ACT FAST- METHOD CLOSEOUTS
Discussion in 'Deals & Group Buys' started by Hams, Oct 18, 2018.
  1. Oct 18, 2018 at 10:11 PM
    Hams
    Hams [OP] New Member
    Joel
    Fort Myers, FL
    16- Pro
    Camburg uniball UCA, Cooper AT3 XLT 295, Coachbuilder shims, shackles, and steering kit, SCS Ray 10, Undercover Flex Cover Ultra, GTR Lighting LED headlight and fog.
    Check out Method Wheel closeouts. Just ordered 18” Vex (x5) $786 shipped. According to master parts list Vex, Con, and Roost are hub centric for those that care.
  2. Oct 18, 2018 at 10:25 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Good deal.
    joonbug and 831Tun like this.
  3. Oct 19, 2018 at 5:13 PM
    CementGen3
    CementGen3 Gas station Attendant
    Will
    Western WA
    2018 Cement SR5 CM 4x4
    TRD Dual Exhaust TRD rear sway bar Method Wheels Vex 311
    Use promo code closeout15 for an even better deal.
    dcsleeper408 and DMathys like this.
  4. Oct 19, 2018 at 6:25 PM
    DMathys
    DMathys New Member
    Thanks for the heads up. Just ordered. Promo code works as well.
    CementGen3 likes this.
  5. Oct 20, 2018 at 8:46 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Looking at buying the Vex and then having them powder coated black. The only color is the dark gray with gold. What are your guys thoughts?
    I like SCS rims, but $1200 is steep. Right now 4 Method rims would set me back $448, then powder coating.
  6. Oct 21, 2018 at 7:02 AM
    Hams
    Joel
    Fort Myers, FL
    16- Pro
    I would get them and have them coated, most don’t like the shiny bolts so you would be taking care of that. Also able to get a textured finish, which is what I would do if I had mine powder coated. For example check out Barstow wheel by Black Rhino.
    Another thought, the factory grey vex might look good with ur (gray) cement truck.
  7. Oct 21, 2018 at 7:28 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    That gold’s gotta go though bro. Have you heard how much folks are getting charged for powder coating?
    Then you’ve got the +18 offset, I was sort of hoping for +20 to +25 for when i level and add 295s.
  8. Oct 21, 2018 at 1:52 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    +18 to +20 is only 2mm, so not huge difference.
  9. Oct 21, 2018 at 2:42 PM
    Hams
    Joel
    Fort Myers, FL
    16- Pro
    Method also offers a black bolt kit for these wheels, however, currently out of stock. I will be calling Monday for ETA. look under wheel accessories.
    For tires I will be running the elusive 285/70/18 Nittos. Nearly 10 lbs lighter than 295 and will most likely ensure no rubbing. I’m surprised many more don’t consider the unsprung weight and extra 1 inch can add when it comes to tires.
  10. Oct 22, 2018 at 3:41 PM
    DMathys
    DMathys New Member
    Heads up, just had my order canceled by Method. They did not have enough stock to cover the order.
    If you ordered close out wheels wait for shipping confirmation before you order lug nuts or tires. I thought with purchase confirmation and bank charge I was good to go and bought both...
  11. Oct 22, 2018 at 5:19 PM
    Hams
    Joel
    Fort Myers, FL
    16- Pro
    Same happened here and I thought I was safe. Piss poor inventory mgmt system for a company that size. Taking my business to SCS.
    TheBeast likes this.
  12. Oct 22, 2018 at 5:41 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Good lookin out
  13. Oct 22, 2018 at 6:23 PM
    DMathys
    DMathys New Member
    Agreed. I understand computer hiccups happen but when I told them the wheel order was processed so I bought lugnuts and tires they said "ok".... no sorry, offers to honor the order when wheels come back in stock, etc.
  14. Oct 24, 2018 at 7:11 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Little help boys.. Which 18's do I get for my 16 pro stock suspension running 285/70/R18 toyo MT's... I want an off set that will widen the stance up a bit.
  15. Oct 24, 2018 at 7:30 PM
    Hams
    Joel
    Fort Myers, FL
    16- Pro
    Couple of options, 1- run 1.25 wheel spacers from spidertrax or bora using your stock pro wheels cheap way to bump out ur stance. 2- run +18 or +25 offset wheel of your liking and sell ur pro wheels to make up diff. Keep in mind your pro wheels are +60 so going to +25 wheel will push wheel out 1.38 inches going to a +18 will move u out 1.65 inches. The math is figured in mm using ur pro wheel as a base line. I use mm to inches calculator.
    Also, as u may know our lug pattern is 5x150
    I’m going hubcentirc wheel which is factory set up rather than lug centric. Many run lug centric with no problems, just don’t seem right to me. Bad news is from my research there are like 3-4 hub centric options fortunately Icon and SCS have some bad ass designs. Strongly encourage you review SCS.
    War_Wagon312 likes this.
  16. Oct 24, 2018 at 7:45 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Your the man. That was extremely helpful and informative. Thank you for the info!
