NEW! 2007-2016 Crew Max and Double Cab bolt on Sliders from SDHQ
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Jul 26, 2016.
  1. Jul 26, 2016 at 9:32 AM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    http://store.sdhqoffroad.com/2010tundrarocksliders.aspx
    SDHQ is proud to announce the release of our bolt on Rock Sliders for the 2007+ Toyota Tundra. These rock sliders have been built to fit both the Crew Max and Double Cab Short Bed trucks. Sticking to a well-earned reputation for craftsmanship, we chose to build these rock sliders out of 4130 chromoly tubing with gusseted steel mounting plates ensuring that these are both strong and light weight. These rock sliders were CAD designed and built in house for a precise fit and finish every time.
    Our rock sliders are intended to be a fully bolt-on design, so there is no cutting, welding or drilling required for install and there is no permanent frame modifications required. Our sliders utilize 4 mounting points on the frame per side and we also created a unique mounting design that attaches to the front body mount where the hardest initial impact tends to occur. Other sliders on the market tend to place the first mount nearly one foot behind the front body mount which creates a weak point in the front part of the slider.
    • Fits 2007+ Tundra Double Cab and Crew Max
    • Durable 4130 .120” wall chromoly tubing with gusseted steel mounting plates for durability
    • No cutting, drilling or welding is required forinstall.
    • No permanent modification to the frame is required
    • Unique mounting design made specifically for the Toyota Tundra
    • Just as strong as a weld-on slider
    • Works with body mount chops
    • CAD designed for a precise fit and finish
    • High strength grade 8 hardware included
    • Raw and powder coated finishes available
    • Made in America
    http://sdhqoffroad.com/07-current-sdhq-built-tundra-sliders/
    Sunnier, CJ21, 15whtrd and 3 others like this.
  2. Jul 26, 2016 at 9:34 AM
  3. Jul 26, 2016 at 9:40 AM
    sdhq_offroad
    GILBERT, AZ
    More Pics on @TRON truck
    DeanO and TRON like this.
  4. Jul 26, 2016 at 9:43 AM
    TheBeast
    TheBeast The Beach
    they are on my list for sure. will they protect from door dings as well on the parking lot ? can they be used as a step too ?
  5. Jul 26, 2016 at 9:45 AM
    sdhq_offroad
    GILBERT, AZ
    yes and yes, however I generally tell people that while a slider will work as a step it is not a substitute for a step as it does not sit low enough to really aid getting into or out of the truck. But you can stand on them to load things on the roof or whatever you need!
    Krezz and TheBeast[QUOTED] like this.
  6. Jul 26, 2016 at 9:47 AM
    TheBeast
    TheBeast The Beach
    I need to take a road trip to Gilbert,AZ. Between the sliders and the bumper..:burnrubber:
    sdhq_offroad[OP] and T-Rex266 like this.
  7. Jul 27, 2016 at 2:11 PM
    sdhq_offroad
    GILBERT, AZ
  8. Aug 14, 2016 at 8:48 PM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    So, I had a set of these show up at my place last week. Gotta say, these things are awesome. Perfect fab work and welding. Great, low profile, lightweight design! These are definitely worth a look for anyone wanting sliders for their Tundra...
    The plan is to have them thoroughly coated and Linex the rails before install, but with the obvious attention to detail in these things, I expect they'll bolt right up. Vacation will get in the way, so it may be a while before I get pics up. But put them up I shall!
    One last thing- I've been researching and shopping for Sliders since the day I picked up my 2016. Before SDHQ came out with these ones, I even tried to purchase a set from other companies, but when the vendors find out we're north of the 49th, they'd brush me off. Not return calls or emails. Not the case at all with SDHQ and Cliff... I can't say enough good things about you guy's patience and customer service. Thanks for all your help and, oh yeah, your product is unreal awesome too! Thanks again Cliff!
  9. Aug 14, 2016 at 10:12 PM
    LML 3500HD
    Sweet.
    How much do the DC and CM set weigh?
    I like the design with not welding to the frame like some of the other guys.
    Nice work.
  10. Aug 15, 2016 at 5:16 PM
    sdhq_offroad
    GILBERT, AZ
    No Problem buddy! Glad they made it up there as quickly as they did. Send me over some pics when you get them on
    They're right around 100lbs a set, 100% bolt on.
  11. Aug 15, 2016 at 5:17 PM
    LML 3500HD
    Hell that is pretty good!!! I had some from a different vendor on my taco and they were HEAVY....
  12. Aug 16, 2016 at 9:38 AM
    TheBeast
    TheBeast The Beach
    I need a set !..so many projects...:burnrubber:
  13. Aug 16, 2016 at 10:55 AM
    too tall
    too tall New Member
    These are looking good. I'll contact SDHQ about getting a set.
  14. Aug 16, 2016 at 5:53 PM
    too tall
    too tall New Member
    Ordered! I'll report back after install.
    They arrive bare. Opinions on POR15 coating than POR topcoat?
    I could also have the same guy who did the spray in bed liner shoot the bars.
  15. Aug 16, 2016 at 7:44 PM
    gosolo
    Ray
    NW Oregon
    Discount for Tundra Talk members?
  16. Aug 17, 2016 at 9:44 AM
    sdhq_offroad
    GILBERT, AZ
    well this is tundras.com :p but we are running a special for forum members right now which is $50 off our normal pricing.
    We also just finished a large production run of these as well and I do have a set pre-powdercoated for local install or pickup available
    Sunnier and gosolo[QUOTED] like this.
  17. Aug 17, 2016 at 11:55 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Checked these out about 2 weeks ago, talk about strong and beefy!!!
    sdhq_offroad[OP] likes this.
  18. Aug 17, 2016 at 6:51 PM
    gosolo
    Ray
    NW Oregon
    I will stop in tomorrow and check em out. Do you think I can jack up the side of the truck with them? 4 brackets/bar? 2 bolts/bracket?
    Already got a bad dent in the rocker under the passenger door on the drivers side
  19. Aug 19, 2016 at 4:13 AM
    too tall
    too tall New Member
    What's the word Gosolo?. I am waiting for tracking info.
  20. Aug 19, 2016 at 6:15 AM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Don't hesitate buying the BEST bolt on slider money can buy gentlemen! I had the privilege of rocking the first set and wasted no time at all putting them to use in Moab! :thumbsup: I can guarantee they will support the entire weight of the truck with little to no flex whatsoever. I've used my hi-lift on them with no issue. Looking underneath to see how they're mounted is pretty impressive especially around the cab mount!
    Sunnier, CJ21, CLR619 and 7 others like this.
  21. Aug 19, 2016 at 5:13 PM
    gosolo
    Ray
    NW Oregon
    Picked em up yesterday, got home today early enough to install the one on the drivers side. Will do the other one in the morning. Time for some scotch now!
  22. Aug 19, 2016 at 5:46 PM
    too tall
    too tall New Member
    You dog ;) I'm chomping at the bit. Mine are due here mid-week but first a trip to my line-X guy.
  23. Aug 19, 2016 at 6:11 PM
    gosolo
    Ray
    NW Oregon
    You will be pleased. What truck do you have?
  24. Aug 19, 2016 at 6:24 PM
    too tall
    too tall New Member
    2016 TRD Limited Dbl. Cab Other than the White Knuckle Sliders these are the only ones that really caught my attention from a design and fabrication viewpoint. Proof is in the doing but I take your word for it. People here don't mess around when it comes to our trucks ;)
    Sunnier likes this.
  25. Aug 19, 2016 at 6:32 PM
    gosolo
    Ray
    NW Oregon
    I checked out the white knuckle also. Have read some horror stories about difficult installation
  26. Aug 20, 2016 at 12:41 PM
    too tall
    too tall New Member
    No lift and no help here. No surprises is important.
  27. Aug 24, 2016 at 2:34 PM
    too tall
    too tall New Member
    Big truck arrived. I know good fabrication, this is that. They looks good. It will be a couple weeks. I've got racing in the NE to wrap up than off to get them coated.
    Enjoy the pics. FWIIW if these fit and function as good as they look these guys raised the bar some.
    Kudos for spraying them with a light oil prior to shipping. Appreciated.
    Sunnier, MotoTundra, JC303 and 4 others like this.
  28. Aug 31, 2016 at 1:57 PM
    sdhq_offroad
    GILBERT, AZ
    Bump!
    MotoTundra likes this.
  29. Aug 31, 2016 at 2:11 PM
    too tall
    too tall New Member
    Ahhh, just back from the NE. I should have mine line-x by next week than install.
  30. Sep 1, 2016 at 4:54 PM
    Wrongside
    AB
    2016 Tundra
    Mine are Linex'd! Just gotta find time between work and hunting to pick them up and install them. Heh.
