I goofed up.
Discussion in 'Wheels & Tires' started by ReginalPierre, Nov 12, 2018.
  1. Nov 12, 2018 at 3:44 AM
    ReginalPierre
    ReginalPierre [OP] New Member
    2014 Tundra
    Pro headlights, Pro grill, Baja Design fog lights, Taillights, antenna, raptor style grill lights,
    Bought myself a '14 Tundra. Super excited. Decided to wash the truck and used a wheel cleaner (similar to purple power) that I've used on all of my previous vehicles and managed to do this.... Any ideas on how to get it off?
    JohnH and TXRailRoadBandit73 like this.
  2. Nov 12, 2018 at 3:46 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    You might have actually removed what was on there? :confused:
    Rica25 and Sunnier like this.
  3. Nov 12, 2018 at 3:48 AM
    Yikes!
    Rica25 likes this.
  4. Nov 12, 2018 at 3:48 AM
    ReginalPierre
    2014 Tundra
    It appears to be a residue. If I take my fingernail to it, it begins to come off. I used Comet Cleaner on it and that kinda works but will take me about 10 hours to do all 4 wheels
  5. Nov 12, 2018 at 3:51 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    Maybe some hot water would loosen that up and make it easier....
  6. Nov 12, 2018 at 4:04 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Might try simple green and warm water.
  7. Nov 12, 2018 at 4:09 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I've done that on aluminum wheels looks like you removed the clear coat.
    Rica25 likes this.
  8. Nov 12, 2018 at 4:40 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    sounds like you are going to make a bad thing worse by doing this. Comet is abrasive which will scratch the finish. Try using a non marking scotch brite pad and some car wash soap. The pad should scrub off the residue without causing further damage. Follow up that with an application of spray detailer.
    Unless you have some majorly neglected wheels, you should only be using car wash soap and soft brushes on those wheels.
    831Tun and Darkness like this.
  9. Nov 12, 2018 at 4:46 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Just be careful when you try different things that you don't use anything abrasive that will do more damage. I don't think Comet is abrasive, but some similar products are; hence their super cleaning properties, but not good for paint or clear coat.
    Engine degreaser should take just about anything off, but I am not sure that I would try it on an alloy wheel. How about regular wheel cleaners - try a known brand like Mother's or Meguiars and see what that does.
  10. Nov 12, 2018 at 6:26 AM
    UNTMatt
    UNTMatt New Member
    2015 Attitude Black 4x4 Limited
    TRD Pro grille, TRD Pro black badging, TRD Pro shift knob, LED under dash lights, GBS, Llumar ceramic tint, BackFlip HD.
    Comet contains calcium carbonate which is a very mild abrasive. On aluminum wheels, only use either standard car wash soap or cleaners specifically designed for aluminum alloy wheels. Personally, I've been using the inexpensive Armor All wheel and tire cleaner and have had no issues. Meguiar's makes a good one called Hot Rims Aluminum Wheel Cleaner that I've used in the past with really good results.
    I don't invest nearly as much as some of the others here but I would recommend using the proper tools for the job at hand. It doesn't have to require a life savings, either. I'm thinking the same as some of the other posts, that the clear coat has been severely damaged. You're probably going to have to find some temporary wheels (unless you can do without your truck for a while) and have those either repainted or powder coated.
    --Matt
    831Tun likes this.
  11. Nov 12, 2018 at 8:55 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    This!
    I have the same wheel, first set of black wheesl. Could have easily made the same mistake. Luckily have only cleaned with car wash soap. Actually applied some Lucas spray wax to help protect.
    It looks possibly bad, but would try a wheel sealant or wax to help revive.
    Good luck.
    909engineer and Mountun Goat like this.
  12. Nov 20, 2018 at 9:12 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Have same wheels.
    Did something similar in year one with the Meguiars wheel cleaner (the pink or purple stuff)...either way, don't use it.
    The best cleaner I've found for these wheels is the West Coast Customs, Wheel/Tire cleaner....get it at Wal-Mart.
    You may need to get a cone buffer and repolish the wheels. Don't worry...I did the same thing and was able to get the factory look back.
    Then use a less abrasive cleaner in the future. :thumbsup:
    Boerseun and Rica25 like this.
  13. Nov 20, 2018 at 9:16 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  14. Nov 20, 2018 at 9:17 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I’ve done that before as well when washing the truck on a hot day. Didn’t wash it off soon enough. I just used car wash soap and one of those sponges with the netting type stuff wrapped around it to remove bugs/ debris. Gave it a good scrub and hit it with the pressure washer. Then add your choice of tire shine etc and you should be good to go.
