmokeyTT
    Oahu
    Are the MCM shackles and TC ones the same specs? 3/4"?
  14. Apr 1, 2020 at 2:14 AM
    #194
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    I think so.
    What are the chances of this group buy kicking off again?
    tarathetundra likes this.
  15. Apr 10, 2020 at 12:51 AM
    #195
    tarathetundra
    tarathetundra New Member
    Nate
    2018 white CM
    37x13.50R18
    I saw that the thread is closed but I am also interested if a group buy would kick back off again. What vendor is this through? Mcm? Thanks!
    Flyinryank likes this.
