Bubba Rope Promotion! Free Soft Shackle Exp 9-30-2016
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Jul 1, 2016.
  1. Jul 1, 2016 at 10:16 AM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    From now until the end of September whenever you order a Bubba Rope through us we will hook you up with a free Gator Jaw soft shackle in the color of your choice. These extremely versatile little guys have a breaking strength of 32K pounds and eliminate the annoying rattle of conventional shackle on your bumper.
    http://store.sdhqoffroad.com/bubbarope.aspx
    If you are not familiar with the benefits and application of a soft shackle here's some additional information:
    Stronger Than Steel!
    Breaking Strength: 32,000 lbs!
    Gator-Jaw shackles are made from Plasma® rope which is the highest strength synthetic rope available. Gator-Jaw™ shackles are stronger than comparable steel shackles. These shackles won’t rust and are so light they float. Towing applications include: 4x4 off-road, agriculture & mining equipment and various marine uses.
    Advantages Over Steel Shackles:
    Stronger than steel - 32,000 lb. breaking strength!
    It floats - no more losing shackles in the water or muck!
    Flexible - easily wraps around the most difficult pulling points!
    One piece construction - no pins to fasten!
    Uses:
    Off-Road Recovery
    Marine
    Farming
    Industrial
    Mining
    How to use:
    Open Gator-Jaw shackle by loosening and slipping off loop over knot
    Thread through eye of Bubba Rope or strap and through tow point
    Check your vehicle’s owner’s manual for proper attachment points
    Do Not attach to bumper, trailer hitch ball or sharp edged tow point
    Loop Gator-Jaw eye back over knot and pull to tighten
    Pull as normal. Gator-Jaw shackles are designed to take the load without stretching
    CARE & MAINTENANCE
    The Gator-Jaw shackle by Bubba Rope can be washed off with water and air dried. While Gator-Jaw fibers are stronger than steel they are susceptible to wear and cutting. Always inspect shackle before use for excess wear, cutting, or worn and frayed areas.
    Rope diameter: 7/16"
    Law323, Ancient1, T-Rex266 and 3 others like this.
  2. Jul 1, 2016 at 10:25 AM
    TheBeast
    TheBeast The Beach
    very cool
  3. Jul 1, 2016 at 10:59 AM
    Aurora CO
    Hmmm........
  4. Jul 1, 2016 at 12:47 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    X2.
  5. Jul 8, 2016 at 9:15 AM
    sdhq_offroad
    GILBERT, AZ
    bump! These are in stock and ready to ship guys!!! Don't miss the chance to get an extremely high quality snatch strap for a great deal and replace those obnoxious D-rings on your bumper while you're at it.
    rons23 likes this.
  6. Jul 8, 2016 at 7:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have heard the soft shackles are amazing.
  7. Jul 11, 2016 at 9:57 AM
    sdhq_offroad
    GILBERT, AZ
    They are pretty awesome! Its essentially a small piece of synthetic winch line that has been turned into a shackle. Super easy to work with, light weight and way easier to get onto factory tow hooks. Paired with a quality BubbaRope snatch strap makes getting stuck truck recovered a breeze with less stress on your vehicle since the strap does the majority of the work.
  8. Jul 14, 2016 at 9:30 AM
    sdhq_offroad
    GILBERT, AZ
  9. Jul 15, 2016 at 8:49 AM
    sdhq_offroad
    GILBERT, AZ
    to the top! These have been flying off the shelves here in the shop. Tons of local guys making the switch in everything from their UTVs to full size trucks!
  10. Jul 23, 2016 at 1:06 PM
    sdhq_offroad
    GILBERT, AZ
  11. Jul 26, 2016 at 8:34 AM
    sdhq_offroad
    GILBERT, AZ
