Who are the audio experts here?
Discussion in 'Audio & Video' started by Blankcheese, Jul 10, 2016.
  1. Jul 10, 2016 at 12:55 PM
    Blankcheese
    Blankcheese [OP] New Member
    Johnny
    '16 SR5 DC 4WD
    My '16 DC has rear under seat storage. I think I could put a 5-channel amp under the front passenger seat, but I have a feeling I'm skunked on a sub without losing the storage?
    I'd like to keep the head unit and upgrade the speakers and amp. And is that a speaker in the center of the dashboard top?
  2. Jul 10, 2016 at 1:03 PM
  3. Jul 10, 2016 at 1:03 PM
  4. Jul 10, 2016 at 3:27 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
  5. Jul 10, 2016 at 6:26 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    What is your spending limit? First off.
    TruckyTruck and rons23 like this.
  6. Jul 10, 2016 at 10:47 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    And what system package came with your truck?
  7. Jul 10, 2016 at 10:48 PM
    TruckyTruck
    Gary
    I'm no expert by the way... but I may come up with something smart to say 1 out of 100 times. :laugh:
  8. Jul 11, 2016 at 2:19 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Two good questions. As for budget, if I'm adding amp/sub let's say $1500 because I figured I need line out converter as well. My concern is: where would sub go if not behind the rear seat?
    I think I have the basic Entune non-JBL with what appears to be a center speaker top of dash. You can see I haven't opened a manual yet.
  9. Jul 11, 2016 at 5:12 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm no expert either, but I think your best bet is to mount a shallow mount sub behind 1 seat and the amp behind the other. If I were to get a sub I would go with the JL 10TW3 shallow mount.
  10. Jul 11, 2016 at 5:38 AM
    Mike Tread lightly.
    south carolina
    If you do a line level out, you know it does pick up extra noise do to the conversion from power to pre amp levels.. they can be points of engine noise over time..
    As for the sub it can go behind the rear seat...
    Any brand of amp and speakers you are looking at or you open?
    TruckyTruck likes this.
  11. Jul 11, 2016 at 9:20 AM
    TruckyTruck
    Gary
    Yeah the Toyota radios give out a pretty dirty signal too.
    You might see if you could talk with taco tunes, if that's the equipment you are looking at, and see if they can tell you about thier line converters.
    If you have the basic radio package, there may not be a speaker in the center of the dash. Mine is a 13 and did not.
    I just replaced the 4 door speakers and bypassed the two little dash speakers, but if you do components, you can put your tweeters in the dash and the other parts in the front doors.
  12. Jul 11, 2016 at 10:44 AM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    I have a '15 dbl cab. Just had a line converter and Kenwood amd installed two weeks ago. The amp is under the drivers seat and the line converter under the passenger side. Like others here have said the stock head unit does produce white noise. It is a bit anoying at low volumes. I replaced all the door speakers and the two tweeters in the dash. The center dash speaker was left connected to the factory amp under the seat. Sounds much better.
  13. Jul 11, 2016 at 10:55 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    Great info thanks all!
  14. Jul 11, 2016 at 2:33 PM
    TruckyTruck
    Gary
    That taco tune line converter may have the ability to filter out the white noise, but like user says, the white noise is really annoying. I couldn't take it so I replaced the head unit.
