1st gen tundra double cab - good 3rd car? Use for family camping
Discussion in '1st Gen Tundras (2000-2006)' started by nikbrewer, Nov 6, 2018.
  1. Nov 6, 2018 at 11:43 AM
    nikbrewer
    nikbrewer [OP] New Member
    I am starting to look for a truck for us to use for camping trips and trips to Home Depot, etc. I am drawn to the tundra due to it apparent reliability. I had a tacoma many years ago and loved it. I have (2) 5 year girls, so we need the double cab for sure. That looks like i am limited to 2004-2006.
    Now, around me i can find some trucks under or near 100k. However, they are 11k -13k, which would mean some sort of car loan. I am not apposed to this, but on a 12 year old car, i just want to verify that this is a good idea.
    When looking at these trucks, what do i need to keep an eye out for? Any years or models better then others?
  2. Nov 6, 2018 at 11:49 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Depending on region, don't be afraid to crawl under (they have amazing ground clearance) and look for rust.
    Outside of that, look for one with documented history if possible. The one major maintenance item on these is the timing belt/water pump job. Should be done around every 90k miles and will cost around $1k to have done. Other than that, very solid trucks. Owned my 03 for ten years trouble free.
  3. Nov 6, 2018 at 11:54 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Rust and timing belt changes. Those are the big ones they're pretty solid trucks.
    Sunnier likes this.
  4. Nov 6, 2018 at 11:56 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Excellent trucks.
  5. Nov 6, 2018 at 11:59 AM
    nikbrewer
    Rust does not seem to be a huge issue here in Oklahoma. Timing belts i should be able to tackle myself, but will use it to negotiate price if it has not been done.
    4 speed verse 5 speed trans. Is one stronger or more reliable?
    Rex Kramer likes this.
  6. Nov 6, 2018 at 1:18 PM
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    We were sort of in the same boat as you. Boyfriend had a 1st gen access cab Tacoma and I had a 3rd gen 4runner. We wanted the extra space with the double cab and knew this would mean a loan. Honestly, it is the best decision we have made and don't regret it at all. My 2004 had 202k miles on, some maintenence, wheels and tires and a brute force bumper on it and we paid $11k. That's pretty much the going rate here in AZ.
    paidoff and Sunnier like this.
  7. Nov 6, 2018 at 1:21 PM
    Casper421
    In the woods
    06 DC
    Look for an 05-06.
  8. Nov 6, 2018 at 1:23 PM
    Rex Kramer
    Georgia
    I think most, if not all 4 door 1st gen Tundra came with a 5 speed.
  9. Nov 6, 2018 at 1:30 PM
    Casper421
    In the woods
    06 DC
    00-04’s have the 4 speed A340 and 05-06 have the 5 speed A750F.
  10. Nov 6, 2018 at 1:38 PM
    Rex Kramer
    Georgia
    The Double Cab didn't hit the streets until '04, and the 5 speed hit the market in '05.
  11. Nov 6, 2018 at 1:42 PM
    Casper421
    In the woods
    06 DC
    Correct. 04 has the 4 speed and 05-06 has the 5 speed.
  12. Nov 6, 2018 at 1:53 PM
    Rex Kramer
    Georgia
    When was the planetary gear problem solved in the original 4 speed... aren't 4 speed AT good to go with the new PG?
  13. Nov 6, 2018 at 2:16 PM
    Casper421
    In the woods
    06 DC
    Yes and I want to say 03 got the new gear.
    Darkness and Rex Kramer[QUOTED] like this.
  14. Nov 6, 2018 at 5:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Casper is on point. The (intergalactic) planetary was fixed for 03. 04 is the oddball year. 05-06 have 5 speed and VVTi motor.
    Get an 05-06, black if possible. :cool:
    WutsaZJ, ethan1911, jnevill and 3 others like this.
  15. Nov 6, 2018 at 5:21 PM
    Casper421
    In the woods
    06 DC
  16. Nov 6, 2018 at 5:37 PM
    Rex Kramer
    Georgia
  17. Nov 6, 2018 at 5:48 PM
    bmf4069 Yup, that's car parts in a dishwasher
    What part of OK?
  18. Nov 7, 2018 at 6:08 AM
    nikbrewer
    im in the edmond / guthrie area. North of OKC
  19. Nov 7, 2018 at 8:19 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Don't be afraid of a higher mileage Tundra either. If they have been properly maintained 200k is nothing on these trucks.
  20. Nov 8, 2018 at 5:13 AM
    JQ3
    JQ3 2005 XSP rwd
    I ended up getting an '05 XSP DC with 93.6K on the odo out of Florida for $10k. It's Phantom Grey and was well taken care of as far as I can tell, I've only had it 3 weeks. I did find out that it will need a rear driver's side wheel bearing. Funny thing my 05 Sequoia needed the same bearing, but it has almost double the miles...94k to 184k. Why the bearing went out so soon is anyone's guess.
    The truck had just gotten it's 90k maintenance too, new Michelins, new radiator and head gaskets!!! So far...so good!!!
    As far as what to look out for, in addition to what they guys have told you already, the wheel bearings. Especially the rear. In both cases, Sequoia and Tundra, the bad bearing sounded like it was the front driver's side. Upon future inspection with a stethoscope and a knowledgeable mechanic the bad bearing was isolated to the left rear. Good luck!!!
    Darkness, ethan1911 and bmf4069 like this.
  21. Nov 8, 2018 at 5:20 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    X2 on this, that’s the best color and best years.
    Darkness[QUOTED] and Casper421 like this.
