What was your OEM Battery Replacement?
Discussion in '2.5 Gen Tundras (2014-2021)' started by geno0506, Nov 13, 2018.
  1. Jan 14, 2019 at 12:39 PM
    #61
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    Before
    And after. (X2 Power Northstar)
    The battery I replaced appeared to be the factory original. I figured that after six years I was pushing my luck on either a cold winter start, or a hot weather failure.
  2. Jan 14, 2019 at 6:17 PM
    #62
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    My air traffic control lighting system was approved but still am waiting for the missle system approval. Hence why I have the Genesis system with dual oddessey batteries
  3. Jan 14, 2019 at 6:24 PM
    #63
    Tundraguy12
    Tundraguy12 New Member
    David Myers
    2015 Black Tundra TSS CrewMax
    Winjet Tails 5% Tint all around
    Some advance auto parts battery, to me a battery is a battery. Although some do look cool lol
  4. Jan 14, 2019 at 6:37 PM
    #64
    LML 3500HD
  5. Jan 15, 2019 at 12:50 AM
    #65
    1BlinkGone
    1BlinkGone New Member
    One thing I learned about East Penn/Deka making batteries for others:
    "The battery of choice at O’Reilly Auto Parts, and CSK Auto stores is a Super Start Battery. Super Start batteries are manufactured by East Penn Manufacturing. East Penn is well know for their Dependable Deka battery brand. East Penn manufacturing is located in Lyon Station Pennsylvania, and have been manufacturing batteries sense 1946. The Super Start Premium battery has a 12 month free replacement and a 60 month pro rate warranty. The Super Start Extreme battery offers 3 year free replacement and 84 month pro-rate warranty. The Super Start Premium battery warranty is nothing to get excited about, however the Super Start Extreme is a very industry competitive battery warranty."
    I do have the SuperStart battery aforementioned, from AutoZone. One thing I learned from somebody who used to work in that side of the parts bis is this...when it comes to 24, 36, etc mo rated batteries- more often than not (but not always) when you opt for a longer-term celll, its' not so much that you're buying a better battery inasmuch as you are buying a better Insurance Policy err, Warranty for it; even though the cases may look different, oftentimes they are the same internally. This is not a 100% across the board fact, and there are exceptions. The Bosch battery took a dump in our Passat and we replaced it with a Super Start. So far, so good....
    16 blue crewmax and equin like this.
  6. Jan 28, 2019 at 5:55 AM
    #66
    socal147
    socal147 None Specified
    Patrick
    Oak Hills Commiefornia
    2019 Tundra Tonka
    Stock is so temporary
    I can't see waiting for a stock battery to fail to replace it. Under warranty or not. My battery is only 200 miles old. Probably wait until the three year mark to change it out. The heat here kills batteries.
    I won’t wait for a failure ...
    driverdog likes this.
  7. Jan 28, 2019 at 7:42 AM
    #67
    SpacecoastHusker
    SpacecoastHusker New Member
    Brevard County, FL
    2014 Toyota Tundra Limited CM
    Bought my '14 CM a couple of months ago. Replacing the original OEM battery (with another OEM) was the first thing I did.
  8. Jan 29, 2019 at 2:22 AM
    #68
    rodm1
    rodm1 New Member
    Where did you order those post mounts?
  9. Jan 29, 2019 at 11:49 PM
    #69
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    :popcorn: or use the stock battery holder as its not far off from a 27r and add longer aftermarket posts such as the audio clamps mentioned elsewhere in this post so stock wires can be left alone?
  10. Jan 30, 2019 at 4:23 AM
    #70
    Ericsopa
    Ericsopa Old man and the sea
    Northstar NSB AGM 27F. Odyssey Extreme is good too; have two of them in my boat.
  11. Jan 30, 2019 at 5:43 AM
    #71
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    My OEM battery lasted 5yrs. I was originally going to get an optima, but it seems they aren’t what they use to be.
    Went with a Duracell from Battery+ store. Has been fine this winter.
  12. Jan 30, 2019 at 5:46 AM
    #72
    AZTundra
    Paul
    Phoenix, AZ
    My original battery failed after 13 months and about 25K miles. It was replaced with another OEM from Toyota free of charge.
  13. Jan 30, 2019 at 7:30 AM
    #73
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    Just bought a used 15 recently. Probably replacing the battery. No clue on how on old it is. Looks original. Have had good luck with interstates.
  14. Jan 30, 2019 at 7:35 AM
    #74
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    From Amazon, they are GP audio brand
  15. Feb 3, 2019 at 10:50 PM
    #75
    FossilHunter
    FossilHunter New Member
    2017 Tundra TRD 4x4 Double Cab
    Northstar
  16. Feb 4, 2019 at 4:21 AM
    #76
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I just ordered one....because....70lbs., ;)
  17. Feb 4, 2019 at 5:36 AM
    #77
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Still running the original OEM battery as far as I can tell. 14 years old, still fires the truck up in -40C weather. LOL.
    I'll be replacing it this spring with an Odyssey AGM.
    Black Wolf likes this.
  18. Feb 11, 2019 at 9:17 AM
    #78
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    that thing looks beast!
    NewImprovedRon likes this.
  19. Feb 11, 2019 at 11:23 AM
    #79
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It is, and you should try heaving it over the radiator support without mashing a finger. :muscleflexing:
  20. Feb 11, 2019 at 11:34 AM
    #80
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Indeed! I may even have to readjust my driver's headlamp aim after setting that thing in there. Weighty.
    RitcheyRch and NewImprovedRon like this.
  21. Feb 11, 2019 at 12:19 PM
    #81
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I went Diehard AGM Gold, previously had AGM Platinum but they didn't seem to have that model anymore so I went with Gold.
    1UPPER[QUOTED] likes this.
  22. Feb 18, 2019 at 5:31 PM
    #82
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    IMG_20190218_203015.jpg Bought my 2015 SR5 in Aug of 2018.
    Proactively replaced the OEM battery in Nov 2018 with Autocraft AGM from Advance Auto...
    DEFINITELY replace an OEM with an AGM.
    Worth the extra coin.
    Black Wolf and NewImprovedRon like this.
  23. Mar 1, 2019 at 8:22 PM
    #83
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    X2 27F battery along with an Amazonhold down and some upgraded ground cable
  24. Mar 2, 2019 at 2:29 AM
    #84
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Duralast Gold :D
  25. Mar 2, 2019 at 2:55 AM
    #85
    timsp8
    NY
    Genesis dual kit with 2x Odyssey’s.
    fundra_goes_west likes this.
  26. Mar 28, 2019 at 3:26 AM
    #86
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    How you like this battery?
  27. Mar 28, 2019 at 4:47 AM
    #87
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Mine just went out literally the day after the two year warranty expired. Decided to bail on the prorated trade-in though and go with a Duracell Gold. $139 w/3 year warranty.
  28. Mar 28, 2019 at 8:53 AM
    #88
    Haggis777
    SW Michigan
    So far so good! Picked it up at Sam's Club...they have an excellent warranty replacement if a person needs to exercise it. AGM is THE way to go!
  29. Mar 28, 2019 at 9:06 AM
    #89
    Outbound
    Aaron
    Northern Alberta
    What terminal attachments do you have there? They look really handy for easily adding lightbars.
    Randy Morton[QUOTED] likes this.
  30. Mar 28, 2019 at 10:16 AM
    #90
    Randy Morton
    Randy
    Toyotoholic and Outbound[QUOTED] like this.
