*PLEASE VOTE HERE* Who DOES/DOES NOT have a leaking cam tower seal?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BuckWallace, Feb 21, 2018.
Have you had a leaking cam tower?
  1. Yes - 2nd gen (07-13) Non-FFV
    16 vote(s)
    3.7%
  2. Yes - 2nd gen (07-13) FFV
    14 vote(s)
    3.2%
  3. Yes - 3rd gen (14+) Non-FFV
    34 vote(s)
    7.8%
  4. Yes - 3rd gen (14+) FFV
    19 vote(s)
    4.3%
  5. No - 2nd gen (07-13) Non-FFV
    34 vote(s)
    7.8%
  6. No - 2nd gen (07-13) FFV
    8 vote(s)
    1.8%
  7. No - 3rd gen (14+) Non FFV
    175 vote(s)
    40.0%
  8. No - 3rd gen (14+) FFV
    138 vote(s)
    31.5%
  1. Dec 22, 2018 at 7:30 PM
    #181
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    That's exactly how the Toyota dealer did my trucks repair. They did not remove the timing cover as I have seen in other videos, which also tells me why they were hesitant to complete the driver side even though it wasn't leaking. If the tech takes off the front cover then it makes a lot of sense to complete both sides.
    Buck Wallace I'm with you on this, I was extremely disappointed by this issue and its pretty much determined I probably wont keep the truck after powertrain warranty is up. I will also say you need to change your oil a bunch after the repair, I did my first change after 500miles and had all kinds of gasket material and wire wheel pieces in the filter. It took me almost 18,000 miles before I finally got a filter without any debris when I changed it. I have put 19k miles on mine now since the repair, its not leaking but I swear the side they repaired has a kind of knocking noise to it when its hot outside and I always have the worry in my mind about all the crap that was flowing though my engine.
  2. Dec 22, 2018 at 7:31 PM
    #182
    BuckWallace
    BuckWallace [OP] Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    I could go with "meh" if I was just replacing a simple gasket on a truck with 100k miles after working it hard, but I drive like a grandpa and my truck is barely a year old with less than 9k miles and needs the top end broken open, so "meh" isn't gonna cut it with me.
    GlobalGuy, jtwags and parallax like this.
  3. Dec 22, 2018 at 7:33 PM
    #183
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    This is everyone's attitude on here , its a leak just happens no big deal. Yes on terms of it not being a catastrophic failure its not a big deal, but buying a vehicle this expensive and as old a platform as it is to leak its a big deal IMO. My Tundra is the only vehicle I have ever had to develop an oil leak at less then 150k miles...that's pretty sad. Leaking engine oil at 21k just shouldn't be acceptable.
    GlobalGuy, jtwags, equin and 2 others like this.
  4. Dec 22, 2018 at 7:37 PM
    #184
    BuckWallace
    Oregon
    This is my biggest issue. The fact that Toyota has an "updated" FIPG sealant that it gives mechanics for this repair acknowledges they know it's a problem. Why they don't use the "updated" FIPG sealant from the beginning just blows my mind. If this is a permanent fix, why the hell don't they permanently fix it when it's initially assembled?
    GlobalGuy, equin and georgiey22 like this.
  5. Dec 22, 2018 at 7:52 PM
    #185
    Vizsla
    Vizsla ☠️☠️☠️
    I kinda agree, but I’ve owned lots of vehicles, and used to own a construction company that had many vehicles. It is what it is. Life is way to short to worry about man made things doing what man made things do. It gets fixed, move on, or drive yourself bonkers. One makes sense, the other does not.
    It’s not updated, just a different color. I’m dead serious. Has much more to do with the surfaces being cleaned properly than anything else. Just so you know it is not a permanent fix, there is myself, and another member on here that had failures after the fix. Again it boils down to the details, has to be completely perfectly clean. Don’t sweat it, will be fine.
    jtwags and NjPro like this.
  6. Dec 22, 2018 at 7:55 PM
    #186
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    My thoughts exactly, only thing I figure is they are rolling the dice on if it leaks or not and its cheaper for them to just repair those that will leak during the warranty period. Its not the right thing to do by the consumer but it happens with all manufacturers not just Toyota.
    jtwags likes this.
  7. Dec 22, 2018 at 7:56 PM
    #187
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I have a ‘19 but too few miles to see a leak. Will keep checking weekly.
    Ronin73 likes this.
  8. Dec 22, 2018 at 8:01 PM
    #188
    parallax
    parallax Professional Zamboni stunt driver
    Oregon
    2018 White Tundra Crewmax SR5 5.7 TRD 4x4
    Dash camera
    Update from post #161
    2018 tundra crew max TRD. With 4112 miles. Both sides are leaking dropped off at dealership last week. They said. Maybe another week before it’s fixed Disappointed a $39,000 Truck would have an engine leak at 4112 miles
    jtwags likes this.
  9. Dec 23, 2018 at 6:23 AM
    #189
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    So what would fix all of this from the start, and whatever that fix is, maybe the 2019 builds have it?
  10. Dec 23, 2018 at 6:54 AM
    #190
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    A different gasket design would fix it. Using a form-in-place gasket material on two flat surfaces is just not a good design - too many possible failure modes.
    jtwags and Ronin73[QUOTED] like this.
  11. Dec 23, 2018 at 9:30 AM
    #191
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Well.............. 2017 with 26350 miles. Drivers side leak. Can't really see one on the passenger side. Dealership visit planned for next week sometime.
  12. Nov 4, 2020 at 5:02 PM
    #192
    70 FJ40
    70 FJ40 New Member
    Max
    '16 Tundra SR5 TRD 4X4 Double Cab
    Just purchased a '16 double cab flex fuel. Nearly 38,000 no leaks yet and doesn't have that issue listed on the carfax.
    Black Wolf likes this.
  13. Nov 4, 2020 at 5:11 PM
    #193
    Aurora CO
    My 14 at 117K has no cam tower issues. My 07 that I had....had no cam tower issues at 99K.
  14. Nov 4, 2020 at 5:30 PM
    #194
    fbingha
    fbingha New Member
    Bakersfield, CA
    2020 with 6000 miles, no leaks (yet).
  15. Nov 4, 2020 at 5:58 PM
    #195
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    Not yet. :fingerscrossed:
    But I only have about 4000 miles.
  16. Nov 4, 2020 at 6:04 PM
    #196
    Aurora CO
    ......winter is setting in up there anyways, time to get the sled dogs ready, sharpen the skates, and stock up on Cheezies!
  17. Nov 4, 2020 at 6:30 PM
    #197
    sbxx312
    sbxx312 New Member
    2018 Tundra TRD Sport
    Mine started leaking on the driver's side at 5500 miles. Toyota offered to fix both sides and I wanted to wait. I'm at 14,000 miles now and it's barely weeping. Not going to fix it absent something major happening, which I doubt.
    I thought my leaking was connected to towing, but I towed our trailer throughout southwestern CO this July and it's still fine. It used to stress me out but it doesn't anymore.
  18. Nov 4, 2020 at 6:47 PM
    #198
    Aurora CO
    The first thing I checked the day that I looked at my 14 on the lot was the cam towers. Dry as a bone at 104K. My biggest concern after that was it was blaaaaack! Ha!
  19. Nov 5, 2020 at 6:53 AM
    #199
    Kung
    KG, VA
    2020 with right around 9920 miles; no leaks.
  20. Nov 5, 2020 at 7:36 AM
    #200
    djhase
    djhase New Member
    If I had not come to this site, I would never have heard of a cam tower leak. My buddy has had every generation of Tundra.
  21. Nov 5, 2020 at 9:10 AM
    #201
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    Current Tundra... 2018 49,000 miles... No leaks...
    1st Tundra... 2014 sold at 45,000 miles... No leaks...
  22. Dec 18, 2020 at 3:06 AM
    #202
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    As of today, there are currently a total of 411 votes cast, with 75 having leaks. Works out to 18.2% of those responding having leaks. I would be willing to bet that the actual percentage of reported leaks to Toyota is far lower than this for two reasons.
    1. There are some people who would never notice the leak in the first place. As far as I have been able to find it's rarely more than a minor leak, and could easily be missed between oil changes.
    2. Many people only come to the forums/interwebs if they already have a problem, so I would think the likelihood of a higher percentage of sufferers being polled here is pretty good.
    Let's say the real number was half the percentage reported here (9.1%) and Toyota sold 1,502,837 Tundras from 2007-2019 ( https://motorandwheels.com/11-toyota-tundra-statistics-facts/ ), then you'd be looking at 136,758 trucks spread across 13 years. 10,519 trucks average per year. This would be a worst case scenario number. One big thing that will drop this number pretty quickly: There were a total of 1.5M Tundras sold and not all of these had the 5.7 engine.
    I don't have ready access to sales numbers breakdowns by engine type, so I am not going to speculate further on potentially affected truck numbers. Purely trying to show that with the percentage being as small as it likely is; it's not hard to see how or why this wasn't a high priority to be addressed. As far as I know there hasn't been any kind of catastrophic failure or severe damage due to the cam tower leak. It just wouldn't be a major concern unless it was affecting a much, much larger percentage of the trucks being produced.
    Cpl_Punishment, Bammer and Sumo91 like this.
