Icon stage 4 towing?
Discussion in 'Suspension' started by SparkyTundra15, Nov 26, 2018.
  1. Nov 26, 2018 at 10:56 PM
    SparkyTundra15
    SparkyTundra15 [OP] Let the adventures begin IG @tundra_adventure
    Moosh
    Los Angeles
    15' Tundra sr5 reg bed converted to TRD pro
    Fox 3” lift with res shocks rolling on 35” KO2s, paramount front bumper w/warn 12 ton winch, tyger side steps/sliders, fab fours rear bumper, ride rite airbags, TRD pro exhaust, wheels and headlights
    Hey everyone! I have a 15’ tundra 4x4 and was wondering if anyone has a stage 4 icon lift that also tows a heavy trailer? I’m thinking of getting the stage 4 but also need to tow a 26’ Toyhauler about 8,000-9,000 pounds at times. Any info would be much appreciated!
    dcsleeper408 likes this.
  2. Nov 27, 2018 at 8:16 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    My suggestion add a CB+1 shackle and replace the leaf instead of doing the add a leaf. I love how ours tows with the icons and new leaf pack.
    We tow 9,800 daily.
  3. Nov 27, 2018 at 4:47 PM
    SparkyTundra15
    Moosh
    Los Angeles
    Thanks for the reply, I’m getti new leafs with the stage 4 and have 2 helwig leafs that I’m adding.
  4. Dec 3, 2018 at 12:34 AM
    SmokeyTT
    SmokeyTT Smokey The Tundra
    Oahu
    2018 SR5 Off-Road 4x4 Crewmax
    Hey I was planning on getting the same shocks as stage 4 but with Deaver leaf packs. Wondering if you noticed any driver side lean? Or if you actually measured it?
    SparkyTundra15[OP] likes this.
  5. Dec 3, 2018 at 7:24 AM
    Mwray8909
    Chino Valley
    I did not have a drivers lean.
  6. Dec 7, 2018 at 9:53 AM
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    @SparkyTundra15
    We do offer a modular full leaf spring system. Pricier then the Expansion Pack but the full RXT Leaf System can be configured based on weight and/ride height.
    http://iconvehicledynamics.com/shop...ta-tundra-multi-rate-rxt-leaf-spring-kit.html
    I've seen the Daystar Air Bag Cradle more and more. Seems to be a great option for the people that use their vehicle for towing and don't want to limit performance due to an air bag.
    http://www.daystarweb.com/productdetail.php?productID=1232
  7. Dec 7, 2018 at 2:12 PM
    SparkyTundra15
    Moosh
    Los Angeles
    @Icon_Adrian
    Thanks for the input, quick question.. I’m getting the Stage 4 setup that includes leaf springs, do those springs lift the rear 3”s? Or is that just an add on shackle to bring it up to 3”s?
    Icon_Adrian likes this.
  8. Dec 7, 2018 at 2:19 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    This is the rxt option 3 towing a dual axle trailer and a pikes peak challenge Nissan Leaf.
  9. Dec 10, 2018 at 1:19 PM
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    The Stage 4 has an expansion pack that yields approximately 1.5" of lift over stock. The RXT leaf system comes in the Stage 8-10.
    The RXT Springs are configurable. They ship set up as option 1. All the parts needed will be included to configure the leafs to option 2 or 3. No shackles or blocks required. Factory shackles and directly mounted to the axle housing.
  10. Dec 11, 2018 at 10:19 PM
    SparkyTundra15
    Moosh
    Los Angeles
    @Icon_Adrian
    Thanks for you’re help bud, I’m going with the stage 4 kit for now and later I can get the expansion pack if necessary. Appreciate the input!
  11. Dec 19, 2018 at 9:52 PM
    Bjornsb
    Bjornsb New Member
    Silver sr5 4x4
    I did icon coilover up front with resi and rear icon 2.0 with resi and air bags toes great
  12. Dec 19, 2018 at 11:39 PM
    SparkyTundra15
    Moosh
    Los Angeles
    @Bjornsb hey bud, what brand air bags? I’m considering the firestone setup, and which ones the icon 2.0 plus resi?
  13. Dec 20, 2018 at 6:25 AM
    Bjornsb
    Bjornsb New Member
    Silver sr5 4x4
    Yes went with Firestone’s and 2.0 VS With resi and stock leaf springs.
    I’ll give you a killer deal on the one that we’re on my truck took them off to sell the truck pm if interested
  14. Dec 20, 2018 at 8:00 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    IMHO a 2.0 shock body is too small for this size truck.
  15. Dec 20, 2018 at 9:50 AM
    SparkyTundra15
    Moosh
    Los Angeles
    @bjronsb which kit is that one? I see the stage 4 kit has 2.5 rear shocks. When you had it installed on your truck, did it tow the toy hauler without any issues?
  16. Dec 20, 2018 at 10:02 AM
    Bjornsb
    Bjornsb New Member
    Silver sr5 4x4
    I didn’t do the kit I just order it separate from SoCal supper shop. I installed it my self. It towed just fine with the set up. And I’ve taken the truck out and Handel fine . My truck 4wd so I went with 2.5 and rears just 2.0 rear end on those trucks are pretty stout leaf springs on them are pretty good I was a Toyota tech
    Also I had rear airbags to
  17. Dec 20, 2018 at 10:58 AM
    SparkyTundra15
    Moosh
    Los Angeles
    @Bjornsb sounds good, I'm interested.. I don't know how to send a dm here.. but I'm assuming you're in socal? What part??
