  1. Jan 13, 2019 at 4:43 PM
    #3241
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    going up an incline w/o downshifting is impressive - LOL.
  2. Jan 13, 2019 at 5:56 PM
    #3242
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Mine down shifts like a mother.. coming it decides to come out of overdrive sits there for a little and if the hill continues bumps it down again to about 3,000 rpm and hangs there until flat ground.
  3. Jan 13, 2019 at 6:07 PM
    #3243
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    I'm pretty impressed at how smooth & non-frantic my trans is.
  4. Jan 13, 2019 at 6:10 PM
    #3244
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Got the steering rack on... kinda.
    Got the outside tie rods on. Couldn't get the right tool to remove the inner ones. Was going to go at it with a pipe wrench but remembered I left my plumbing tools at my brother's house. Left the old ones on, they're broken in for sure but I cant see them making a problem.
    Tightened up my lower ball joints, cleaned and reinstalled my brakes. Replaced the passenger side reservoir mount with a painted one. Filled upper arm bushings with a grease gun. Still need to do a few small things.
    • Replace driver side reservoir mount
    • Warranty replace battery while it's out?
    • Tighten that damn middle bolt on the steering rack. It's such a pain to get too, I remember there is a trick to it but can't remember the trick.
    • Top off steering fluid
    • Top off radiator
    • Zip tie steering boots
    • Install coilovers
    • Install tires and drive around the parking lot to bounce the suspension, then tighten upper arms
    • Go get alignment
    Easy :cool:
  5. Jan 13, 2019 at 6:12 PM
    #3245
    Filthyphil
    Phil
    Hmm maybe shift points are different in the 03 tranny? Idk that’s my biggest complaint on my truck.
    TX-TRD1stGEN likes this.
  6. Jan 13, 2019 at 6:16 PM
    #3246
    antnat96
    antnat96 New Member
    Anthony
    Charlotte, NC
    Beige 2001 Tundra Access Cab SR5 2WD
    Honestly...beats me. It's a Maryland truck and hasn't had a frame replacement yet, so you'd think it'd be all rusty, but it's just got a couple surface bits here and there. I did use some PB blaster and bang the hell out of those old calipers with a hammer though so the mounting bolts would come off easier though :curls:
    Still using rubber hoses. Perhaps I'll upgrade in the future. Do you think that could have anything to do with the slightly longer brake travel?
  7. Jan 13, 2019 at 6:28 PM
    #3247
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    I don't think you'd get a diff b4/after because of rubber hoses, well not longer travel. That's likely different hardware or air in the line.
    antnat96[QUOTED] likes this.
  8. Jan 13, 2019 at 7:03 PM
    #3248
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you did the 13WL caliper update it typically takes a little more push on the pedal. You'll get used to it.
    antnat96 likes this.
  9. Jan 13, 2019 at 7:11 PM
    #3249
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Rusty vs painted. Knew I should have painted these before installing.
  10. Jan 13, 2019 at 7:40 PM
    #3250
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I figured that was the vvti kicking in kinda like vtec lol
  11. Jan 13, 2019 at 7:42 PM
    #3251
    because_wumbo-truck
    Jon
    Houston, Texas
  12. Jan 13, 2019 at 10:59 PM
    #3252
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    Gonna squeeze this in before midnight. :D Filled the gas tank up this morning then added 1-1/2 cans of SeaFoam then proceeded to drive 100 miles on 1/4 tank. Considering that my last fill up was 200 miles on 3/4 of a tank, I'm happy.
  13. Jan 14, 2019 at 2:36 PM
    #3253
    Professional Hand Model
    Fred
    Hand Protectors
    Took about and hour total. Tools needed pictured. A metal blade in the sawzall made for nice clean cuts in the plastic. Very happy with the outcome. Will spray flat black on the aluminum freon lines to mask their appearance.
    BestGen, NUDRAT, Filthyphil and 2 others like this.
  14. Jan 14, 2019 at 2:39 PM
    #3254
    Fred
    Hand Protectors
  15. Jan 14, 2019 at 3:47 PM
    #3255
    FirstGenVol Brake Czar
    2002 AC
    That looks great. Remind us again who makes those.?
  16. Jan 14, 2019 at 4:07 PM
    #3256
    Fred
    Hand Protectors
    Grillcraft.
    Darkness and because_wumbo-truck like this.
  17. Jan 14, 2019 at 4:33 PM
    #3257
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sounds like a bbq :dancingbacon:
    BestGen, FlightSimGuy and Casper421 like this.
  18. Jan 14, 2019 at 4:37 PM
    #3258
    Fred
    Hand Protectors
    I was thinking the same. This grill could put some serious hashings on some beef.
    Darkness[QUOTED] likes this.
  19. Jan 14, 2019 at 4:40 PM
    #3259
    because_wumbo-truck
    Jon
    Houston, Texas
  20. Jan 14, 2019 at 4:42 PM
    #3260
    Fred
    Hand Protectors
  21. Jan 14, 2019 at 4:51 PM
    #3261
    sharmstr
    sharmstr New Member
    2003 SR5 V6
    FJ Wheels, EGR Fender Flares, Snugtop w/rack.
  22. Jan 14, 2019 at 5:10 PM
    #3262
    Fred
    Hand Protectors
    Ordered a little 5” x 1” Toyota Emblem to complete the style I want.
    Conceptual Design
  23. Jan 15, 2019 at 6:53 AM
    #3263
    2002 AC
    Jerry, can you tell me about these reverse lights you mounted? Which did you buy? How was the install? Etc. Now that I have this camper shell on my truck visibility, especially at night, is going to be limited. I need to do this.
  24. Jan 15, 2019 at 7:15 AM
    #3264
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Quite a bit like mine but I put mine on the rear fender just above mud flap territory.
    His may get more rise if he is closer to the bumper, mine use the bumper as a natural cutoff.
  25. Jan 15, 2019 at 8:17 AM
    #3265
    HappyTrails
    HappyTrails New Member
    2000 Tundra SR5
    None
    In the month I’ve had mine:
    8 new plugs
    1 new ignition coil
    Replaced blower motor
    New AC control knobs
    Replaced all 4 O2 sensors
    Replaced fuel filter
    Replaced power steering pump and belt
    Flushed radiator
    New led dome light. So bright!
    More to come.....
  26. Jan 15, 2019 at 9:34 AM
    #3266
    2002 AC
    That one is kind of random.;) Did you find some neat aftermarket knobs or did the old ones break?
  27. Jan 15, 2019 at 10:08 AM
    #3267
    HappyTrails
    2000 Tundra SR5
    None
    And I didn’t mention changing the lights behind them. My sister had it for a few months and broke them off. Three new ones 15 bucks on Amazon.
  28. Jan 15, 2019 at 10:18 AM
    #3268
    sharmstr
    sharmstr New Member
    2003 SR5 V6
    I'm such an idiot that I didnt even realize there were lights behind them. When I first got the truck I thought "what a shit design. how are you supposed to see the controls at night". I even remember looking for them when I took the dash apart to install my new head unit. It wasnt until I saw a post in this thread that I realized there were bulbs. Idiot!
  29. Jan 15, 2019 at 10:25 AM
    #3269
    HappyTrails
    2000 Tundra SR5
    None
    I didn’t think about it either until the new mobs came. Can tell a light sits behind each one, illuminating it. They were easy. Mine were clear with a green rubber on them. Could not find green ones so went with amber.
  30. Jan 15, 2019 at 10:30 AM
    #3270
    sharmstr
    sharmstr New Member
    2003 SR5 V6
    Yep. Replaced mine with white leds last week.
    Deslock23 likes this.
