Talk to me about leveling kits
Discussion in 'Suspension' started by sctruckgirl, Mar 14, 2018.
  1. Mar 21, 2018 at 9:05 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    I ran 18x9 rhino glamis with a -11 offset on a 2.5 inch lift on 275/70r18 and was crazy happy with the result
  2. Mar 21, 2018 at 9:06 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    The rhinos are amazing for the price and look
  3. Mar 21, 2018 at 9:09 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    BOBONTUESDAY[QUOTED] likes this.
  4. Mar 21, 2018 at 9:10 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Cleaner pic posted lol
  5. Mar 21, 2018 at 9:26 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    20171101_173825.jpg 20180106_160732.jpg ...Revtek 2 1/2 " Spacer up front. .nothing in the back...Tires are 295/70/18
    LawJ and SouthBoundSteve like this.
  6. Mar 21, 2018 at 9:46 PM
    Rica25
    Ricardo
    Tulare
    I ran glamis also but 12+ offset
  7. Mar 21, 2018 at 10:53 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    I liked them. So much so that I got another set
  8. Mar 27, 2018 at 1:35 PM
    LawJ
    LawJ New Member
    Law
    2014 Black Crew Max 5.7
    2.5 leveling kit, 285/65/18 on factory rims
    I’ll post my pics shortly; I just got mine leveled 2.5 and put on 285/65 18 on stock rims
  9. Mar 27, 2018 at 2:37 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I think i'm going to go this route. Hows the ride compared to stock?
    SouthBoundSteve likes this.
  10. Mar 27, 2018 at 2:44 PM
    Danimal86
    Daniel
    Sacramento, CA
    It seems like a good middle ground between 5100's and toytec boss.
  11. Mar 27, 2018 at 2:49 PM
    Danimal86
    Daniel
    Sacramento, CA
    Mine already wont fit in the garage. Can you do 3" while keeping the stock uca?
  12. Mar 27, 2018 at 3:24 PM
    LawJ
    LawJ New Member
    Law
    2.5 level in the front on 285/65 18 G2’s
  13. Mar 27, 2018 at 3:35 PM
    You can, but you will have better caster for alignment with aftermarket UCA's such as SPC.
  14. Mar 27, 2018 at 5:55 PM
    #FARFROM
  15. Nov 14, 2018 at 4:28 AM
    11CMGray
    11CMGray New Member
    With a 3" front leveling kit, I'd like to put some method race wheels on, something like in the picture. If I get some 17x9 could I still get a meaty tire 33s? Or will there be rubbing.
    There was a good wheel size thread I was reading when I first joined this site but couldnt find it this tine
    rebmo likes this.
  16. Nov 14, 2018 at 4:48 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
  17. Nov 14, 2018 at 5:05 AM
    11CMGray
    11CMGray New Member
  18. Dec 5, 2018 at 12:09 PM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Not to hijack this thread, but have some questions of my own. There are so many varying opinions but am hopeful can find the right answer here or pointed in the right direction.
    The ultimate goal is to run these wheels: https://www.blackrhinowheels.com/off-road-wheels-rims-arsenal.php
    on 35s.
    Many people say I could do this with a 3/1 and BMC. Others say a 4/2 with new UCA's will work as well. Further, I currently am on 20" wheels with KO2s and I believe am sitting at a +50 offset, which is too far inward for my liking. I do have the fender flares on my SR5 so I was at least wanting to match the flare or come out some. The black rhino's sit at -12 offset (18x9.5), so will that give me the stance I am hoping to achieve? Should I go 18s or 20s for wheel sizes? (they come in both)
    My next questions come from which lift/level to get? My fear is putting strain on other parts that will eventually cause a catastrophic failure of some sort. Is the 4/2 readyLIFT good to go? Should I just do Bilstein 5100s all around for the 'almost' 3/1 lift/level? Is the spacer that goes at the top of the shock absorber a good or bad thing, and will it wear over time causing the shock to fail? Leaf kit lift? Any advice is truly appreciated and thanks for taking the time to read.
    edit: Have 2018 SR5 4x4. Only plan to do some light off-roading (beach, Big Bend next year, small hiking trips).
  19. Jan 23, 2020 at 6:30 PM
    Edier08
    Edier08 New Member
    what brand 3 inch coilover? any shims? thanks looks great
    Rica25 likes this.
  20. Jan 24, 2020 at 5:44 AM
    #50
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    Do you have pics of what you had to cut out?
    I have 5100's on top setting with 20's and wanting to go 305/55/20
    Rica25 likes this.
  21. Jan 25, 2020 at 12:00 AM
    #51
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Bilstein 5100
    Rica25 likes this.
