DIY RIGID TRD PRO Fog Lights Brackets
Discussion in '2.5 Gen Tundras (2014-2021)' started by tanabersx, Jan 13, 2019.
  1. Jan 13, 2019 at 11:36 AM
    tanabersx
    tanabersx [OP] New Member
    Miguel
    Puerto Rico
    2017 Tundra DC SR5 XP
    First of all I want to give the credit to @Neshra54 and all the other guys in his thread on how to do this. This is his thread: https://www.tundras.com/threads/diy-trd-pro-rigid-fog-lights.34224/
    Didn't post this on his thread for not to thread-jack it.
    You are going to need:
    -TRD Pro Fog Bezels @Roman can help you with that.
    https://parts.toyotaofcoolsprings.c...-bezel-right-hand-tundra-trd-pro-pt22834190aa
    https://parts.toyotaofcoolsprings.c...t-bezel-left-hand-tundra-trd-pro-pt22834190ab
    -Rigid D-series fog (don't know if any other will fit)
    -h11 to deutsch adapter harness
    After some tweaking and measuring I was able to CNC my brackets. Did them in structural aluminum which is way stronger than regular aluminum. My goal here is to help everyone here that wants to do this mod. Here is how they ended up:
    For everybody that is wondering, you do have to measure and drill a 3/8" hole in your fog light/bumper back plate. All of this is covered by the wheel liner so none of this is exposed. Here is a thread on how to remove that: https://www.tundras.com/threads/2018-led-fog-light-installation-instructions-w-pics.18346/
    The position of this hole will depend entirely on where do you want your fogs pointing at and how do you set up the fog bracket. With this said, the position will be different for everybody.
    Here is the hole I drilled so you get an idea.
    The trick here is to measure and point the fog already installed and hand tighten in the fog bracket and support bracket, measure and then tight everything outside, re-check and then tighten the support bracket to the frame. After you decide where you want your fogs pointed(I suggest doing this with trucked leveled in front of a wall), there is only about 1/4" to play up/down/left/right with the fog so you don't have much room for error here. There is not much space to tighten things inside that area unless you have really small and flexible hands, also the right tools. Don't worry you can always extend the holes on the support brackets if you miscalculate something, no biggie.
    As for the support brackets here is how I can help you guys. I'm able to get this brackets with all stainless steel hardware from a friend that owns an aluminum shop. Again, this is not to profit from this, this is very time consuming for me and believe me, I got a million other things to do that I really profit from. This is what he can do for us:
    Structural aluminum brackets with pre-drilled holes, all stainless hardware, no rust, no breaking.
    UPDATE: PRICE IS $19 for both brackets and hardware shipped to CON-US. He already has a few of them ready. This brackets will have rough edges, that really makes no difference. This is just to lower fabrication costs. If you want soft round edges you can always give it a quick sanding.
    Let me know if somebody is interested and I'll start shipping them.
    I also made my own harness adapters, was planning on adding them to the package but don't really have time for that you are better of ordering them from Amazon or ebay.
    Thanks a lot and let me know if you guys are interested.
  2. Jan 13, 2019 at 11:46 AM
    Augparra
    Augparra New Member
    Domingo
    2014 Limited TRD crewmax
    So clean. Nice job
  3. Jan 13, 2019 at 12:45 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Nice job!
  4. Jan 13, 2019 at 12:52 PM
    tanabersx
    Miguel
    Puerto Rico
    Thanks!!
  5. Jan 13, 2019 at 12:54 PM
    Added to DIY sticky
  6. Jan 13, 2019 at 1:46 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    If this gets off the ground, Count me in!
    I am interested in the brackets,
  7. Jan 13, 2019 at 1:51 PM
    tanabersx
    Miguel
    Puerto Rico
    :benchpress:
  8. Jan 13, 2019 at 2:16 PM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
  9. Jan 13, 2019 at 2:17 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    nice! I'd buy some brackets
  10. Jan 13, 2019 at 2:41 PM
    charliebison
    charliebison New Member
    I’d buy!
  11. Jan 13, 2019 at 3:54 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’d buy a set
  12. Jan 13, 2019 at 3:59 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Great job!
    Looks like Rigid may be soon releasing a redesign/new fog brackets for their lights. Curious what it may look like and if their light bouncing issue will be resolved.
  13. Jan 13, 2019 at 4:13 PM
    tanabersx
    Miguel
    Puerto Rico
    With this bracket the fogs are solid AF. Don't think rigid will re-design as they are not going to use Toyota's fog bezel or make you drill a hole. They try to do their kits as bolt on as possible. If they invest a little time and money on this, they can make something similar bolt on but still will need to use another bezel.
    Tundradrenalin likes this.
  14. Jan 13, 2019 at 4:13 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    That is one clean job!
  15. Jan 13, 2019 at 4:16 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I don't doubt yours are solid. People have been doing those for years to add rigidity to the rigid brackets.
    Iv been talking with Rigid and complained to them in person showing them their bracket weakness and online complaints.....sounds like they will be doing something for a redesign, timeframes? unsure. I agree they will probably not ask the end user to drill though.
  16. Jan 13, 2019 at 4:20 PM
    tanabersx
    Miguel
    Puerto Rico
    Thank you sir!
  17. Jan 13, 2019 at 7:16 PM
    Tundraguy12
    Tundraguy12 New Member
    David Myers
    2015 Black Tundra TSS CrewMax
    Winjet Tails 5% Tint all around
    Looks good
  18. Jan 14, 2019 at 4:41 AM
    tanabersx
    Miguel
    Puerto Rico
    UPDATE ON THE PRICE!! READY TO SHIP. PM ME FOR INFO. WILL BE SHIPPING FIRST BATCH TOMORROW AND A SECOND ONE ON WEDNESDAY. LMK
    MTG-MAN and 14burrito like this.
  19. Jan 14, 2019 at 5:53 AM
    Devildawg712
    Devildawg712 New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    nice! Pmd
  20. Jan 14, 2019 at 7:01 AM
    cjscinta
    cjscinta New Member
    Nashville TN
    I could have used these a few weeks ago when I did mine. Would have saved me a lot of trouble. Oh well.
  21. Jan 14, 2019 at 8:38 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
  22. Jan 14, 2019 at 8:50 AM
    mesaboogieman
    mesaboogieman New Member
    Joe
    Black 2014 Toyota CM Limited
    Looks great!
  23. Jan 15, 2019 at 7:02 AM
    tanabersx
    Miguel
    Puerto Rico
    Shipped the first round today, all tracking #'s sent. If you didn't receive your tracking today, it will go out tomorrow so you will receive it then.
    Thanks.
    stuckinohio and Tundradrenalin like this.
  24. Jan 15, 2019 at 11:28 AM
    mesaboogieman
    Joe
    I didn't even know that I wanted this until I saw this thread. I should know by now that any visits to this site will correlate to a lighter wallet for me :spending:
    bulldog93 and Tundradrenalin like this.
  25. Jan 16, 2019 at 10:46 AM
    tanabersx
    Miguel
    Puerto Rico
    Second batch shipped today! I believe all orders are shipped now.
  26. Jan 17, 2019 at 4:27 PM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    Received the brackets and hardware today. Thank you!
    Also, thank you for de-burring the holes.
  27. Jan 17, 2019 at 5:40 PM
    tanabersx
    Miguel
    Puerto Rico
    You’re welcome!!
  28. Jan 17, 2019 at 11:41 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    I’ll take a set
  29. Jan 18, 2019 at 3:59 PM
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    I bought the brackets and installed them a few days ago. Zero complaints.
    Could you buy your own brackets and hardware for less money? Probably. But the convenience of having them delivered to me and not having to buy anything myself was worth the few extra bucks. I’m also happy to support someone else who took the time to make my life easier.
    Thanks!
  30. Jan 18, 2019 at 10:57 PM
    Devildawg712
    Union City, Ca
    Had a bit of an issue with the locknut so I ended up using a regular nut with a lil bit of locktite. Everything else was a breeze. Extremely Happy.
