Truck won't start - narrowed it down to fuel pump or ECU - help diagnosing?
Discussion in '2nd Gen Tundras (2007-2013)' started by AR15tn, Oct 18, 2018.
  1. Oct 18, 2018 at 11:34 AM
    AR15tn
    AR15tn [OP] New Member
    Started up the truck to run a quick errand, didn't drive it the following day. Tried to start it up and it would try to start but never would.
    Battery needed to be replaced anyway so I did that. Truck is getting spark, verified that.
    I can get the truck to start if I put starting fluid in the intake. It'll start up/turn over then die, so I think it has to be a fuel delivery issue (there was also no smell of gas on the spark plugs at all when I pulled them).
    Anyone have any ideas how to tell if it's the fuel pump or the ECU or module that runs it?
  2. Oct 18, 2018 at 11:34 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA...o_O
  3. Oct 18, 2018 at 11:35 AM
    15whtrd
    15whtrd Mr. Blonde
    My guess would be it has something to do with your alarm system or your key if it has a chip. If you have a second key try that. Something sounds disabled. I doubt it’s your ECM or fuel pump but you never know.
  4. Oct 18, 2018 at 11:37 AM
    AR15tn
    I only have the one key. There's no alert on the dash showing an issue with the key or anything.
  5. Oct 18, 2018 at 11:40 AM
    koditten
    koditten New Member
    Try putting the key in opposite the way you had it.
  6. Oct 18, 2018 at 11:43 AM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Disconnect battery and wait 30 seconds and re connect that worked for me
  7. Oct 18, 2018 at 11:46 AM
    AR15tn
    Tried both of these already, but thank you
    EDITED TO ADD:
    To those thinking this is an immobilizer thing, wouldn't I see the light showing that the key has issues on the center dash display?
    anthonygan[QUOTED] likes this.
  8. Oct 18, 2018 at 11:48 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I went through a similar issue... ended up with a new key, a new battery, and a new fuel pump. Everything has been fine since then.
  9. Nov 29, 2018 at 10:36 AM
    1crzysob
    1crzysob New Member
    2011 Red Tundra DC SR5
    3" level kit, matte black step bars
    Mine quit on me a couple months back. Hauled it to the dealership, after diagnostics, they found the fuel pump control module was bad. The tech told me it was something that never should have failed. The extended warranty covered it, only cost me 100 vs almost 800 without the coverage
  10. Nov 29, 2018 at 10:51 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I’m guessing fuel pump.... have some1 turn the key and go under by the fuel pump see if u hear it turn on
  11. Feb 25, 2019 at 6:07 AM
    HTxSnoop
    HTxSnoop New Member
    2012 4.6L Tundra Crewmax
    3in level kit with 20s
    im having the same issue on mine 2012 tundra 4.6 sometimes it wouldnt start cranks. but if i hold the gas pedal down all the way it would i changed spark plugs some coils n new fuel pump doing the same thing but it feels like it rough idling when it idling. anyone can help me solve this issue too?
  12. Apr 20, 2021 at 6:31 AM
    LNT-Master
    LNT-Master New Member
    FIX! Sorry to necro this thread, but if there is a fix...... Oh yeah, speaking of fix. Had a 2011 Tundra about 35 mph just completely lose all fuel pressure and coasted to a stop dead. Two days of Toyota TIS testing later, I finally got brave amd pulled the fuel pump control ECU that is bolted and sits inside the frame. I removed it and actually disassembled it. The condition of the main chip that has 144 soldered contact points was toasty black on the greenboard side that you can see and if you flex the greenboard outward enough (it will not come completely out) the condition of the chip area itself was completely corroded. I replaced the fuel pump control ECU and the Tundra fired right up! Replacing the fuel pump control ECU fixed my problem.
  13. Apr 20, 2021 at 6:32 AM
    LNT-Master
  14. Jun 24, 2022 at 8:39 AM
    AnimalMother
    AnimalMother New Member
    Todd
    01 Tundra SR5 access cab 4.7 4x4
    Bilstein 5100 all around, OME 885 front, bastard Tundra/Titan leaf pack rear, 17"Granite rims w/ 33-12.5 tires, shinny new frame. Custom paint.
    I have a 2011 4.6 Tundra. I am also having random crank no start issues. I narrowed the problem down to the fuel pump control module. I pulled a module from a 2012 Tundra at the local salvage yard and it seems to only work when it wants to. I am using a Launch x431v bidirectional scan tool. With key on, Launch hooked up and multimeter back probing the white signal wire going into the FP ecu and the other lead to chassis ground I get 12v. When I use the Launch to control the fuel pump on/off or fuel pump duty cycle 25%/80% I get roughly .02v fluctuation. I also have 12v on the white/black incoming power wire. I get 0 v on the blue and red wire going to the fuel pump. There is a green incoming wire which is labeled DI in the wiring diagram and coming in from the ecm but I could not find any info on that one.
    Dose anyone have the official Toyota Service Manual section for testing and troubleshooting the fuel pump circuit starting at the ecm. The manual I have only tells you how to remove and install the pump ecu. Nothing about how it should work.
  15. Jun 24, 2022 at 4:06 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Try here. The official repair manual from Toyota for a 2009 4.7. Should be close enough to the same.
