Roof Top Tent Hoists for Garage Storage
Discussion in 'Sports, Hobbies & Interests' started by Sunnier, Oct 5, 2018.
  1. Oct 5, 2018 at 10:47 AM
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    Anyone know of a good pulley hoist garage storage system rated for more than 200 pounds? My RTT is 200#, and I prefer never to max out on capacity, but I haven't found an option with higher weight capacity.
    Thanks in advance for any help! Pics and links appreciated.
  2. Oct 5, 2018 at 10:59 AM
    n2deep
    n2deep Pavement Princess
    Build one. I used a couple pulleys, some steel cable and hand winch from harbor freight
    Bear, Sas and Sunnier[OP] like this.
  3. Oct 5, 2018 at 12:11 PM
    n2deep
    Couple pics. Mounted 2x4 to ceiling and secured with bolts thru attic truss and steel plates above to keep from pulling thru. Hand winch from Harbor freight.
  4. Oct 5, 2018 at 12:18 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  5. Oct 5, 2018 at 12:50 PM
    Sunnier
    Sunny
    San Diego, CA
    This Harken is the best-rated one I found ready-made, but it's Max capacity it 200#. If no one else posts a ready-made option with higher lift/ storage capacity :spy:, with these pics (thank you!) and the instructions for the Harken, I can probably figure it out. :fingerscrossed:
    :) Thanks, Fellas!
  6. Oct 5, 2018 at 1:45 PM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I have the 200# harken for my topper and it works great but like you said, you want more than 200#s. An option might be to use the harken but then add some ratchet straps to it for more weight support, assuming you have exposed beams in your garage.
    Sunnier[OP] likes this.
  7. Oct 5, 2018 at 2:17 PM
    Sunnier
    Sunny
    San Diego, CA
    I don't have exposed beams. I am planning to run bolts up through the drywall into a 2 x 6 laid over the rafters. X 2.
    dittothat and Sas like this.
  8. Oct 5, 2018 at 3:43 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    Build it yourself. Block and tackle, line, cleats. You know any sailboat owners? If they are anything like me, they have most of what you need laying around the garage.
    Incidentally, Harken is such a large part of sailors lives I have a Dog named Harken. They make nice stuff.
  9. Nov 27, 2018 at 3:05 PM
    Marty McFly
    Morty McBoonJug
    :pccoffee:
    Hola @Sunnier did you figure out what your going to do with the RTT situation?
    fundra_goes_west likes this.
  10. Nov 27, 2018 at 3:08 PM
    pbcolt
    pbcolt New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    + a 2x4 frame and cables attaching the 4 corners to the hoist.
  11. Nov 27, 2018 at 3:09 PM
    Sunnier
    Sunny
    San Diego, CA
    No, it's still on the truck. I think it's a top priority every time I look at the truck. But when I get inside the house, other top priorities hold my attention. What are you thinking?
    We'll use the RTT in a couple weeks. After that, it really will move back up the priorities list..., unless someone proposes another camping weekend just a few weeks out.... :rolleyes:
    Marty McFly[QUOTED] likes this.
  12. Nov 27, 2018 at 3:41 PM
    Marty McFly
    Morty McBoonJug
    Camping trips you say lol I haven’t done nearly enough research but I’d like some kind of system that could be utilized as storage for the RTT too :confused:
    Sunnier[QUOTED][OP] likes this.
  13. Nov 27, 2018 at 4:56 PM
    Sunnier
    Sunny
    San Diego, CA
    The one N2Deep posted above looks like the best option for low cost. But we'd have to figure it out. :anonymous:
    Or that Harken system above is well-rated, and would work well for your RTT, but not mine (too :muscleflexing:).
    If you want to be the ginnea pig, we could hit Harbor Frieght and built I at your house, then I could probably replicate it at mine. The reason I'm suggesting you go first is because my garage is really full of stored stuff; learning somewhere else would allow me to know best how to locate it (I mean, which stuff to move first.)
    Anyone else in SoCal, this offer extends to you. I'm comfortable crawling around in attics, and will be lovely assistant to the first person that answers up and wants a hand to do a cheap-ass RTT hoist build in your garage.
    Edit: SD area would be my first choice :cool:, but I'll totally travel all the way to Hollywood for you, Marty! :D You my BFF!
  14. Nov 27, 2018 at 5:03 PM
    Marty McFly
    Morty McBoonJug
    Haha I don’t mind being a guinea pig. I just need to look at other options. Something with a motorized pulley would be ideal. The only problem is my garage is half finished, so finding studs would be a little difficult
  15. Nov 27, 2018 at 5:14 PM
    Sunnier
    Sunny
    San Diego, CA
    It is true, all my buddies are saying to winch it. But even winches are cheap at HF. :boink:
    Please let me know if you find one ready to go that has a weight limit 220# or higher. I don't feel comfortable using the one rated for exactly what I'll store. Seems like a good idea not to push that.
  16. Nov 27, 2018 at 5:39 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    My tent came with a hoist and 2 straps the po built. Uses a auto stop hoist, similar to how blinds work.
  17. Nov 27, 2018 at 6:19 PM
    Sunnier
    Sunny
    San Diego, CA
    Hmmn, link or pics? I guess only if it's not built on to your RTT.
  18. Nov 27, 2018 at 8:24 PM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    You can always use a stud sensor to locate it. Typically you probably have a spacing of 12”, 16” or 24” spans from stud centers.
    Marty McFly likes this.
  19. Nov 27, 2018 at 9:00 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  20. Nov 27, 2018 at 9:04 PM
    Marty McFly
    Morty McBoonJug
    This is true, I don’t think the studs is really the problem. I’d want to reinforce it above the studs but getting to the rafters would be difficult.
  21. Nov 27, 2018 at 9:47 PM
    Sunnier
    Sunny
    San Diego, CA
    Naw, dude, we'd just lay a couple of 2x6's across the studs, cross ways. Then insert long bolts up through the drywall, through those 2x6's. Secure on top of the 2x6's (in the crawl space) with wide washers and nuts. This'd spread the weight over as many studs as the length of the 2x6's used. Waaaaay better at dispersing the weight than bolting directly to studs or rafters. I can easily picture this part; I get hazy on the ratchet, straps, and connection points down in the garage.
  22. Nov 27, 2018 at 9:50 PM
    Sunnier
    Sunny
    San Diego, CA
    Awesome! Thanks for this :fistbump:
  23. Nov 28, 2018 at 7:25 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    Let me know what you end up going with. Will be doing this eventually
  24. Nov 28, 2018 at 8:04 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    I went with something a little different. I have a 66 Lincoln continental in the garage and I really can’t get my tundra to my garage. So I built a rolling rack that fits above the Lincoln. 3A30F93B-F9D7-4594-A639-5F7DB308D27A.jpg16A76353-FA76-46E0-AAD5-DB69A20CE694.jpg F1EB8B4C-106B-427B-9BB6-1AF1E5E96D10.jpg
    Sunnier[OP] and fundra_goes_west like this.
  25. Nov 28, 2018 at 8:05 PM
    Grendel
    Grendel New Member
    It only takes two of us to get it on. The rack was originally designed. To roll over the mini behind the garage
  26. Nov 29, 2018 at 11:56 AM
    Sunnier
    Sunny
    San Diego, CA
    Thanks for posting! I appreciate the creative alternative to a ceiling mount... and especially appreciate see a garage on here as packed with stuff as mine is ;). At least you're houses a vehicle. :anonymous:
  27. Feb 22, 2023 at 11:25 AM
    Hellrazor
    Hellrazor New Member
