Pro Suspension in Cold
Discussion in 'Suspension' started by alpinepro4, Dec 16, 2018.
  1. Dec 16, 2018 at 8:44 PM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Anyone notice there TRD Pro suspension get real stiff when the temp drops below 10 degrees, or is it just me?
  2. Dec 16, 2018 at 8:51 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Lowest temps so far in my area a few times it’s been in the lower 20s haven’t noticed anything. I will pay mind to this now and post up when it gets colder.
  3. Dec 16, 2018 at 8:55 PM
    alpinepro4
    Pat
    I will be interested to hear when your temperature really drops. I don't notice it till under 10, seems to get real stiff. But not a lot of things like work when it get close to single digits. I have started saving for Kings, was going ADS but for what I do Kings might be the better choice.
  4. Dec 16, 2018 at 9:09 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    Pretty sure its just you...
  5. Dec 16, 2018 at 9:14 PM
    alpinepro4
    Pat
    How does your feel when it's below zero? Mine felt a bit stiff at -16 the other week.
  6. Dec 16, 2018 at 9:19 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    Mine really doesn't. It creaks a little in the cold but my pro suspension feels spongy and fluffy all of the time. Including -30.
  7. Dec 16, 2018 at 9:21 PM
    alpinepro4
    Pat
    Okay I might be overthinking things, maybe looking for an excuse to buy a set of kings. I will play with tire pressure now.
    Black Wolf likes this.
  8. Dec 17, 2018 at 8:29 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    I don’t think it’s just you. Mine is noticeably firmer below freezing. But I don’t think it’s just the Pro suspension either. Every vehicle I’ve owned has been ‘stiffer’ in the cold. At least until driven awhile.
  9. Dec 17, 2018 at 10:02 AM
    15whtrd
    15whtrd Mr. Blonde
    Think about it. Oil viscosity becomes much thicker when it’s cold out. Put some 0- 20 in it LOL
    Wrongside, Newm and TRD15559 like this.
  10. Dec 17, 2018 at 1:33 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    Kings/ads cant go wrong, it has been mentioned on this forum that the king coils can sag overtime. Also in this forum people say how plush and smooth the ride is.
  11. Dec 17, 2018 at 1:48 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Same here, even when I had Icon coilovers they were stiff till driven for a bit. Cold makes the oil seem thicker. Even the other day I was putting bar oil that has been sitting outside in my chainsaw and it was like gel coming out.
    Wrongside[QUOTED] likes this.
  12. Dec 17, 2018 at 2:11 PM
    alpinepro4
    Pat
    I would assume ADS coils don’t have a habit of sagging? I like the thought of a plush ride with kings. Then stiffen up when heading off road. I hear ADS not quite as smooth on road. But shine once on dirt. Those who have ADS am I wrong? Torn between the two.
  13. Dec 17, 2018 at 3:10 PM
    n2deep
    n2deep Pavement Princess
    Its probably the spring rate between Kings and ADS - Kings come with a 600lb spring and ADS 700lb spring. Depending on how much lift is cranked out of them that would affect how it feels on the road and dirt. I also believe King is conservative on valving where ADS might be a bit more aggressive.
    Ohh and temp would directly affect the viscosity of the oil inside the shock
    equin and 15whtrd like this.
  14. Dec 17, 2018 at 3:58 PM
    alpinepro4
    Pat
    That makes sense, you could then put a 600 lbs spring on a ADS and be close. Or have ADS valve suspension a bit softer.
    Yeah beginning to realize it the oil in shocks thinking up and giving a firmer ride.
  15. Dec 17, 2018 at 4:03 PM
    AZTundra
    Paul
    Phoenix, AZ
    It's only gotten down to ~40 degrees here in Phoenix since I installed my Pro Suspension. Mine doesn't seem stiff at all (at least compared to the stock Yellow Bilsteins that were removed). Doubtful I'll see anything near 10 degrees.
  16. Dec 17, 2018 at 5:01 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    My new KO2s rode harder when it’s cold
    Pro suspension is the same as when it’s warm
    I think tires will have more affect than anything imo.
    Casper3 likes this.
  17. Dec 17, 2018 at 5:05 PM
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 MX4 295/70/18 TOYO AT3 TRD CAI Window Tint
    Hmm interesting never really noticed it but also if it gets that cold my a$$ isn’t leaving the house so it’s hard to check
    RLHULK likes this.
  18. Dec 17, 2018 at 5:56 PM
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    I thought my Pro suspension felt stiffer when it got colder too but I figured I was being crazy. Glad to know I’m not the only one that thought or noticed that
