Upgrade headunit?
Discussion in 'Audio & Video' started by Rski85, Mar 21, 2018.
  1. Jun 13, 2018 at 7:10 PM
    rjrankin
    rjrankin New Member
    I did similar mounting it here and running wires through the headliner to the pillar. Didn’t have to remove the pillar, I just worked it in at the top and ran it down the weather stripping to under the console. Anyone have a usb they’ve added that works with audio? Reading negative reviews about the ones on Amazon
  2. Jun 13, 2018 at 7:56 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    looking at the 9704s, what does Sirius XM READY mean? Is it ready for a subscription or more parts needed?
  3. Jun 13, 2018 at 7:59 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    sirius XM "ready" means you need to buy the corresponding satellite radio tuner, which is not built into any headunit I know of, at least not a pioneer or kenwood
  4. Jun 13, 2018 at 8:07 PM
    rjrankin
    rjrankin New Member
    Yeah there’s an adapter you have to purchase for xm. Can’t speak to how well it works because I pretty much just use Spotify and podcast. It also does pandora
    Also keep in mind the extras that are needed to hook up the stereo. I paid $338 for the stereo but it cost me about another $200 for wiring kits and dash kit.
  5. Jun 13, 2018 at 8:08 PM
    TomC843
    Tom
    Charleston, SC
    so every radio ever is XM ready if I have to buy a XM tuner unless I don't understand.
  6. Jun 13, 2018 at 8:12 PM
    TomC843
    Tom
    Charleston, SC
    All using cell phone / bluetooth? I would not have anything for a lot of my travels but FM then. no service in a large area around where I live.
  7. Jun 13, 2018 at 8:21 PM
    ninjajay
    Spoolston, TX
    no, not all radios have the plug to connect a sirius XM tuner, so "ready" just means it has the plug
  8. Jun 13, 2018 at 8:59 PM
    slide187
    slide187 New Member
    Boston, MA
    2015 Silver Sky Metallic DC Limited Tundra
    Console Cavern Organizer Mod, Driver's Forward Assist Handle Tonno Pro Hardfold, Body Colored Door Handles, Body Colored Mirror Caps, MBRP Stainless XP Series Dual Exhaust, OEM Bed Extender
    Anyone seen/tried one of these? I know, I know, I’m askin for trouble with another one of these android head units that’s not a brand name. Im just not ready to give up on the OEM look. I hate the way the aftermarket ones look in the dash. And I don’t wanna pay $1k for an aftermarket unit just to have the screen angled like the dash. But I def have given up on the OEM head sound and
    function. And the constant crashing is too much. https://www.ebay.com/ulk/itm/162853439395
  9. Jun 14, 2018 at 7:49 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    i unplugged/removed the factory mic, and installed the kenwood mic inside the factory mic location. works well, cant see it.
    Mw4904 and (deleted member) like this.
  10. Jul 1, 2018 at 12:08 PM
    slide187
    slide187 New Member
    Boston, MA
    Was that a pain? And i take that story to mean that the Idatalink Maestro allows you too keep just about everything BUT the factory mic that's already in the overhead console.
  11. Jul 1, 2018 at 12:09 PM
    slide187
    slide187 New Member
    Boston, MA
    Welp, it looks like i'm leaning more and more toward a Kenwood head unit. Looks like theres a few of them where the screen still can be physically angled and i'm not too concerned with the inclusion of Waze on the head unit since Carplay will have it this fall when iOS 12 comes out. All the research i've been doing seems like I'll need the Idatalink Maestro RR, with the ST02 to keep my factory gps antenna, the T02 for vehicle setup functions and the non-JBL amp, AND UT02 for my factory USB input.
    So question about that last one for the Kenwood peeps, I know for Carplay and android auto theres a specific usb cable you have to use.... This idatalink usb cable doesn't allow you to make the factory usb drop one of those, does it? Because it seems like it would. For ex. the gray usb cable on the Kenwoods is for car-play... If I hooked that one to the factory location with the UT02 then the factory usb input in the center stack should be my "carplay input" right?
  12. Jul 1, 2018 at 1:44 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    Your mic placement is perfect for voice quality. However, I recommend you pull your pillar and ziptie your mic cord along the factory harness. The reason I say that is to keep it from interfering with the side curtain airbag if (hopefully never) it needed to deploy.
  13. Nov 3, 2018 at 5:17 PM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Losing the nav in the center display on the dash is a deal breaker for me. As far as I know, there are no aftermarket head units that retain that feature.
    Seems like only anther Toyota head unit would allow that to still work. Anybody try a 3rd gen Tacoma head unit in a Tundra?
  14. Nov 3, 2018 at 5:45 PM
    slide187
    slide187 New Member
    Boston, MA
    I don’t think you’d be able to get the taco HU to jive in the Tundra dash
  15. Nov 3, 2018 at 7:05 PM
    KB Voodoo
    Chad
    I really liked the unit in my 2016 Tacoma. It's a lot better than the Tundra unit, but I wouldn't go through a lot of trouble to make it happen. The Tundra unit is "good enough".
    Watt maker likes this.
  16. Dec 13, 2018 at 7:16 AM
    Nap1970
    Nap1970 New Member
    2018 Tundra TRD off road
    Is there anyway to mirror iPhone via Bluetooth for getting audio and video on 2018 Tundra stock entune audio plus? If not, what other options would I have for mirroring iPhone other than installing an aftermarket radio? Really not trying to remove factory unit because I don’t want to risk messing anything up with all the wiring and how supposedly everything back there is connected to safety features and etc. I just can’t get over how bad the factory stereo is and the Scout gps is practically completely useless. One of the worst that I have ever seen. Thanks for any feedback.
  17. Dec 13, 2018 at 7:22 AM
    B737
    Jersey Shore
    there is nothing special about the tundra head unit in regards to wiring, safety or connections. its just another 12 volt car and HU. all the features can be accessed after its removal through the use the idatalink kit. throw that junk out, and install what is gonna make you happy.
  18. Dec 14, 2018 at 8:47 AM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    This one will fit but will set you back $70,000 to $90,000Screenshot_20181214-114238_YouTube.jpg
    TheBlackPearl and Y0TA PR0 like this.
  19. Dec 14, 2018 at 9:00 AM
    KB Voodoo
    Chad
    The heads-up turn by turn navigation between the speedo and tach are lost with every single aftermarket HU available. That's a deal breaker for me and a lot of other people.
  20. Dec 14, 2018 at 9:06 AM
    #50
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    I agree with others that the stock HU isn't the best but this feature is one that I really like.
  21. Dec 14, 2018 at 9:45 AM
    #51
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    You've probably already seen these and aren't interested but the digital speedo in whatever app is tracking from the wired stock GPS antenna. My dash speedo behind the wheel is off since I have bigger tires and I never bothered getting a Hypertech calibrator. The HU is running Waze here.
    It does depend on GPS signal (no tunnels), and it's not as accurate with rapid acceleration/deceleration but at a steady speed it's more reliable than the vehicle's speedo even on stock wheels.
    https://www.theglobeandmail.com/glo...te-the-cars-speedo-or-the-gps/article4348596/
  22. Jan 13, 2019 at 9:23 AM
    #52
    bruce213
    bruce213 New Member
    Bruce
    2019 trd sport 4x4 crew cab
    Katzkin Leather, M2G DVD Player, Pioneer 8500NEX, 2" Spacers, Bigger Tires on Stock Rims, Undercover Flex Tonneau Cover, Bedrug, Tyger Fender Flares, Iron Cross Patriot Running Boards
    What’s the wiring harness??!
  23. Jan 13, 2019 at 3:08 PM
    #53
    ZPMAN
    Minnesota
    This was going to be my trucks first upgrade, http://www.beatsonicusa.com/if02ep.html
    Until I stumbled upon the Phoenix.
    I was not impressed with the library sound and lack of freedom on the stock unit.
  24. Jan 13, 2019 at 4:14 PM
    #54
    bruce213
    bruce213 New Member
    Bruce
    Wow that’s badass! I was thinking of doing an aftermarket just for the hdmi but this’ll save me a lot of money lol
  25. Dec 18, 2020 at 8:44 AM
    #55
    Scavezze1971
    Scavezze1971 New Member
    Greg
    2018 SR5 Plus TRD Off-road (Canadian)
    Well, maninly for me......Entune SUCKS. Oh and the bluetooth shenanigans with the factory unit.....oh and the GPS requires updating the map at $90....the sound quality, better resolution screen....capacitive vs. resistive touch screen....
  26. Apr 22, 2021 at 9:49 PM
    #56
    Native Warrior
    Native Warrior New Member
    Johnny
    2012 Toyota Tundra Trd Rockwarrior
    3” adjustable bilstein shock lift, wheel spacer
    I own a 2012 tundra Rockwarrior will a 2017 tundra platinum factory radio wire up in my truck or is the wiring all different? I just want a plug n play kinda deal for temporary. Anybody know I have steering controls and backup camera in the mirror.
  27. Apr 23, 2021 at 4:58 AM
    #57
    ninjajay
    Spoolston, TX
    completely different and not worth your effort
  28. Apr 25, 2021 at 5:37 PM
    #58
    Wirelessnate
    Wirelessnate New Member
    Nathan
    2015 Tundra Platinum CrewMax Black
    Ok here’s a dumb question, and maybe I should start a new thread. I have a 2015 Platinum, and like others I love the turn by turn between the gauges. Can I install a 2020 head unit with car ply built in?
  29. Apr 25, 2021 at 7:25 PM
    #59
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2, SmartCap, Ride Rite, Bora spacers, 35” rugged ridge tires.
    If you have car play why do you need the crappy factory NAV. Google is WAY better.
  30. Apr 25, 2021 at 10:15 PM
    #60
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    My Excellon no doubt has a bit of software, but android HU are on a whole different level. You are at the mercy of the programmers. So much software waiting to crash or bug out on you if you don t get the right updates, or if the programmer was doing crack:eek2::militarypress::goingcrazy:while coding.
